Page 446 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Hulk
4,068
The more I think about that LL 10k CB R23 MT score the more confused I am.
Assuming 4.5/3.5 clocks and Lion Cove performs 5% better than Raptor Cove in this bench, and Skymont perform performs 5% worse than Raptor Cove then the resulting score should be nearly 15k.
Either Intel's entire LL presentation, all of the engineer talks, the slides, all of it, was gaslighting, or that leak is faulty.
We shall know soon enough!
Reactions: IEC
DavidC1
2,166
3,307
They are early tests, user submitted tests, plus very power limited, which is what MT is.
You'll get decent ST performance approximations but not for MT. There's no way 4 Lion Cove cores alone will clock at 4.5GHz and fit at 17W, nevermind 4 Skymont on top of it. Even at 30W it'll be a challenge for 4P @ 4.5GHz.
30W package power means 25W for core which means each core has only 6.25W available to it. What can Lion Cove do at 6.25W? What can Golden Cove do at 6.25W?
Here's for comparison Meteorlake:
30W: 10,000
17W: ~6,500
The 125H requires ~70W to reach not even 15K. Even the 7840HS requires 50W.
If the Xitter leak is true where performance increases at 30W is not much then Lunarlake has a steeper V/F curve where it is even more optimized for lower frequency efficiency.
@majord Ok. So AMD must have followed Intel and did opposite on the later chips to favor high frequency.
Lunarlake is still about leadership battery life. It has everything a regular user requires. High ST performance for responsiveness, great graphics, good battery life, and potentially small form factor.
Reactions: luro and 511
DavidC1
2,166
3,307
Something little different.
@Abwx commonly makes the argument that since frequency and power relationship is cube root squared, that's how the power and frequency graphs should always follow.
This is NOT the case. Every design has an optimal operating frequency. You'll know if you played extensively with V/F graphs, usually easiest when done with GPUs.
I have. The Polaris clocks are nearly at the floor at 0.6V. Sure, 0.6V would require less power than 0.7V, but that 100mV increase means suddenly your max clocks can go from 300MHz to 600MHz.
And on the peak, you can undervolt it to 950mV and have the GPU clock at more than 2GHz. So there's a linear portion of the graph and exponential portion of the graph in regards to frequency. On the exponential part of the graph you can give just 5% extra voltage and have it clock 10, 20, or even 30% higher in clocks!
So rather than 1.3x clocks being 1.3x1.3x1.3x or 2.2x in power, it's 1.3x1.05x1.05 or just a 43% increase in power, likely less than that because there's static power contribution and voltages are just about active power. Static power contribution is not negligible. It is in the order of 10-20%.
Abwx
12,004
4,968
I never said cube root squared but around 2.36 - 2.56 root squared for usual TSMC s processes, for LNL it is :
CB score ratio = 10200/8200 = 1.244
Power ratio is 28/15 = 1.87
P/f evolution exponent is hence ln(1.87)/ln(1.244) = 2.867
So that yield P(f) = f^2.867 and conversly F(p) = P^(1/2.867)
So more precisely 2.867 root squared in this TDP range, wich is signifcantly more than previous TSMC s processes, and indeed close to a cubic root, but that s an exception so far, and so much that it s unlikely that it s due to the process but rather to the hybrid uarch that is not optimal if the e and P cores V/f curves are significantly different, or eventually that at 17W there s a turbo at work wich is not present at 30W.
DavidC1
2,166
3,307
The problem with your analysis is the same AMD/Intel makes in their presentations, which is being oddly accurate like claiming "17%" gains. In the sane days we used to call it 15-20%.
You are assuming the early platform is completely representative of the final product, and the testing is done in a perfect environment. That few % will skew the numbers to say one is winning over the other since we're arguing about mere single digit percentages.
The natural variation present in user-submitted tests, in a prototype platform, from one tester, likely time constrained at that too, and with limited information presented to us, and on a laptop no less will render it no more than a case of "oh that's interesting" and a reference point than "This is how the product performs".
Abwx
12,004
4,968
There are another leaked number to substantiate LNL perfs at 30W.
ARL s 8 + 16 score 43118 pts at 250W and 5.4 + 4.6 frequencies.
A 4 + 8 would score around 21600 at 125W and same frequencies.
A 2 + 4 would score 10800 at 62.5W., also at 5.4 + 4.6.
With 33 % more cores, and hence 1.33x lower frequency, you can get those 10800 pts at 1.33^2.8 = 2.22x lower power or only 2x if the exponent is less than 2.8.
So that makes 62.5/2.22 = 28W for 10800 pts or eventually 62.5/2 = 31W, the little 600 pts difference is due to the uncore that wont scale exactly as much as the core powers or to anything else, but you ll admit than using two different designs we end standing on the same feet.
majord
509
711
30W: 10,000
17W: ~6,500
Yeah I'm not sure what is going on with that 7840HS dropping off, but as alluded to, perhaps the VF curve is whack at lower TDPs. Check U series performs far better at that 15-17w .
Re Leadership in battery life, well that is always welcome, but I'm not sure how relevant it will be in actual devices outside perhaps pure idle time. Assuming it can dip down to Snapdragon levels of idle power.
At the end of the day the device has a far bigger bearing on actual life when talking about laptops with any of the modern SoCs. Any advantage in idle and light use consumption can get completely smeared away by power hungry OLEDs , and poor consumption of other peripherals. Therefore It's hard to sell an SoC on that alone when it's assessed as part of a device
Reactions: Hitman928
511
5,429
4,845
I hope they rework Intel EVO spec for LNL EVO was a nice idea but not well executed
DavidC1
2,166
3,307
It is inaccurate to say Lunarlake is a 15W chip + 2W DRAM. DRAM peak is harder to utilize in real world applications than the chip, thus it's basically "cheating" to eek out more performance by using slight bit of extra headroom.
My Kabylake Yoga uses 0.7W in average for the DRAM. It goes as low as 0.5W. So if 17W LNL uses 0.5W in average for the DRAM, the CPU is using 16.5W.
Any advantage in idle and light use consumption can get completely smeared away by power hungry OLEDs , and poor consumption of other peripherals. Therefore It's hard to sell an SoC on that alone when it's assessed as part of a device.
Icelake has great idle power use. Very low. The problem is it sucks on web browsing and video playback, so any load makes the low idle useless. The x86 platforms have a problem in both low idle and/or keeping it low.
Luckily the demos they have been doing is in load scenarios as well. 40% reduction in teams, 40% reduction in video playback and frame-rate capped gaming. Interestingly, they quote that 40% number for memory PHY power reduction.
Lunarlake using similar power doing local video playback as Meteorlake on idle.
5,429
4,845
This 17W is total distributed power budget among CPU+GPU+NPU+RAM+Uncore
DavidC1
2,166
3,307
It don't matter. Uncore and RAM can't go to zero, but the rest can be power gated and essentially be zero, thus CPU/GPU can use all of it. 2W for Lunarlake is misleading. It'll need something like a memory power virus.
Anyways, just had to restart the WMI service on my Kabylake Yoga to get package power down by 0.5W. 10-15% battery life impact thanks to one service.
Thanks Microsoft!!
511
5,429
4,845
Yeah 2W is misleading unless you run prime95
Thanks Microsoft!!
I am with you on this one i had i5-8250U for like 3.5 years was very nice but Microsoft services are amazing at screwing modern hardware looks at modern standby
Magio
207
243
Is this actually in mW? 1.4W package power for 4k30 AV1 sounds quite impressively low to me, but then again 14W would be wayyy too high.
There's this video where they demo LNL in this exact scenario and total system power (with screen off) is 5/6W, that seems higher than what I'd expect if the package power on its own was 1.4W.
511
5,429
4,845
Found it here they could have made improvements considering 3-4 months from launch
Magio
207
243
Ah, hadn't seen that video ! 2.5/3W package power on VVC does make AV1 at 1.4W seem plausible !
Do hope we'll see laptops that do a better job keeping system power in check than in that AV1 demo.
511
5,429
4,845
Ain't no way it can do 4.5 ghz P and 3.5 E All core
Hulk
4,068
I agree those frequencies are optimistic for mobile.
Probably more like 4/3, right?
4/3 with Lion Cove doing 5% better than Raptor and Skymont 5% less than Raptor (in CB R23) would show a score of about 13,500.
Reactions: 511
DavidC1
2,166
3,307
Hulk, Meteorlake gets 6.5K at 17W. You are being way too optimistic here. 15K using 70W. It requires 30W to get 10K. And 125H is a 4+8 part with Hyperthreading meaning it should require less clocks to reach the same performance.
Skymont should do better on lower frequencies but It should be in the low 3GHz frequency for both cores. Maybe even high 2GHz for E.
It is. The web browsing power for Meteorlake is not too dissimilar for my Kabylake system.
I would never get an OLED and resolution beyond FHD for my system. Battery life impact is forever, while the Wow! factor from a screen lasts at most a month.
Reactions: Hulk
DavidC1
2,166
3,307
Intel summary:
->20% MT perf with lower core count
->20% ST performance, or same performance as MTL at 1/2 the power
-More than twice the performance per watt in productivity(?)
-LNL reduces SoC power by 40%
Interesting bit:
Intel says removing Hyper-Threading helped them get more efficient at low power.
DavidC1
2,166
3,307
Doesn't Wi-Fi 7 take a few watts of power on its own?
5-6W with screen off isn't particularly efficient. If WiFi 7 takes that much power I don't think it's worth it. Based on those numbers alone it's no advancement at all from my Kabylake on the power front. But Meteorlake system shows nearly double so we'll see.
