Page 566 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Intel likely secured this 3nm quite early, possibly before AMD decided that they were not going to use 4nm. In the time that AMD decided they were going to stick with 4nm from Zen 4 to Zen 5, pricing renegotiation would have had to take place. Huang was probably already producing boatloads of Ada and Hopper GPUs and AMD was producing MI-300X and EPYC, most of which are more profitable per mm2 than client CPU. Im not saying the 4nm is more expensive than the 3, Im saying its very close or on par-- and even if its not, it still has pricing pressure because AMD can repurpose the same die not selling on desktop to be use in EPYC, which commands a higher price. All of this adds up to Zen 5 being expensive. AMD has no incentive to lower the price, its better for them to just be content with selling the silicon in other products.
We'll see who is right very soon. I'd be willing to bet that Arrow Lake will not be any more expensive than launch pricing of Zen 5, and could actually have cheaper launch pricing, which would validate my line of thinking here.
Your guess was pretty good, based on Raichu prices.
TSMC N3B is very expensive for Intel. They commented on it multiple times in their latest earnings call. It is one of the key factors they identified for low gross margin forecasts for the end of the year and into 2025.
N3B for whole die like LNL is expensive yes but not ARL as a whole in which a part is N3B rest is taken by SOC
ARROW LAKE n3b 8+16 die size is approx 13.69X6.45 approx 88.30 mm2
A 19K WAFER AND 572 U9 Dies it is approx 33 USD for the CPU die it is an approximation not counting defective can be U7 i took yield as 0.15 cause iirc N3B yield are behind N5 which is <0.1 so i took it 1.5
Are you saying N3B is less expensive than prior nodes if the die is smaller? It’s expensive either way. Obviously less die space on the most expensive node is better, but it’s still just as expensive a node, is the biggest part of the SOC (at least for the high end), and you have to deal with the additional advanced packaging costs, including a bigger base tile. There's a reason Intel said that margins will remain low until they can get off of external nodes and transition to 18a.
Nope i am saying the total cost for the entire chip will be the deciding factor based on my copy+paste skills i have shown above it costs around $33 to produce the CPU Die
What's more expensive: monolithic 260mm2 on Intel 7 or 100mm2 N3 and N6 + foveros and a tiny N5 gfx tile? The difference might not be that much tbh, N3 CPU tile yields must be way higher, they get more i9s and i7s per wafer
That's a complicated question. Under the latest separation of Intel foundry, Intel Foundry charges Intel products like $20 and says the Foundry has a loss of $60 on that sale.
But if it was 260 mm2 N7 vs: combined costs of
100 mm2 N3N
44 mm2 N5
100 mm2 N6
27 mm2 N6
Foveros die + packaging
Arrow Lake is still definitely more expensive. Probably +50% to +100% the cost vs. what equivalent 260 mm2 N7 would cost.
100 mm2 N3N
44 mm2 N5
100 mm2 N6
27 mm2 N6
It is 23mm2 for the gpu it is already in MTL-U IO is around 20 iirc N3B is 90mm2 and SOC 100 yes
Yes no doubt it is more expensive than RPL
I expect the 8+16 die to be larger than that. I also think you are discounting the cost of N3B wafers. Either way, the point is that N3B is expensive, advanced packaging is expensive, and there is no way that Intel is getting a better deal with N3B + N4/N5/N6 on advanced packaging than AMD is for N4P + N6 with much cheaper packaging and is obviously more expensive than if they had gone with N4P themselves.
Nope it was always rumored to be 19k-20k per wafer also why do you expect it to be larger than that never mind found the reason i almost forgot about L2 cache from 2.5 -> 3 so yeah additional few mm2 but i think it will be less than 100
Yes i fully agree it is not cheaper than Zen 5 but by how much that is an open question
I think right around 100 mm2 but not 100% sure. That price I believe is N3E, not N3B, N3B is noticeably more expensive.
My main point was that there was no way ARL wasn't more expensive, so I'm glad we agree there and I agree that it's difficult to say how much more expensive it is then Zen 5, but it's significant enough for Intel to comment directly on how expensive it is for them to use TSMC with ARL and LNL.
You know that wafer price comes down a bit over time
One thing with Raptor lake is the foundry margin is also going to Intel however they wanna show it in their books if they get nodes competitive to TSMC and similar cost structure their margins are going to improve dramatically
TSMC actually went through multiple price increases over the last few years, though I believe they stabilized and dipped a little in 2023/2024. They are reportedly increasing prices again in 2025.
In 2022, TSMC raised wafer prices by 10%, followed by an additional 5% in 2023. Looking ahead, another 5% blended increase is anticipated for 2025 in a bid to help TSMC's gross margin rebound to 53% - 54% by 2025.
Edit: Found the Morgan Stanley analyst's chart showing wafer cost per node changes over time. The chart shows each node with the baseline price being 100% and the percentage point change over 6 years (2025-2026 predicted).
Could hike and wafer agreement is in advance do you think Intel will pay hiked prices if their agreement already had 19K-20Kfor a fixed amount of wafer after that sure
You seem to think price negotiations can only go down. Intel is a direct and vocal competitor, with a widely known need to secure capacity on a leading edge node after multiple manufacturing failures. TSMC may be open for business with everyone, but I doubt they cannot spot a desperate customer when they see one.
Intel is a long-time customer of TSMC and on the verge of switching most of their volume to TSMC. I think TSMC will negotiate with them fairly as it weakens a future foundry competitor if even Intel won't use Intel Foundry.
I'm not going to argue about the exact price as those are under NDA and specific to high volume contracts anyway. The point was that prices haven't come down, they have and are going up.
Intel is a long-time customer of TSMC and on the verge of switching most of their volume to TSMC. I think TSMC will negotiate with them fairly as it weaken a future foundry competitor if even Intel won't use Intel Foundry.
I'm with @coercitiv on this, Intel is not really in a position to negotiate and TSMC knows it. If Intel signed a long term contract for multiple generations, it would probably be a different story, but Intel has only been talking a lot about getting off of TSMC as quickly as possible. Foundries value not just high volume, but also long term customers. Intel has told the world, they are not a long term customer for TSMC, so TSMC doesn't have much incentive to deal generously with them. I'm sure they're giving them a fair rate, but I doubt it is anything special.
That's not how TSMC works and even if it was It's in TSMC's best interests to treat Intel well. If going with external wafers gives them the best performance and experience, the harder it is for Intel to justify their own fabs.
