Page 87 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Too vague for me to tell how much he/she knows, but @adroc_thurston is certainly right that LNL is by far the more interesting of the two.
Lunar Lake is and always was on N3.
As far as I'm aware, this is not true, though it's possible I'm behind the curve. I'd take that claim with quite a bit of salt, however.
I'm pretty sure that Intel on their backside power delivery article they've already confirmed 20A on Arrow Lake next year, unless they retracted that statement..
A properly balanced core won’t have the resources for SMT. If Intel is dropping SMT, perhaps they have rebalanced the whole core. If that is the case, things are going to get VERY interesting.
Widely rumored by now
Not by any credible source.
I acknowledge that ARL-S has a high probability of being on N3. I genuinely didn't know that was the case with LNL as well. I can't find it anywhere on the internet either.
Intel 4/3 > TSMC N5/N4/N3. It doesn’t matter if Intel 20a/18a is used for Arrow Lake/Lunar Lake or not, Intel will have a process advantage. AMD is using N5/N4 for Zen 5.
Intel has already stated that Intel 4/3 could be used if they run into problems with 20A/18A. IIRC This all goes back to the original Investor Day presentations.
" Intel 3, Intel 20A, and Intel 18A remain on track", Intel announced in 1Q23 earnings report (This must not be a lie).
We should wait and see 2Q23 earnings report...
Is it possible that they are bypassing 20A because 18A is turning out good for them?
More likely that the client tiles that were (at least talked about) on 20A are also dual sourced at TSMC. Intel must have decided that keeping the 20A version wasn't worth it.
The 18A server products are likely only on 18A. Intel may get to the point where they feel like they need to have the server products at TSMC to remain competitive... but obviously they would want to unload the fabs first before doing that.
If I understand correctly, here is where Intel stands.
1) Intel has stated for over 4 years that they will try all options. All options means using their own nodes, backporting CPUs, and using external fabs. (red circles were my emphasis) https://images.anandtech.com/doci/15217/20190916 SPIE Photomask and EUVL Plenary - Phillips v23-VRL2 distribute-page-019.jpg
2) There is no financial reason for all options to make it to the market. Intel would use what is best for Intel at the time. Thus, many options would be canned.
3) Intel has publicly stated that all options include CPUs that could be using x86 tiles from other fabs. https://www.anandtech.com/show/1657...-on-intel-ip-blocks-for-foundry-cores-on-tsmc
4) Intel has stated that Arrow Lake will be on 20A and external. https://www.intel.com/content/www/u...ogy-roadmaps-milestones.html#client-computing
5) Same link as #4 says "Lunar Lake and Beyond – Fueled by its IDM 2.0 strategy, Intel will be using both internal and external process nodes to deliver leadership products."
Go back to item #1 above. Suppose all options work. Intel's node works, backporting could work, external fabs could work. Suppose Intel already bought the fab production. What would you do in that situation? Use the external fab or ditch that lost money and fab it yourself?
Any particular reason why?
Very different SoC. Hopefully time to develop something better than MTL's garbage.
Was.
Was more interesting.
I'm not aware of any substantial recent development with LNL. Can you elaborate?
It is true, 20A parts went MIA, 18A ones still seemingly intact.
There've certainly been reports that they rejiggered which products the 20A die would go into. Sure that may not be the source of confusion?
You have a lot of good info and knowledge but then you say stuff like this and it throws me for a loop.
To me, ‘garbage’ is Rocket Lake, Kaby Lake, etc. MTL is on a new node, has new features and is the most advanced non monolithic client CPU Intel has done to date.
You might be in the moore's law living world.
But realworld is not.
Tiny mobile parts are not really affected.
Intel 4 displays good logic dense, however, memory (SRAM) dense is'nt so competitive.
So, MTL has ADM cache (probably ADM is eDRAM).
This is thanks to Foveros.
Yes, it's needlessly complex.
MTL has been designed with modularity so that presumably various chiplets can be ”plug and play” to create different products
Ugh, nope, only SOC/IOE tiles get reused for ARL and neither have any relation to Lunar-onwards.
Doesn't make it good.
Just needlessly complex.
What’s the alternative, keeping it monolithic? That’s not really a step forward either. A chiplet design similar to Ryzen client desktop isn’t a viable alternative for the low power mobile segment.
What is it supposed to do to not be trash?
Tile arch has some advantage not only reusing IP but also flexible choosing process node, easy debugging, better yield and so on.
If MTL were monolithic, MTL could be a product in 2024.
You can study "why MTL is being MTL" from resource of Hot Chips 34.
There’s also the process node aspect. to produce a single compute tile makes node transitions much easier.
Less tiles.
Not be needlessly complex versus what came before.
Just do less tiles.
Adding packaging overhead where there should be none is silly.
This seems like a distinction without a difference. You're proposing to combine the SoC and GPU tile? That makes it even less flexible and likely doesn't do much to reduce complexity.
It's not just the chiplet partitioning, though that's not ideal either. The universal consensus seems to be that the SoC die is a mess. They rushed it terribly, and lost a lot of the architects midway through. Maybe Chips and Cheese can tease out some of the details.
There are some good ideas and notable improvements in MTL, but there's a lot of bad mixed in. LNL had the luxury to learn from some of that secondhand, and also much more relaxed requirements (e.g. all-in on TSMC, so no process worries).
