Page 47 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
uzzi38
2,747
6,657
It's a little off I think. ARL-S on 20A during H1 2024 is not realistic. Maybe they are just assuming it's 20A because roadmaps usually don't say what node it uses. Or they are mixing it up with MTL-S. 6+16 cancelled, means 6+8 could still come.
They misunderstood the roadmap, but based off of the other things they said I do genuinely think they have access to a roadmap.
19,218
Quoting from here: https://forums.anandtech.com/threads/zen4-3d-review-thread.2610878/post-40972537
What are these people going to say in a few generations when Intel goes full chiplet and relies on their interconnect designs to make it work.
Is there any evidence that they have an interconnect design that could match or even surpass what AMD has in Zen 4?
AMD had the advantage of having Bulldozer as such a bad design for its time that it was easier for them to adopt the chiplet strategy and start afresh. Intel is in the unenviable position of trying to outdo their pretty good Raptor Lake IPC with their first ever mainstream chiplet based design.
It's a monumental task for them to ensure that they manage better IPC while also offsetting the memory latency regression. RPL-R is just proof that they were wildly overconfident in their ability to overcome the challenges associated with moving to chiplet based architecture. Question is, is the time they will buy in the process going to be enough for them to meet, let alone beat, consumer as well as investor expectations?
I wish their internal Plan B document would get leaked, giving us some visibility into the possibility of a 2nd refresh of Raptor Lake (bigger package on a new socket, more cores, more cache, stock TDP 350W!) to buy time while they iron out the chiplet related performance issues.
Reactions: Hulk
A///
4,351
3,160
Only if someone has the gritty details about what they've deployed in their multi chip glued xeons. other than that nothing but what was brought up in their intel day a year or two ago. zen 4 won't be the competitor to intel's chiplets then. We're still a good 2-4 years away regardless of what intel says. AMD could be on zen 6 or 6x3d by then.
Geddagod
1,681
1,720
I fully expect Intel to not do anything different with their interconnect for if they ever end up going MCM for consumer, as in just mesh across tiles.
Intel's CPU architectures are quite literarily built for this- and the rumors point to them continuing this- massive ROBs and slower, but very big private and mid level caches compensating for higher latency L3.
Maybe the surprise would be Intel doing dual ringbus like they did way back when in server, but other than that ¯\_(ツ)_/¯
IntelUser2000
8,686
3,787
SquashBonic hint Meteor Lake might have nearly 0 ST perf changes at worst.
This is why Arrowlake is replacing Meteorlake at the high end. Even with 8+16 config(which isn't) essentially releasing Raptorlake again but with less power is going to do bad on desktop.
"Nearly 0 changes" sounds like the gain akin to Raptorlake. 1-3%.
@Hulk So regarding the timeline of Intel 4, SquashBonic says "this year in meme volumes" for Meteorlake. Likely that's mobile and desktop is firmly next year.
19,218
From what I can tell, MTL's saving grace might be close to RDNA3 iGPU performance (I'll assume 70% as close) and it's neural accelerator that might be fully compatible with the rumored AI features of Windows 12. Power consumption? Let's hope it's no worse than 12th gen mobile.
jpiniero
17,200
7,575
Intel is still projecting Single digit improvement over RPL-P and RPL-H in benchmarks, that "Zero percent ST improvement" part is for worst case scenario where Intel might miss their targets.
By targets you probably mean clock speed. Does seem like they'd be able to get away with mixing in Raptor rebrands if it comes to that.
BionicSquash
9
18
51
By targets, I meant Pre-si estimates over RPL-H that Intel published in internal docs for several benchmarks. You might not always Match Pre-si numbers with actual sample which is why I included the worst case scenario.
inf64
3,884
4,692
Do you know if MLID's IPC claims for Meteor Lake are true? He claimed 10-15% IPC improvement, which seems kind of high for a Golden Cove derivative.
jpiniero
17,200
7,575
They probally have a pretty good idea of what the IPC gains would be, right? It's mainly the clock speed that surely they have some doubts about.
A///
4,351
3,160
Targeting an IPC takes considerable work. Something we've seen AMD do over several generations. Today's tech allows both Intel and AMD to properly test a theory before comitting where such ability was limited a decade more ago and even further going back 20 years. Clock regression is always a serious issue but it can be tamed and often avoided.
For Intel what stands apart from them and AMD right now is their power use, anywhere from 40-110 watts more depending on the task. It'll be interesting if Intel can make some approach to this issue with the rpl refresh and later on with their outlook and new power delivery methods. That's a big if.
There's a lot riding on Gunslinger's neck over at Intel, but even so I'm interested in zen 5 next year. I've seen so much anticipation about and smoke blown up our cornholes that it's going to define the next gen of processor performance and Zen 4 was but a tiny stepping stone.
Reactions: lightmanek
