Page 458 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
jdubs03
1,471
1,048
I'm just hoping thats the case and a successor comes in 2027. There's a reason why Dell still had LNL in 2026 as an option for the preimum mobile SKU.
They could at least try a refresh for a little performance bump. Otherwise it’ll just get stale.
Their whole segmentation between LNL and PTL is needlessly complicated. I’m not sure why they couldn’t just be consistent with their product segmentation as they scale up the power levels. Hopefully NVL changes that.
DavidC1
2,154
3,293
So Intel you create an amazing x86 SOC with efficiency focused PMIC comparable to M1 but dump it next gen, wtf?
@DavidC1, you were right LNL currently does not have a true successor..
If it looks like a duck and quacks like a duck...
Now my prediction was based on the pessimistic viewpoint that they would have thought Lunarlake was enough to kill WoA advances so they can go back to being lazy and fat.
Except they cannot afford this. They shouldn't can E core Xeon line either. They should address all potential markets. Samsung can at least catch up properly, Intel doesn't even know how to be a fast follower.
Let's hope that's not the case, because if they don't change this mindset, I keep telling you, even if they survive this current debacle, their days are numbered.
Bionic_Squash:
It's ARL-U successor yes.It's got a 4 Xe core IGPU too
Oh you mean the "Arrowlake"-U with Redwood Cove on Intel 3 process? Pantherlake-U is the successor to THAT crap?
Other mega corps had MBA influence their engineering. Intel is basically a finance company with engineering as a side job.
5,408
4,819
I agree they should at least keep most of LNL in design for PTL-U PMIC and On Package Memory and SLC are the highlights of LNL that is akin to M series
Rouge River Forest is not cancelled according to Bionic Squash and One Raichu so no to this
Yeah i agree they need good designs for future
Reactions: DavidC1
DavidC1
2,154
3,293
They can't... or to phrase it more accurately, they don't want to, because it would cause them to spend few hundred million $ more they couldn't afford because of why? Terrible choice made to squeeze 0.1% margin and revenue over organically finding new markets.
Lunarlake successor needs a dedicated SoC design.
PTL is successor of LNL ,all u&h.
Don't change, keep being the way you are.
jdubs03
1,471
1,048
Why oh why does ARL-U not use LNC and Skymont? Hopefully PTL-U uses Cougar Cove and Darkmont.
dttprofessor
163
45
MTL 4 Tiles NOC(SOC)/BEOL(intel4) problem
LNL 2 Tiles no problem
PTL 3 Tiles no problem
Reactions: DavidC1
511
5,408
4,819
MTL 4 Tiles 3/4 Tiles including the biggest TSMC Intel 4 CPU
LNL 2 Tiles all TSMC
PTL-H 3 Tiles GPU TSMC CPU+NPU+Memory PHY 18A
PTL-U Intel 3 GPU + 18A Compute+NPU+Memory PHY+ N6 IO
not counting filler tiles
DavidC1
2,154
3,293
3 tile approach is a stupid idea for ultra low power chips. ARM vendors don't do this. Monolithic chips still has it's place, because you cannot beat laws of physics, you have to work around it, do your best job with it.
Two tiles on Lunarlake at least made sense, because IO really stopped benefitting from scaling a while ago, and you can get very low leakage dies easier on a mature process.
The GPU is on a separate tile on Pantherlake, which likely a big sacrifice in power terms. The GPU will have to go through another tile to get memory access. Because while Foveros is ok, but is still much slower and higher power than being on-die. How will a GPU over Foveros achieve low power state and have high bandwidth communication with the compute tile, where the memory is?
Latency is a problem in both achieving ultra low real world power and performance. Because if you want low-med active power to be low, you need to turn off clocks and power states in between activities, in the order of milliseconds. If the latency is too high, it simply can't stay in low power state as often.
Did you know that since back in the Pentium III era more than 20 years ago, CPUs were able to reach lower power states in between keystrokes? Latency is absolutely critical for power reasons.
Intel investigated 3D stacked dies publicly as early as the Netburst chips. It never became commercial because 3D stacking active dies immeasurably increases thermal density. So assuming even the IO die to be the interposer has a low chance. Unless they can 3D stack the IO die underneath all the compute dies, they should stick with minimum amount of tiles as possible.
5,408
4,819
The display/codec logic is on the 18A tile so it makes sense to seperate GPU Compute Entirely
Are we assuming Foveros is still on 36 micrometer pitch like MTL cause by panther lake it would have been improved very much
dttprofessor
163
45
STX is monolithic ,200+mm^(maybe 230?),4P+8C+NPU+890M, without 4 LPE & system cache, it's too big.
Reactions: 511
Gideon
2,044
5,103
My office PC is faster than that! https://www.intel.com/content/www/us/en/products/compare.html?productIds=75122,75469
Good to know that I'm enjoying better than fighter pilot CPU performance in the comfort of my workplace.
Warning, OT:
Maybe right now (but reality is of course more complicated). Besides they are also receiving upgrades.
The exact details are obviously kept tight under wraps but even just glancing at the upcoming F-35 Tech Refresh 3 hardware (Block 4) It's pretty clear these planes have all kinds of different accelerators on top of (and inside) the "Integrated Core processor" box:
This is also rather cryptic (by design) but I would guess the HW coming online in 2025 (wit the mentioned 37-increase). Even if it was, it probably won't be Haswell soon enough:
Integrated Core Processor
  • Multi-function processor for processing data for the aircrafts radar, distributed aperture system, electronic warfare, communications, guidance and control, cockpit and helmet displays
  • 37-fold increase in computing power for planned capability upgrades
  • The ICP system provides enhanced software stability, higher reliability and increased diagnostics resulting in decreased sustainment costs
Panoramic Cockpit Display
  • Electronic Unit Legacy capabilities increase five-fold with modern multi-core processors
  • Two independent safety critical display processors for left and right cockpit displays with redundancy
Aircraft Memory System
  • Delivers twenty times the storage of the legacy system enabling increased sensor data gathering capabilities to expand situational awareness
And considering the small Panoramic Cockpit Display box fits a multi-core processor (a GPU?) I somewhat doubt the large Integrated Core Processor box is onl a single "desktop class" MoBo / CPU. 37x uplift (from Haswell?) also strongly seems to suggest at a server CPU or a multi-CPU design.
There seem to be Separate CNI (communications) and EW racks on top of that.
There's a bit more info aboutthe separate EW rack in the upgrade kit notes:
40Px (former Lot 15) - Technical Refresh 3 (TR-3), Next Generation Distributed Aperture System (Next Gen DAS), Cooling Mod Phase 1 (orifices only), High Efficiency Low Voltage Power Supply (HE-LVPS), Electronic Warfare (EW) Rack 2 Integrated Backplane Architecture (IBA), Radio Frequency Converter (RFC), Electronic Warfare Controller (EWC) Firmware, and Fuel Conduit Mod.
1) ECP-1609 - TR3 - Integrates new Integrated Core Processor (ICP), Panoramic Cockpit Display (PCD), and Aircraft Memory System (AMS) to meet Block 4 processing, memory, and throughput requirements. 2) ECP-1610 - Next Gen DAS - Replaces current DAS due to sensor reliability, while increasing performance to provide larger pixel focal plane array and higher operating temperatures.
-Cooling Upgrade Phase 1 (orifices only) - Increases cooling capacity to support EW growth.
-HE-LVPS - Required for EW mods increased power requirements.
-Rack 2 (IBA), RFC - Replaces legacy EW racks to accommodate modernized EW modules.
3) ECP-1323 - Fuel Conduit Mod - Enable alternate wire routing for Block 4 upgrades for Pre-Lot 15 Aircraft to eliminate the need to route wiring through the dead zone and accommodates future wiring needs.
Oh, and these ICPs also seem to also be duplicated for redundancy (at least one F-35C managed to land in 2012 even with 2of these stopped working)
How? There is a totally separate triple-redundant VMC (Vehicle Management Computer) that keeps the plane airborne even if all the ICPs crash:
So a lot of public domain info on the subject if one knows where to look.
And as proven above f-16.net forum is really good for that kind of info.
TL;DR:
There is more like a server rack worth of different computing devices in 5-th gen fighters, rather than a single CPU / MOBO
19,210
TL;DR:
They must be using a realtime OS. Is it QNX or a heavily modified variant? How does one handle multiple cores in realtime? The communication latency needs to be really, really low between the cores to ensure quick response times.
19,210
It seems both MSI and Acer will have Lunar Lake based handheld
Steam Deck better come out with a power optimized Zen 5 or Lunar Lake could destroy its sales!
Or maybe they will decide to give options to consumers. Steam Deck Ryzen Aye Aye edition and Steam Deck Looney Lake edition :p
mikk
4,333
2,413
Maximum turbo power will be 37W on Lunar Lake. Of course this is a theoretical maximum as always, but it's a lot lower than on MTL-U with up to 57W. This is good.
Reactions: SiliconFly
OriAr
