Page 427 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
925
841
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
DavidC1
2,023
3,161
Pretty sure they use 64-bit bus, which with LPDDR is akin to "dual-channel". Wildcat Lake will probably use LPDDR only. So I guess it's fine in that sense.
64-bit is single channel by PC terminology, and especially since we're talking about bandwidth.
If they went 64x1-bit are we going to call it 64-channels?
Reactions: 511 and FlameTail
511
5,156
4,620
80 channels with the ECC on DDR5
Wolverine2349
525
179
86
Given how underwhelming Ryzen 9000 uplift over Ryzen 7000 in all but AVX512 workloads and some server tasks and Linux stuff, is it safe to say Arrow Lake will handily beat Ryzen. 9000.
And is Ryzen 9000 uplift underwhelming because AMD does not know how to do 6 wide decoder properly? They seemed better with a 4 wide decoder and knew how to do it well with excellent branch prediction.
Reactions: exitorious
MS_AT
913
1,833
AMD doesn't have 6 wide decoder. Each SMT thread gets a 4 wide decoder. If only 1 T is active it's still 4 wide decoder.
Wolverine2349
525
179
86
Oh ok interesting. I remember all the talk that Zen 5 AMD was finally going to go 6 wide. Why did they not. Maybe that is part of the problem?
511
5,156
4,620
Skymont has 2X Vector Uplift as well so i guess ARL will give Zen 5 a run for it's money in Linux as well vector ports is increased by 33% on LNC and 100% in SKT based on the the ports alone ARL should have decent FP as well
Wolverine2349
525
179
86
Would it beat 7800X3D in most or all games and blow out Zen 5 vanilla in gaming?
And since vanilla Zen 5 is underwhelming improvement in gaming over vanilla Zen 4, I think Zen 5 3D will probably not be much better than 7800X3D Zen 4?
exitorious
19
I don't see how Zen 5 3D can really be any better. The current x3d chips were based off the 7000 series and the 9000 series isn't any faster than the 7000 series in games so where would any kind of performance uplift come from?
inf64
3,884
4,692
That is not true. 9950X is 8% faster than 7950X:
Couple with improvements that AMD will bring with 9000 series X3D chips (probably higher clocks), I can see 10 to 15% better performance vs 7800X3D with 9800X3D
Reactions: Racan
exitorious
19
Depends on whos review you believe I suppose: https://www.techpowerup.com/review/amd-ryzen-9-9950x/18.html
H433x0n
1,224
1,606
Huge opportunity for Intel. If ARL-S manages +10% 1T and +20% nT they’ll have the general performance lead for this generation.
Unfortunately it’ll probably end up being +5% 1T and +15% 1T and be basically tied against Zen 5 and launch to a flurry of negative reviews and x86 doomer talk.
Reactions: Tlh97 and reb0rn
MS_AT
913
1,833
Unlikely. LNC has a massive 14% IPC uplift. ARL-S final should have close to ~10% perf uplift. And coupled with 16 skymont E cores, MT should be impressive too. This year, ARL-S top sku should easily match or slightly outperform the top X3D part.
IPC alone at this level will not beat memory latency;) Zen5 is the proof enough;) [Zen4 matched Zen3x3d, with 13% IPC bump, 12% frequency bump if not more] So while ARL-S might top the charts, in games where x3d leads now thanks to bigger cache, it will keep the lead.
cebri1
373
405
I'll give Intel props if they can get +10% 1T and +20% MT. Maybe even buy the inevitable 2025 refresh. But I will not be holding back from x86 doomer talk.
Zen 6 is next year, or another 22 months? If the latter I will join the doomer club. Unless Lunar Lake+BMG turn to be amazing.
gdansk
4,691
7,930
Lunar Lake has the potential to be installed in compelling portable devices. But I'm skeptical it will beat even M3.
Zen 6 is not 2025.
Reactions: Tlh97 and cebri1
poke01
4,628
5,942
