Page 564 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Joe NYC
4,129
5,683
I wouldnt be so sure. At least I no longer think it'll be more expensive than Zen 5 / 4nm. The reason why is Huang and his damned H100/200/ Blackwell AI GPUs. He is selling an enormous quantity them at an enormous price and TSMC picked up on that a year or so ago and increased 4nm pricing. As of now, Im not too sure of any really big players besides Intel and to a lesser degree, AMD, that are buying up that 3nm production line. NV's next GPU may be on 2nm or even 18A (or both). I have come to believe that 4nm wafer price hike by TSMC is the reason that Zen 5 launched with seemingly mismatched pricing and has seen relatively muted price drops despite by most accounts, having terrible sales.
Wafer prices and quantities are negotiated in advance, and then the contract stays as signed. AMD and Intel may have come to TSMC at the same time seeking capacity. AMD found price of N3 to expensive and instead retrofitted Zen 5 to N4 (at some expense in terms of manpower and features). Intel just said fine, and is paying the higher price. Thinking that Intel is not paying substantially higher price for N3 wafers than AMD is paying for N5/N4 is just being in LaLa Land. AMD would have stayed with their original plan to use N3 for Zen 5 if that was the case.
Then comes the die size. We don't know what ARL die size is of the compute die, but given that Intel P-cores are bigger than Zen cores, the odds are that ARL P cores portion alone + its L2 and L3 are probably the same or bigger on N3 than Zen 5 CCD die (which is 70 mm2). But then, Intel also has 16 E-Cores on top of it.
Or comparing it to Metero Lake, which has roughly identical die compute die size, but has only 6P cores and 8 E Cores.
Same or larger die size of ARL compute tile is going to cost a good amount more on N3B than same or smaller die on N4P.
H433x0n
1,224
1,606
Ah, yes… Right on cue.
I’m really curious what he will say when he finds out the i7 and i9 K SKUs have a 250W power limit.
We’ve seen Lion Cove and Skymont in Lunar Lake, I get it’s not apples/apples but I doubt it magically becomes inefficient. Obviously it’s less power constrained and uncore is clocked higher but it’s still the same core and same node.
Reactions: Tlh97 and coercitiv
Det0x
1,484
5,089
ondma
3,319
1,708
So? If you want the best gaming processor on the market you still get the X3D variant. Nothing else beats the current version, anything extra is icing on the cake.
True, but the point I was making is that neither ARL or Zen5 is a significant improvement over the previous generation in gaming performance. It is still unknown if 9xxx x3D will be a significant improvement over 7800x3D in gaming.
DrMrLordX
23,178
13,266
at least there is Intel claiming 32% IPC Gracemount
Arrow Lake-N wen?
This is it for x86 i guess first Zen5% now core ultra 2% 💀
Again with the Zen5% nonsense. This is an Intel thread. You want to discuss Zen5? Go take it to one of the Zen5 threads and see how far you get with that nonsense.
This video is damm funny
This is an Intel thread . . .
Reactions: Tlh97 and 511
H433x0n
1,224
1,606
It isn't magic, it's the inefficiency needed for the last 600 MHz.
If it’s efficient at 5.0ghz in LNL, it’s not going to be inefficient at 5.0ghz in ARL.
In an hypothetical scenario where it is equally efficient as the 9950X in the 125-175W range but has a higher PL2 are we really going to say it’s less efficient chip? Why ignore nuance and just harp on an arbitrary PL2 number?
Reactions: lightmanek
coercitiv
7,464
17,822
There's more to it though. For example they finally have independent voltage rails for P and E cores. That does not directly translate in better efficiency, especially under load (where they could go full tilt), but in theory it can help both light threaded and multithreaded workloads.
Det0x
1,484
5,089
Or as it usually goes, the official numbers are a bit inflated. So it could go the other way too ;)
Or just look at what they compared against..
In gaming they compared vs the 9950X, not 7800X3D/7950X3D (on a pre-patched Windows 11?)
In content creation they compared vs the 7950X3d, not 9950X
In power consumption vs 14900k, not Zen4/Zen5
And that is Intels own benches with APO enabled in gaming and @ 250w powerlimit in content creation, and i would not surprise if the power consumption test was done @ "baseline profile" for Arrow Lake and "performance/extreme profile" for Raptor Lake
Ontop of 5200MT/s memoryspeed for Zen4/5, 5600MT/s for 14900k and 6400MT/s for the 285K..
I can see the writing on the wall when we get third-party, apples-to-apples benchmarks 🧐
coercitiv
7,464
17,822
I think we should wait for reviews. It could end up being more good than we think
ARL will probably have more variance than LNL in various workloads - I would expect there will be benchmarks, probably the ones less sensitive to latency, where Lion Cove will stretch it's legs. If we're "lucky" the 9% IPC figure includes gaming, this should hide productivity workloads where it might be quite a bit better. That being said, the same applies to the other team's product, so it will be interesting to watch how everything unfolds.
For now though, we still need to let the gaming steam out.
MS_AT
927
1,848
AVX10 is strictly worse thing than AVX-512 that Zen 5 has, it is likely inferior to Zen 4's version of AVX-512.
APX okay, that is in interesting addition, but in last 15+ years, CPU cores have developed many tricks to sidestep all the deficiencies that APX seeks to correct, so there won't be some large benefit from it, IMHO.
Maybe to expand a bit. AVX10 will be an improvement for Intel from the feature point of view (new instructions, masking), but the consumer version (AVX10/256) will not be an improvement from throughput point of view. Compared to Zen4 double pumped units, it will also not help with code footprint, but the new features will definitely help.
For the APX, I would love for it to be already a thing as I am running out of GPRs to hold addresses for SIMD ;) So having 32 of them would require less gymnastics.
But for both, APX and AVX10 the real problem is that you need code compiled for them. It's the same story as with Zen5, it has the best known AVX512 implementation, but in reality there is little software making use of it.
Kocicak
1,177
1,232
I wonder if Arrow lake performs like this because it should be this way, or if it is somehow broken but it would require such a long time or expense to fix it, that Intel simply gave up and released it as is.
I wonder if the problem is not related to the disaggregation of the CPU. There are too many pieces in the puzzle and each of them needs to be 100% in order. This must be a nightmare to make.
KompuKare
1,234
1,606
Good points!
Internally marketing should have the full set of results from their technical marketing labs therefore whatever they actually choose to show tends to be whatever makes them look best. Sure that is marketing's job but reading between the lines is very important.
Sometime next month after all the reviews, should we create a
"2024 CPUs, their hype-train, and subsequent derailment"
in a vendor neutral thread with ARL, Zen5, SnapDragon X, etc.!?
Joe NYC
4,129
5,683
Yes, the slides don't compare against the best CPU from the competition for the category of applications, but they pick the CPU that is not the best fit.
Also, someone mentioned Intel used DDR5-6400 memory for AMD. I seriously doubt that Intel is using it in 1:1 clock ratio, that is ideal for AMD processors. AMD recommends DDR5-6000 and there are tons out there that are cheap and supporting good memory timings.
BTW, this guy on youtube goes over the benches:
Reactions: Tlh97 and Tarkin77
511
5,345
4,759
Are all slides leaked though that is my point we know how is it with the leaks we will know in 30 hours
Reactions: Tlh97 and Joe NYC
