Page 242 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
I am expecting upcoming NovaLake - H with LPDDR6 support will include big iGPU like Halo. Panther Lake already has 12XE GPU, thus NVL-H should have 20XE, ie 320EU.....sound familar?
That is so late damn...just asking since alternatives or competitive products would still be good for the market
20 Xe cores in 2027 is not big. Big would be 40 or 50 Xe cores.
Arrow - Early 2025
Panther - Early 2026
Nova - Early 2027
8 Xe cores = 16 CU
20 Xe cores = 40 CU
Yay, 2027 Intel iGPU rivals soon-to-be released Strix Halo. It's 3 years from now. Somebody remind us what was available in early 2021?
Nova Lake is 2026?
Also why TSMC N2, if they have better IFS nodes?
Because MLID? :tearsofjoy:
Arrow - Early 2025
Nova - Early 2027
8 Xe cores = 16 CU
20 Xe cores = 40 CU
Clearly you have no ideas about memory bandwidth. FYI, upcoming Battlemage GPU comes with 32 Xe cores and 256-bit 20Gbps GDDR6 memory, ie 640GB/s BW. Even with LPDDR6, 128-bit only translate into 205 GB/s, one third of the GDDR6, 20 Xe cores actually sounds generous cause I am counting ADM to help with memory limitation.
And don't you know Intel is always late to party? 🙄 Panther Lake with similar specs to Strix Point is one and half year later, go figure...
Just like ARL-S is using N3B not 18A, you have so much to know about IFS late
Nobody has ever said ARL will use 18A. Gelsinger recently said again that ARL will use 20A.
Here is a reference: https://www.tweaktown.com/news/95818/intels-arrow-lake-cpus-on-target-for-2024-launch-ceo-asserts-with-massive-ai-gains-in-tow/index.html
Edit: somehow the link may not work, it doesnt for me. In any case, the article is recent, and Gelsinger specifically says about halfway through the article that ARL is "our lead 20A vehicle".
ARL compute tile will use 20A on some SKUs, but most of the volume will be on TSMC's N3B according to rumors + leaked document.
What do you think about these RaptorLake-S 257mm2 and 26 billion transistors?
Never ever. That would be above Intel 7s HD Density, and Intel is known to use low density Designs. Sapphire Rapids is 11B transistors per 400mm^2 if I remember correctly.
Totally understand, just seems like a waste of an EUV node to be using it on cache. That is, unless Intel 7 just can't accommodate TSVs, which I would find surprising.
The base is cache + interconnect network + voltage regulators, not just cache.
Intel said that they are trying to use the most advanced node for each component that doesn't go past the point of diminishing returns. That is, their best node for the cores will be 18A. Their best node for their base is Intel 3 (Intel 20A and 18A did not give much added performance for those components). The I/O will be on Intel 7 (not even Intel 4) as I/O just doesn't gain much from smaller nodes.
One could argue the exact point where the point of diminishing returns is located, but Intel seems to think they have something to gain at Intel 3 for the base. It might also be based on the fact that they are trying to increase production of Intel 3 and have very few products using it yet. If the lines are sometimes empty, might as well run them even if the gains are not too much.
As for adding the TSV technology to Intel 7, it seems like a lot to do for little to no gain on an aging node.
I found this entry on Twitter:
"Some news for Sapphire Rapids from ISSCC: According to Nevine Nassif, Principal Engineer for Sapphire Rapids at Intel, the die size is a little lower than 400 mm² and the transistor count is between 11 and 12 billion."
What the heck are you on man?
It takes 8 Xe cores to compete with 12 CU(I got the 16CU wrong). AMD will have 40 CU Strix Halo soon.
Therefore, 20 Xe cores = 30 CU. Tell me that AMD won't increase mainstream iGPU from 12 in 2027? 20 Xe in 2027 is not a big deal, when AMD will have 26 Xe equivalent very soon.
Yea, a 60%+ density for SRAM.
Intel is only scaling great on cache because TSMC is far ahead for SRAM and they hit limitations earlier, just like the reason DRAM is on 1xnm process forever is because they are fraction of SRAM(I mean like 20-30x difference) and hit limitations way earlier.
We'll see how Intel does on 18A.
So "rumors" and "leaked documents" (when and by whom?) are more reliable that what Gelsinger says? Honestly, they may be, but personally, I am not convinced by either the rumors or what Gelsinger says. We will have to just wait and see. I will be a very bad look for Intel's foundry business if the bulk of ARL is on TSMC silicon though.
See above link, yeah it is from Taiwan news. Western news pretty soon will pick up...
It'll only look bad for a short time.
PantherLake with similar specs to Strix Point is one and half year later, go figure...
Another thing, I never alluded to Pantherlake beating Strix(although I believe it will), which should have been clear by "2027" remark but apparently your bias blinds you, since most points I made were about 20 Xe not being a "big deal".
You can't simply compare Xe1 with Xe2 and Xe3 and assume nothing will change. And who says Nova Lake gets 20 Xe cores, this is just a guess from someone. Strix Halo might be irrelevant for mobile, better wait and see. If this thing costs 3k up and comes with dGPU and tiny volume who cares. Strix Point is what really matters for mobile.
Strix Halo is a 256 bit part. Its a completely different beast.
20 Xe core part most likely still will be 128 bit, same as that 12 Xe core part.
Thats the first thing.
Secondly they will be different architecture - Battlemage, instead of Alchemist. The performance/core will change.
Im willing to say that Intel will catch up to AMD with perf/ALU. At least to AMD.
Their graphics engineers/architects are under a lot more pressure to perform to keep their jobs.
Their CPU division is full of fat, lazy slobs who haven't faced any repercussions so far (that we know of) after the release of RPL-R and Crater Lake.
Nova Lake should have a Celestial iGPU at the very least given that Panther Lake seems to get Xe3 and comes 1 year earlier.
