Page 397 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
858
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
dullard
26,196
4,869
You're really splitting hairs over .5% ST and 4% MT? The "actual data" was the same leaked slide we both saw last year and some warnings form leakers showing numbers from an ES2. I'm just repeating an oft-repeated summary of that slide (yes, MANY PEOPLE QUOTED THE 5%/20% NUMBERS), and your own guesstimations are insignificantly different. Nobody gives a darn about a delta of +.5% ST and -4% MT from a summary of a slide from last year. Nobody. You're arguing just to argue, stop.
Clearly, you didn't read my post. You were the one complaining that the leaked slide last year was optimistic, when in fact, it was about the exact same ST and MT gains as what we just saw in leaked results. If nobody cares, then why did you post that the leaked slide was optimistic? I fully agree that it is splitting hairs, thus you should edit or delete your post that the leaked slide was optimistic--because it wasn't optimistic.
Oh and, this is a free space. I stop posting when I want to stop posting. Not just because you were called out for being contradictory and can't stand to hear about it.
Reactions: controlflow
dullard
26,196
4,869
I'm a little unclear on something regarding that tweet.
So the 4.7/4.0 clocks were with PL1 & PL2 = 250W? If so, do we really expect the retail clocks to be much higher? 250W is already rather high.
A lot of the changes between engineering samples and production chips is that they have a chance to tweak areas with unwanted power leaks.
Plus what others have said. PL1 and PL2 are maximums for given time periods -- not the power that was actually used. The power actually used depends on the specific benchmark and specific cooling installed. CPUs only use 250W or more for any meaningful length of time when attached to a cooling system that can handle 250W or more.
Josh128
Banned
Oct 14, 2022
1,542
2,295
Unless something has gone horribly wrong, expectations for ARL-S should be approx 5.6-5.8 GHz ST boost clock, based on TSMCs current frequency ceiling (yes, N3 may be different than N5P/N4, but I doubt by much), +14% IPC (based on Lunar Lake presentation). So, + 11.5%- 14% absolute perf in ST vs 13900K, a few % less as you go up the stack to 14900KS.
MT should be really, really good based on Skymont gains + 3nm TSM process. Depending on what kind of true power limits it has, 48K-50K in performance mode in R23 is probably a safe, realistic expectation. Zen 5 9950X, on the other hand, appears that it will top out at 44K-45K range when given full PBO 230W PPT.
Reactions: buttersdeif
dullard
26,196
4,869
2 months past october, the usual month. Not that crazy
Other than Coffee Lake, Raptor Lake, and their respective refreshes, what chips did Intel launch in October? I'm just asking what makes a "usual month" to you.
dullard
26,196
4,869
Exactly that ☝️
I ask since Sky Lake, Kaby Lake, and Comet Lake were all launched in August. While Haswell, Haswell Refresh, and Broadwell were all launched in June. Nahalem and Alder Lake in November. Then there are recent launches in April (Ivy Bridge), March (Rocket Lake), and December (Meteor Lake). That is, there isn't much of a pattern.
That said, I do think October is the goal.
Reactions: SteinFG
cebri1
373
405
Alder Lake was launched in early November, Raptor Lake and Refresh were in October. So three consecutive generations in early Q3.
ondma
3,321
1,713
Well, now it’s clear that @jaykihn0’s +3% ST perf projection was completely off the mark.
If LNC has +3% ST perf at a meager 4.7GHz (that too an ES), >20% ST perf uplift is definitely within the realm of possibility for the top end sku like I mentioned before.
Look at post 9897. That contains the latest info from that poster. He says that his chip was "unlocked", so not restrained to ES2 speeds (i.e. 4.7 ghz). However he says he had no way to verify the actual frequency, so a very sketchy post overall. I would not be excited, but IMO anything 10% or over is good for ST performance uplift. 20% or higher is definitely a pipe dream. Anything 5% or less like the leaks are suggesting, though, is a disaster.
majord
509
711
IF I was forced to make a bet, Id say it will top out at 5.2 to 5.3ghz , but I think theres too many small variables still. One thing seems almost certain , that SC perf increase will be less than IPC / perf/clock increase , so a freq regression seems inevitable . It also makes sense given the transition to TSMC
Josh128
Banned
Oct 14, 2022
1,542
2,295
No way man. Desktop on 3nm TSM should clock every bit as good as 5/4nm TSM. Surely its not hitting 6.2, but I'd put big money that its likely to clock right up there with Zen 4 and 5. 5.6-5.7 for sure, and maybe more.
Goop_reformed
316
341
5.6-5.7ghz for a core that wide? Doesn't bode well for power consumption
H433x0n
1,224
1,606
It is much wider than zen 5 and zen 5 is not particularly wide at all. Golden Cove family of cores are even wider and look at how many problems they have.
Unless you have inside information you can’t possibly know that since we don’t know Zen 5 core resources other than surface information such as it being a 4x2 decode, which is the same width as Lion Cove.
Goop_reformed
316
341
Let me put it this way. Intel cores are bloated, and are getting bloated. The trend continues for the foreseeable future
Reactions: Tlh97 and DavidC1
DavidC1
2,187
3,340
Cool, can you share the details of Zen 5’s ROB, uOP cache, ALU count, register file size, etc?
You know David Huang says it cut uOP cache sizes to Zen 3 levels and even PRF sizes right? Hence the 16% gains despite big changes elsewhere.
Totally agree on this one. They will be replaced.
