Page 545 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
940
852
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15W?Intel Lunar LakeIntel Panther Lake 4+4+4
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,106
3,227
To kill off a successful product segment for BOM optimization is a mistake. If LNL is a sales success, they could charge more to offset the higher costs.
Something more important than margins and revenue is the ability to create new markets and shut off competition.
It's same with the arguments regarding iGPUs. Sure it increases die costs a bit, but without it you are completely locked out of majority of markets. That is above and beyond the impact of any die size savings would give you.
DavidC1
2,106
3,227
Based on the size of the NPU, they could have put 24MB MLC and further lowered power and improved performance. It's way way too large.
Nah, this is a misconception likely originating from MLID, about Lioncove bring a part of royal core/an entirely new project and uarch team led by Jim Keller. That's simply not true. Lioncove still has a lot in common with redwood cove and all prior Intel core uarch as shown by C&C and David Huang's articles. The core still behaves largely the same in a lot of key metrics
Yup.
Layout has changed substantially on Prescott too, it just did not perform well. Lion Cove is the size of Zen 5 despite a substantially denser process, without top clock speed advantage(both at 5.7GHz), without SMT which according to Intel should give noticeable ST and die area advantages.
The biggest red flag to me is the branch prediction regression. Branch prediction is THE key to improving performance, and it's now worse than distant successor to "Atom" core which had very very humble beginnings. Branch prediction regression tells me the team is really really struggling.
adroc_thurston
8,249
10,996
the costs are worth it
Nope.
and required to compete at the highest level.
Premium tablet chips are very very very niche.
I think it’d be in best interest of Intel to create a new product segment based off of LNL
It's literally dead already.
PTL and NVL are both focused on BOM optimization.
It's not. Premium Windows tablets are 10 years like dead.
It's not a new market, Core Y is like 12 years old.
Fat iGP is niche. Which is why the ULV PTL has a tiny one.
Reactions: Joe NYC
FlameTail
4,384
2,762
Comparison of CPU core areas
This was posted on reddit.
Private caches have been included to core area;
Intel/AMD = L0, L1, L2.
Apple/Qualcomm = L1.
It seems Lion Cove is still rather bloated, compared to the competition. On the other hand, Skymont area efficiency is impressive.
The Hardcard
346
442
Is it bloated? The L2 cache is what it is and it’s 2.5 MB. It would be interesting if logic area could be compared.
poke01
4,761
6,095
Remembers 12” MacBook ugh that core M but still.
I think Intel got luckily with N3B, if Lunar was on N3E lion cove would have been even bigger.
Hulk
4,005
Re Geekbench 6 testing. I set my P cores to 2.7GHz to simulate 8 more E's. No hyperthreading of course. The result shows GB6 basically going to 0 by the time you get to 24 cores. By that I mean the 24th core should theoretically increase overall score by 4.3% but in reality only adds 0.6% increase in performance, or 13.2% of that theoretical amount.
Those first 8 or so cores are really important for a high GB6 score.
511
5,340
4,754
I think they still have AVX-512 related logic and stuff in the core just it's fricking disabled Intel's presentation Slides that
AMDK11
489
435
Of course it is. This is not due to any Keller or Royal Core.
LionCove is a transition from a unified schedule of 3xFP/ALU and 2xALU to separate 4xFP + 6xALU. This is a radical change since the days of Pentium PRO(P6).
AMDK11
489
435
Yup.
Even though I agree that Intel is pushing for clock speeds like in the Pentium 4 times, you are transferring it too literally to LionCove. Pentium 4 compared to Pentium III had a regression from 3-Wide decoder to 1-Wide.
LionCove is pushing for higher IPC as opposed to Pentium 4.
DrMrLordX
23,174
13,262
Which means Lunarlake is efficient at the system level that they can juice more to the SoC yet offer same battery life, ending up as a superior product.
That doesn't make any sense. If it pulls more power then it's going to wear out the battery faster unless it somehow is racing to idle quickly enough to justify the additional power draw. That doesn't seem to be the case based on the results of the Geekerwan video.
@Abwx also has a point. Why are the SoC power draw numbers so different? They don't conform to the board power limits, and there's no indicator that the opposition system has parasitic losses outside of the SoC. Also nobody really wants to address the main point he was making, which is that the Lunar Lake SoC requires more power to achieve higher benchmark results. The whole point of the test wasn't to speculate about parasitic losses or platform efficiency, it was to isolate each SoC and determine perf/watt. If Geekerwan intended for both SoCs to use the same amount of power, then he failed in execution, because they simply did not.
It's quite possible it was carried over from Alder Lake.
The only way anyone would have noticed such a problem on Alder Lake is if they somehow tuned it to pull the same TVB volts (1.6v+) as could be requested on a Raptor Lake system. Honestly I have no idea if Alder Lake can exhibit that behavior.
FlameTail
4,384
2,762
And Intel/AMD needs to follow that direction, because I suspect large L1 caches are also contributing to efficiency in their designs because it keeps lot of data from going out into slower, higher power cache levels and memory.
The basis of Apple's design is also having stellar design team, because being able to have 4GHz clocks at such low power at just 9 pipeline stages and humongous L1 cache with 3 cycle latency is amazing.
Apple's cache hierarchy is also more cost/area effective. If you compare M3 vs Lunar Lake, Intel is spending more capacity (and hence area!) on caches.
Apple M3
4P + 4E
(192 KB pL1i/128 KB pL1d)×4 + (128 KB pL1i/64 KB pL1d)×4
16 MB sL2 + 4 MB sL2
8 MB SLC
Lunar Lake
4P + 4LPE
(48 KB pL0d)×4 + 0
(192 KB pL1d/128 KB pL1i)×4 + (64 KB L1i/32 KB L1d)×4
(2.5 MB pL2)×4 + 4 MB sL2
12 MB sL3 + 0
8 MB SLC
poke01
4,761
6,095
Apple M3
4P + 4E
8 MB SLC
Lunar Lake
4P + 4LPE
(48 KB pL0d)×4 + 0
12 MB sL3 + 0
8 MB SLC
So where does this idea “Apple has more caches than Intel/AMD” come from then?
FlameTail
4,384
2,762
Good question. Two reasons, I think;
(1) When Apple M1 came out, it did actually have much larger caches than Intel/AMD peers. However since then (M1 -> M4), Apple has hardly increased the sizes at all (L1i/L1d has been the same size, P-core L2 went from 12 MB to 16 MB). Meanwhile in the same time period, Intel/AMD made large increases to their cache capacities, so much so that now Intel has surpassed Apple (as you can see in my previous post).
(2) Apple has more cache for an equivalent level compared to Intel/AMD. Apple's L1 and L2 caches are huge (But they don't have an L3 like Intel/AMD do).
DavidC1
2,106
3,227
You are also missing the point, or maybe you aren't paying attention. Likely AMD has incorrect sensors as two outlets point this out, how the system power is comparable to Intel platform that has the TDP of the SoC set 5W or so higher.
You have a handheld, you are gaming. One has a 22W SoC but 30W system power, for 2 hours of gaming with a 60WHr battery. The other has a 15W SoC but still same 30W system power, for the same 2 hours of gaming with a 60WHr battery.
If Geekerwan or other outlets set the TDP to be same between Intel platforms and AMD platforms, the system power would end up being LESS than the AMD system thus you end up with better battery life.
As a user do you really care about SoC power? Especially when the system power numbers show different than expected?
Apple has way more L1 caches than both vendors. It's the fastest cache so it performs better, and it's the closest so you save power because you are needing to move less.
Lion Cove is on N3B process, which affords at least 30% density advantage over N4, thus Zen 5 on N3B would end up being 3.2mm2, making Lion Cove almost 50% larger.
DavidC1
2,106
3,227
That's cause Y chips weren't excelling in any areas. The battery life was nowhere near competitive unless you got it thicker than most Tablets. The Y chips were super slow in both single thread and iGPUs, while Lunarlake offers excellent battery life, top notch single thread and iGPU performance.
It still is a market they should pursue, even just to keep WoA out. You don't abandon a market because it sucks for one year.
The BOM argument is short-sighted. The only reason WoA had any chance of taking even 1% marketshare is because Intel refused to make a truly good battery life Intel platform. This is also important on a psychological level, that x86 CAN rival ARM chips in battery life, which from comments on LNL reviews, people are surprised by. Of course Intel is likely going to do what you expect and just focus on BoM, because they are really a finance company that happens to hire engineers.
I agree with this. But I'm pretty sure you are smart enough to figure out that wasn't my point.
poke01
4,761
6,095
Is WoA ever a threat to Intel? First MS/qualcomm need to fix the basic productivity software like the adobe suite, blender etc and then Qualcomm needs to make a low power design which next gen X Elite isn’t going be.
I don’t it will be Qualcomm who Intel should be worried about although that 5GHz core if it that happens and its efficient then it’s different. Intel should be worried about Nvidia, if those rumours of a Nvidia entry into CPU WoA market is true then that’s more of a threat to Intel. Nvidia got potent engineers and mindshare and excellent GPU IP. If Nvidia is smart they would release a 4-12P core SoC with 20SM GPU and a RAM up to 128GB.
This is exactly what Thor Jetson is meant to be, if Nvidia release this on the WoA platform then it will be more than 1%.
AMDK11
489
435
As for the LionCove vs Zen5 surface:
LionCove
L1-I 64KB
L0-D 48KB
L1-D 192KB
L2 2.5MB
Zen5
L1-I 32KB
L1-D 48KB
L2 1MB
In addition, LionCove has larger buffers, scheduler, ROB, etc. All this costs transistors. Besides, a single 8-Wide decoder makes the Front-End more complicated.
We'll see what LionCove will show at ArrowLake. I suspect that outside of L2, the LionCove logic in LunarLake has been slimmed down. Confirmation will be available in a few days.
