Page 510 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
859
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
5,562
4,967
1726500106712-png.107663
This table clearly shows N4P is better than N3B 🤣 if we take Semiwikis estimation for it than Intel 4 is on par with N5 and N3E is similar to Intel 3 in terms of PPW not area as I3 is slightly better than N5
Early reports are that customers aren't overly enthusiastic about 18a, but it hasn't actually released yet so we'll see how well it does when it lands.
Yes apparently they reduced the targets for 18A to get it on time and 18AP will be a better version but it will be on par
DavidC1
2,199
3,358
They downgraded i3 too.
They initially claimed it'll have HD library and it'll have density improvements for high performance. Instead we got "HD" library which was barely smaller than i4 and nothing for HP.
And we got 18A downgraded to essentially original 20A specs. In this regard they shouldn't have leadership anymore because it was using 18A they would have had leadership.
And they are killing the entire company to achieve those mediocre specs.
Reactions: Tlh97 and OneEng2
DavidC1
2,199
3,358
Lenovo Yoga Aura has a 1200p which is a 1080p panel but for the 16:10 aspect ratio.
On the site it's still only 1800p. Besides 15-inch screen makes the whole thing quite bulky.
I think you'll see more of that in the second round of LNL designs whenever those drop. This first salvo at IFA was really centered on the super premium segment which kind of demands great screens so that's what most of these are equipped with.
LNL is not gonna be in entry level designs any time soon if ever but it will find its way in the upper midrange over the next several months and those will be more likely to ship with lower res IPS panels.
There's some like me that would not take battery life tradeoffs for a potentially better looking display. Eh it looks like I have to wait to see what Japanese manufacturers offer.
When I first got my old XPS 12, the screen looked vibrant. It only lasted a month before it felt normal.
Screen is temporary, battery life is forever.
511
5,562
4,967
You are wrong here 18% PPW and ~10% density increase is what TSMC calling a full node from now on so how is intel different from TSMC also on Intel 3 they met all their goals listed also the denser HP 2-2 Fin can be HP library as well it was a bit misleading but Intel 3 met everything they claimed
18A was downgraded from what they showed and they are betting the company on it but regarding killing the company what better alternative do they have now it's either go all in or go home broke as for how good 18A is we will find out in Q3 next year product ramp takes time as well DD is the only nice thing we have been given for 18A outside of disappointments which is inline with what TSMC had with N5
Reactions: OneEng2
cebri1
373
405
Intel 3 has HD libraries. There is no evidence that this has changed or that there was any modification of specs.
Reactions: Ghostsonplanets
cebri1
373
405
I don't think he said Intel 3 doesn't have HD libraries. More like, Intel 3's HD libraries aren't "HD" enough.
How does he know what is enough? He said Intel 3 was downgraded, and that's not true. It's meeting the performance expectations, ofc for him Intel always falls short.
Reactions: sgs_x86
cebri1
373
405
Yep. Thats true. Intel 3 was never downgraded. But, then again, in his defense, even a half-node should improve the transistors (at least a bit). But Intel 3 didn't bring in any improvements to the HP libraries. They remain exactly the same (something I find a bit disappointing).
Just fyi, estimates put Intel 3 HD density at around 150 - 160 MTr/mm2 and TSMC N3B at ~200. To remain competitive, Intel should also have pushed their HD libraries a bit further. That what I meant by "not HD enough".
What for? Intel 3 never going to compete with N3B for leading edge, it's pretty much an internal node that delivers a nice improvement over Intel 4, more than a 20% density increase.
Why would you aim for higher density targets and add additional risk, when it's a key node for your server lineup? Over Intel 7, Intel 3 already delivers a 40%+ improvement in performance per watt. If GNR builds on the improvements delivered by EMR, GNR is going to be able to provide over 50% improvement in perfomance per watt over SPR. A massive generational improvement.
DavidC1
2,199
3,358
Read what it says on the slide:
"Denser HP libraries". That's not what we got, did we?
We should have got a denser HP library, and a separate and even denser HD library.
Instead, the HP is same as Intel 4, and HD only offers 10% gain. It's a downgrade from what they were saying, just like 18A is.
I'm saying it was downgraded because it was downgrade from the original 5N4Y goals in that VERY slide.
18A's downgraded gain is also over the reduced Intel 3. The density gain is only 30% over Intel 3.
Though Intel never said this, there were projections that 18A would offer substantial density improvements. It was repeated everywhere too, how the TSMC's mediocre scaling gain will be beaten by 20A/18A's amazing density gain.
Look at this forecast: https://semiwiki.com/semiconductor-services/techinsights/310900-can-intel-catch-tsmc-in-2025/
We are estimating a 1.6X density improvement. In the second half of 2024 Intel’s 18A process is due with a 10% performance improvement. We are estimating a 1.06X density improvement making this another half node.
They estimated 20A being 1.6x and 18A being additional 1.06x.
Intel's hype was further accelerated with unrealistic assumptions such as the one above. Remember, 14A is a 2027-2028 process with a mere 15% perf and 20% density gain.
cebri1
373
405
Clearly they are referring to the HD libraries as the performance targets and density targets are aligned to what was disclosed 2 years ago. But whatever.
DavidC1
2,199
3,358
No, they simply missed/lied.
The Intel 3 HP library is not "denser" but the same 240nm pitch as Intel 4. To get the mediocre 10% density, you need the slower HD library. I don't know how you can spin "denser HP library" as meaning anything other than this.
18A was supposed to be 15% + 10% over Intel 3. 20A was supposed to offer 15% by itself.
I remind you guys again 14A is a 2027-2028 process with 15% perf and 20% density gain.
Reactions: KompuKare
Josh128
Banned
Oct 14, 2022
1,542
2,297
How so?
I haven't heard that N3B has particularly poor yields after the delay. Maybe a little worse than TSMC's other nodes, but still good for production. It is a more expensive node though. The PPW advantage over N4P is pretty small.
So vs N4P, 3%-8% lower power, 1.64x density, -1 to +4% perf. Vs N4X, unknown power savings, unknown density, roughly equal perf? It is unknown whether Zen 5 uses N4P or N4X, and its said that Intel uses N3B, which is not shown here. Im sorry, but this is not enough information to declare with any degree of certainty that density is the only advantage ARL has over Zen 5.
jur
47
37
14A is supposedly still in development. Don't be surprised, if gains change. They only got their first high NA a couple of months ago.
DavidC1
2,199
3,358
Intel themselves said 10%, don't know where you are getting 20% from.
Also they said Intel 3 is a Foundry Node.
You want to give excuses for Intel? Fine, but that doesn't change them not meeting promises in their original 5N4Y presentation.
DavidC1
2,199
3,358
The base Intel 3 process node delivers up to 18% better performance at the same power for an entire processor core, a flexible set of metal interconnect options, and up to 10% greater density than the previous generation Intel 4 node (1).
Overpromising and underdelivering. Not what I expected 3 years ago when Intel brought in Patrick "Pat" Gelsinger, a lifetime Inteller and prodigy engineer as CEO.
Hitman928
6,758
12,506
Zen 5 uses N4P. From the process perspective, N3B’s only significant advantage is logic density.
jdubs03
1,512
1,098
So I took another look at the GB Browser and the U7 258V isn’t much behind the U9 288V in multithread. It’s scoring around 10800 vs 11000. I would’ve thought there’d be 288V would have a bigger gap.
trivik12
354
324
What was over promised? it was more about Iso performance back then.
Reactions: cebri1
Josh128
Banned
Oct 14, 2022
1,542
2,297
Well, 3-8% power efficiency is not insignificant when you are talking about ~250W power levels.
Also, while it is said that Lunar Lake uses the N3(B) node, where was it confirmed that Arrow Lake doesnt use N3P node? It seems counterintuitive that Intel would use a mobile class process for its high performance desktop chips, yet still manages to squeeze out 5.7GHz from that process at an acceptable power draw. It seems much more likely that Arrow Lake is using N3P than N3B, which is used for Lunar Lake with efficiency in mind.
