Page 243 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
Oh no. Desktop ARL iGPU gets shafted. AGAIN!
Oh well. Looks like Intel wants AMD to continue their desktop APU superiority.
You can't simply compare Xe1 with Xe2 and Xe3 and assume nothing will change. And who says Nova Lake gets 20 Xe cores, this is just a guess from someone. Strix Halo might be irrelevant for mobile, better wait and see. If this thing costs 3k up and comes with dGPU and tiny volume who cares. Strix Point is what really matters for mobile.
Strix Halo is a 256 bit part. Its a completely different beast.
20 Xe core part most likely still will be 128 bit, same as that 12 Xe core part.
Thats the first thing.
Secondly they will be different architecture - Battlemage, instead of Alchemist. The performance/core will change.
Im willing to say that Intel will catch up to AMD with perf/ALU. At least to AMD.
Were you guys paying attention to what Tigerick has been saying? My reply has been to that. He said it'll be 20 Xe cores, and mentioned something like being a big iGPU, when my retort was that 20 Xe in 2027 is not big at all. It's like being impressed with news saying "Meteorlake has 128EUs!" back in 2021, when we'd eventually find out Meteorlake performs like AMD's iGPU but a year later!
AMD will have 16 CUs in Strix point. They'll have something similar for mainstream to equal 20 Xe(~26 CUs) in 2027, if not better. History does not favor Intel iGPUs.
Xe3 on Panther Lake sounds a bit unlikely if you ask me. It's difficult for them to come out with a new gen igpu in a short span of just 12 months. Doesn't sound like Intel at all.
For example, ARL is coming out with Xe+ or Xe++ this year end. That'd be roughly 3 years since Xe launch. Not very inspiring.
Yes, but Lunarlake is Xe2.
Also, Pantherlake should be a year after Arrowlake, or late 2025/early 2026. That's nearly 24 month away.
Who cares on the desktop?
Let them keep trying. Eventually, a good iGPU will be born.
ARL compute tile will use 20A on some SKUs, but most of the volume will be on TSMC's N3B according to rumors + leaked document.
N3 for Arrow Lake & N3B for Lunar Lake
Enemies of heat, noise, power cables sticking out and going into the discrete GPU, melting connectors etc.
I will give you a serious answer. For non gaming uses, pretty much any recent integrated solution is sufficient. For gaming, they are a limited low end solution. A better igpu may be of some benefit, but they would not be the determining factor if I were purchasing a new cpu. We have been hearing since the days of "Fusion is the future" how APUs are going to be the next great thing. Still waiting.
There is no N3.
Better than a low end card like RX 6400 or Geforce 1650: https://forums.anandtech.com/threads/amd-8700g-igpu-is-pretty-good.2617243/post-41163075
APUs have come a long way and only thanks to AMD.
But at best, nearly equal to, and in most cases, significantly slower than my ancient 1060 6GB, extrapolating from the 6500XT comparison on Techspot. In any case, I didnt mean to derail this Inte cpul thread with discussion of graphics performance of an AMD cpu, so I will end the conversation.
It is big, 20 Xe cores is 2560 ALUs.
Its the same number of ALUs as RX 6700 XT. For mainstream SOCs - it will still be apropriate.
Number of ALUs or Xe doesn't tell you much without knowing the clockspeed.
Then you also need to feed It, that looks like the biggest problem in my opinion.
Case in point: Adreno GPU in 8G3, which is a smartphone SoC, has 1792 ALUs (!), which is more than even some dGPUs I believe?
Please stop comparing apples to oranges.
MTL IGP with only 8 XEs is fed by 128-bit 5600-7500mbps (LP)DDR5(x). 20 XEs will need a lot more, unless clockspeed will take a drastic hit.
