Page 204 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
942
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
ikjadoon
241
519
"Battery capacity has increased from 80 Wh on the Prestige 15 to 99 Wh on our Prestige 16. Combine this with the efficiency of the new 14th gen Intel CPU and you can get extremely long runtimes of almost 18.5 hours of real-world WLAN browsing. This is one of the longest-lasting Windows laptops we've tested with results that rival the MacBook series."
Impressive battery life here. Would be curious to see how a PHX laptop with a similar size battery performs.
Not a fan of how MSI decided to set the PL2 to 115W in this laptop. Hopefully there is at least an easy option to cap power much lower. Asus in the Zenbook seems to allow you to cap the power to 28W, which is much more appropriate for a thin and light laptop.
As you noted, this is running a pretty old bios. Would be interesting to see if things can improve with newer FW.
That is some bonkers battery life on an H-series CPU. Love the 100WHr battery. Li-on batteries are so light relative to a laptop, everyone should be going big. Now let's see some MTL-U battery life next year: that is what most consumers will buy, as Intel finally got rid of the confusingly popular P-series.
For reference, here is the original M1 MacBook Air:
The M2 Air was actually a bit worse at 910 minutes in the WiFi v1.3 test.
This Prestige 16 now has the 10th longest battery life ever tested in a laptop review by Notebookcheck. See the M3 MacBook Pro 16: just +9% longer with the same battery size on a very common consumer task like web browsing.
MTL appears to be a massive battery life win. Let's hope all OEMs continue to use 80+ WHr laptops in all their 13" & larger designs.
mikk
4,333
2,413
Back on MTL, another video has come along comparing the Asus new and old BIOS:
The benchmarks themselves have the usual problem of not being run at a static power level, so I wouldn't say they're of much interest. What is nice is starting around 3 minutes in are graphs of average temperature, frequency, and power versus time on a Prime95 run with both new and old BIOS. While the power graph clearly indicates that the new BIOS does allow the CPU to consume more power for a time, by the end of the graph the power consumption is equivalent between new and old BIOS... but the clock speed with new BIOS at that steady state is about 10% higher than the old BIOS. Also the new BIOS shows a markedly more consistent clock speed in general.
It uses quite a bit more power indeed, it might not even related to the pcode update golden pig was talking about. Hard to say with this power difference. On the other side the CPU frequency in Prime95 isn't that much different after PL2 drops, maybe like 15% higher (1600? Mhz vs 1400? Mhz) whereas Cinebench R24 MT run 26% faster and compiling even more faster. We don't know for the E-cores though. Depends on when Intel released the new pcode for OEMs, it's not like OEMs will immediately update and release everything new from Intel. I think it is more than just a power bump up but there is limited data in this test. Something clearly was wrong with the old bios in the compiling test, maybe the E-cores didn't run properly.
Hulk
4,104
Yes, looks like Intel pushed up max temp and power so performance benches better.
For what it's worth I was at my local Microcenter today and got to check out that Zenbook with MTL. Wow, gorgeous screen and really nice form factor I must say.
Khato
1,381
488
At the end of the Prime95 frequency trace it looks to be reporting about 1.3GHz on the old BIOS and 1.425GHz on the new BIOS. During that time the reported power is basically equivalent. Note that I'm assuming that the reported frequency is indicative of actual relative frequencies.
The frequency plot on the old BIOS is definitely indicative of there being something wrong. It seems like it's overcompensating for changes in loading maybe? Resulting in more drastic swings in frequency compared to the new BIOS.
Reactions: lightmanek
controlflow
198
348
I played around with one too, really liked the 120hz OLED. Nice colors, contrast and a fast/responsive display. Too bad those screens are so power hungry. BTW, I can confirm that the retail units really do have LPDDR5 7467 (32GB for the unit I looked at). The Best Buy specs claiming 6400 is indeed a typo.
I might consider picking one of these up based on how the power/performance ends up looking after a few more bios updates. The build quality and packaging are nice and it seems to be quite capable for a sub 3lb system. $1300 is a pretty reasonable price for the specs, but maybe I've been too desensitized by Macbook Pro pricing.
Hulk
4,104
Not to derail the thread but do you know if the SSD in the Zenbook is replaceable? I'd really like a 2TB (or more) drive.
TESKATLIPOKA
2,696
3,260
MTL is a massive battery life win? It clearly depends on laptop, Acer Swift Go 14 SFG14-72 ended up much worse in comparison despite having the same CPU.
On the other hand, MSI did a great job in selecting power efficient components and putting the biggest battery possible inside.
BTW, this was in what you posted.
Raptor Lake U managed 954 minutes with only a 68W battery, If I normalized It to 99.9W then It should manage 1401 minutes.
Not really apples to apples comparison for both CPU and laptop, but I wanted to show that It's not really depended on CPU, because they are very efficient light loads, but more on the rest of components(SSD, RAM, display).
cebri1
373
405
I saw one as well, it's indeed gorgeous. I may pull the trigger on it, as I'm looking to replace my old 7700 + 1050Ti. Only downside is 16GB of RAM.
mikegg
2,134
669
Do these battery benchmarks account for browsing speed? For example, number of web pages loaded/minute.
I can see CPUs running at extremely low frequency in order to increase battery life. AMD and Intel mobile CPUs are notorious for running at half the speed when unplugged from the wall while Macbooks run at full speed until low battery.
DavidC1
2,182
3,329
RWC is exactly same as previous gen, clock frequencies too are similar to previous gen & no known significant performance optimizations either. They played it too safe. So, we can't expect much performance gains with RWC at this point I guess.
Redwood Cove on client gets doubled L1i. Probably helps in some scenarios and also lower power a bit.
Reactions: SiliconFly
DavidC1
2,182
3,329
The U's are more power efficient but average is what matters. Alder/Raptor seems to have a bigger than usual variation. Let's see what other MTL laptops, especially based on Us do. I'm interested on U9.
Tigerick
942
857
U9 has 2P+8E with 4 Xe Intel graphics, there is nothing special on it. You should wait for a year for Lunar Lake
DavidC1
2,182
3,329
If you are looking for portability, the chances are you aren't a gamer, or at least don't slobber over graphics. At that power level, you won't run much of latest fancy pants graphics anyway. Lunar isn't going to change this.
By the way, no surprise at Meteorlake launching in December. All I see is bunch of excuses or long-winded explanations, but mobile always comes out to be 1 year release cadence. If a next gen product is coming 6 months down the road, why would manufacturers bother, especially considering it takes couple of months for BIOS/software optimizations.
mikk
4,333
2,413
Sadly he used Prime95 instead of Cinebench R24 or his compile test to check out clock speed, power and temperature, it would have been much more meaningful for a real world use case.
SiliconFly
1,924
1,284
that's nuts.
IDK, I am not a computer engineer, but I read an article comparing rentable units and hyperthreading, and I didnt see them come to that conclusion.
The surprising thing about ARL is that if it truly does not have hyperthreading, the leaks I saw didnt say anything about increasing E cores either.
Seems like the worst of both worlds. Loss of single thread performance due to clock regression, and loss of ultimate MT performance due to no HT.
My feeling is that Zen 5 will dominate in both.
Pretty sure you cannot scale ST performance by X amount just by scaling up a theoretical core's resources by the same increase. A single thread will never fully saturate the width of a core at all times because of instruction dependencies, which is exactly why going wider doesn't give you proportional IPC uplift. It's also why SMT was created, so that you get more throughput of a given core, but not more ST performance. Rentable Units, if it's actually possible, likely means better utilization of silicon area since you don't need a separate big cores, which are not efficient from a perf/mm2 point of view since ST performance has diminishing returns with core area.
Regarding rentable units... Sadly the reality is quite boring, especially compared to the fanciful fiction. I bet that the term was included without context in some presentation that a non-technical 'leaker' received. So clearly some explanation for the term needed to be created in order to be able to 'leak' it.
Sorry abt the confusion. I was talking about the theoretical maximum of a hypothetical 8 core CPU with a perfect Rentable Units (RU) implementation running a perfectly sliceable workload. Just an imaginary CPU (not Intel or any other company for the matter). Don't think a real CPU like that can even exist in the real world. It was all just about the idea itself.
Actually, I think MLID's leak about RU in some future Intel architecture is (I'm assuming) maybe about just 2 cores tied together into a single cluster and sharing resources that can probably boost slightly beyond a single core's ST performance when a single thread is assigned to that cluster. But even that sounds a bit dodgy imho.
FlameTail
4,384
2,762
Smells like a resurrected Bulldozer?
SiliconFly
1,924
1,284
Unlike RU, Bulldozer's ST perf is limited to a single core's max perf. In theory, RU's ST perf can actually exceed a single core's ST perf depending on the thread. Whether this works in real world is a different question altogether. Sounds a bit unlikely as implementation is a nightmare.
coercitiv
7,485
17,887
A perfectly sliceable workload would be sliced into the optimum amount of threads already. It would also reduce RU efficiency to zero as all cores would already have work to do.
SiliconFly
1,924
1,284
...when a single thread is assigned to that cluster...
Not multi-threaded workload. I mean a "single thread" can be "sliced" by a processor only if it has RU.
(Very different from scheduling workloads with multiple threads which is already common.)
Abwx
12,021
4,982
Cinebench scores from a Thinkpad Carbon: https://www.bilibili.com/video/BV1PQ4y1J7K9/?spm_id_from=333.337.search-card.all.click
Sustained power around 30W and PL2 55W (6:45).
From 9600 pts to 14952 pts is 1.56x better perf and should require 2.5-3x the power, and here power increase by only 1.3x, that would be perf/watt increasing hugely when power increase, that s impossible, there s a a turbo at work here.
Edit : Assuming that 9600 pts at 23W is accurate then 14952 pts is at 55W.
coercitiv
7,485
17,887
A single thread that can be perfectly sliced by RU can be sliced perfectly by the programmer or the compiler as well. You asked for the ideal situation, that's what happens when things are pushed to the limit.
