Page 456 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Philste
308
486
Ah yes my bad. Seems like that’s a focus on ST and battery life. MT isn’t getting much of a bump there.
Focus is more on building a CPU that actually is suitable for 500-800$ devices and still makes money. Lunar Lake is basically "we've thrown it all in to let the world see we are not dead". But they can't sell RPL in these lowend devices forever.
Magio
206
243
It is gonna be cheaper than LNL while performing slightly better I don't see it as a bust
Lower GPU performance and no on package memory for efficiency and a return to PL2s that have no place on a thin and light chip makes it a super disappointing "upgrade" from LNL IMO.
It might perform measurably better in certain ways, if PTC/Darkmont are decent upgrades and 18A delivers, but that just makes it all the more disappointing we're not getting a PTL-V which leverages those improvements but keeps the great stuff from LNL and has enough GPU cores to let Celestial stretch its legs.
Reactions: DavidC1
Philste
308
486
These PL2s are really weird. PTL-U looks bad, PTL-P/H looks amazing with 64W upper limit for 16 cores and a 1536 ALU iGPU.
Reactions: DavidC1
ondma
3,320
1,709
That’s one reason why if this is all true, it’s such a disappointment. On the order of 10+ years of work has been spent on this concept. To me I cannot believe that Gelsinger would be so short-sighted and waste all that effort. Particularly since the concept was in such an advanced stage. If they’re not integrating this tech into Nova Lake and its successors, then tbh they deserve to lose further market share to AMD.
It is even more disappointing because Intel desperately need a new P core. They seem to be stuck to 15% or so improvements per generation, and they are still big and power hungry. Even then, 15% would not be bad if they could maintain or increase clock speed, but ARL will have a clock speed drop that cuts into the IPC gain. (And no, I dont believe the posters on here who still stubbornly insist desktop LC is going to somehow have a 20%+ IPC increase. I hope I am wrong, but the more leaks that come out, the more it looks like a marginal improvement in both final 1T and nT performance.)
511
5,411
4,833
4 Xe3 Celestial iGPU vs 8 Xe2 battlemage GPU i think it is going to match or will be slightly behind LNL iGPU kind of same with 11thgen/12th gen 96EU graphics vs 4 Xe-LPG (64EU)
Yeah I agree they just need to have stringent rules for Design
Philste
308
486
Hm I don't think so. That would mean Intel would do another big jump in their graphics arch within one year. Don't forget PTL taped out already, so Celestial IP is already completely done. RDNA3 was barely 20% higher "IPC" than RDNA2 and Ada is basically Ampere from a pure Architecture standpoint, just way more resources on a far better node. I don't think Intel can reach 8 Xe² Cores with 4 Xe³ Cores. At least as long as the clocks stay roughly in the 2 GHz region.
Magio
206
243
Imho, 18A will deliver on performance for sure. But I don't think it's gonna deliver when it comes volume due to capacity constraints (at least in 2025).
Also, isn't PTL-U 4P+4LPE a good enough replacement for LNL? It appears it can comfortably replace LNL given its power envelope.
In pure CPU performance (ST and MT) it will most likely be an improvement over LNL but it just does not seem as cutting edge a chip overall and doesn't have the same razor sharp focus on efficiency. I also really don't believe 4 Xe³ will match 8 Xe², that can happen
For PTL-U's limited appeal I always go back to Dell's leaked roadmap: The XPS 16 and 14 will get PTL-H/P refreshes in late 2025/early 2026, but the XPS 13 refresh is only slated to get LNL and Oryon V2 variants. Of course plans can change, but Dell knew enough about PTL to know they'd ship the H and P variants and yet they weren't planning a PTL-U SKU in their flagship line.
Reactions: DavidC1
DavidC1
2,155
3,297
I don't follow GPUs much, but I remember reading the no of EUs in a Alchemist Xe core is different from the no of EUs in a Battlemage Xe core. It's like 1:2 or 2:1 or something. Likewise, Celestial can be different from Battlemage. If true, Intel can reach the performance of 8 Xe² Cores with just 4 Xe³ Cores plus a little extra due to a generation leap. Just speculating.
You got that wrong. Xe core is the basis to use because you can have less EUs but same Xe cores.
32 Xe = 512EUs
32 Xe2 = 256EUs
Xe cores are comparable to Xe2 cores with the same FLOP rating. EUs are not comparable.
So no, you can't have Xe3 outperforming Xe2 by using the same metric. The improvements will have to come elsewhere.
Exactly. Very skeptical on PTL-U until otherwise. It increases tile counts, the PL2 TDP is ridiculous, on-package memory is an afterthought rather than being optimized like in Lunarlake.
Intel views Lunarlake as enough to kill current WoA wave, so they can go right back to coasting.
Actually 15% every 2 years. How will the P cores in Pantherlake get 10% improvement is beyond me.
What personal attack? I was just stating the facts. There is no way you can know more about why Pat canceled any project then he does himself. Your answer is just that he is a "dmiwit". OK. maybe, maybe not.
Thumbs up. Sometimes people need to be told that they are flat out wrong. Otherwise it's just censorship.
Scientific and other progress RELIES on disagreements, no matter how outlandish it may sound to others to come to the truth, the right conclusion. Having a society filled with snowflakes is contrary to that goal.
Thunder 57
4,250
7,049
An important note:
The final AT post says new forum registrations are closed. So, no more new members. :'(
And the most worrying point is it says it's paid up for 3 more months. After that they may abruptly pull the plug.
We have to start looking for equally good or better alternatives. There isn't much time.
I read that as for the main site. It looks like you can still register in the forums. Also I think Dr. Cutress said it was paid through April, but I may be wrong. Either way, we should be planning for a future without AT forums. The question is when.
jdubs03
1,472
1,049
Should we all move en masse to the desired promise land? Who has the best forums? Techpowerup?
Markfw
May 16, 2002
27,396
16,237
I will be moving to techpowerup if AT forums close
I know this is sort of off-topic, but does techpowerup have forums that remotely resemble these in functionality and people ?
Markfw
May 16, 2002
27,396
16,237
Simply put, no.
Yea I registered and posted one reply. Then I got an email that I had posted, and the reply was nice, but I get the feeling there is a real lack of knowledge there. I tried it because poke01 said he was going there when these close, but damn, no comparison.
Thunder 57
4,250
7,049
Yea, wow. They don't have a CPU forum? Just "General Hardware"? Their forums look like a worse version of Tom's and doesn't even have a CPU section? And the posts are very much like I see on Tom's where it's newbies asking basic troubleshooting questions. I will not be going there.
Sharkyforums is technically still there, just an absolute ghost town. I'd sooner suggest all AT people join there and revive it.
Hitman928
6,753
12,492
I have accounts at overclockers.com, Tom’s, and overclockers.uk but only post at the first one with any frequency. It’s not very busy but it’s a good core group.
Reactions: Elfear
poke01
4,811
6,140
Yeah TPU forums is nothing compared to here but it’s something. I kinda don’t want this community to disappear.
It does get lively around CPU and GPU launches particularly in the review comment section but yeah it’s the next best site after Anandtech imo.
Reactions: 511
Markfw
May 16, 2002
27,396
16,237
Well, they deleted my 3 post which simply said read post number 2, which the guy didn't. Cross them off my list permanently.
Reactions: Thunder 57
