Page 442 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
Appears Lunar Lake models will start around $900. That's for the base model with the Core i5 and 16 GB of ram. Still too high.
It’s very simple actually, you have questions about Zen5 scores you take that discussion to the Zen5 thread. Read the forum rules if you have more questions.
100% this.
Final warning before I start filling in spaces on ban bingo cards. This is an Intel thread not a versus thread. The amount of AMD talk is way past what is permitted in a vendor thread. You can start your own comparison thread for released products, but not for unreleased ones. Basically keep your chocolate out of their peanut butter.
Mod DAPUNISHER
I base my sayings in numbers while you re left using deffamation if not willfull ignorance or eventually both since i said what are these numbers, but here they are with proportionality respected :
If CPU A score 100 in ST and CPU B score 115 then how is it possible that when using only 6 threads in MT CPU A end being 10% faster..?..
Different cpus have different inter-core latencies. Real MT scaling needs low latency interconnect between cpus- and 9950x based on slow interconnect between different CCDs might very well tank in performance when job is split to two CCD. 9950x might perform better on that test when other CCD is disabled.
If you know something about Intel s communications with OEMs please let us know, for the time the general public is aware of nothing and can rely only on past Intel s behaviours.
Intel's past behaviors is that PL2 is fixed in stone and does not change it this late in the game. Arrow Lake PL2 could be different than Raptor Lake PL2. But it isn't changing at the moment like you claim.
And yes, that is also Intel's communications with OEMs. No matter how much you wish it happens, there is no "surprise, those months you took to design a computer, toss those months in the trash, we are changing everything with just weeks to go!". Microcode changes can and do happen in the final weeks. But not massive changes to critical design inputs like PL2.
Yeah, if the Expertbook with the lower Ultra 7 SKU and 32GB already costs 1400€+ I can already see that a top Zenbook S14 config probably costs 1800€+. I hoped if it's good I would get it for like 1300-1400€.
That's for the lowest Lunar too. That i5 is not very performance oriented. You want the Ultra 7.
The thinkbook 185H is close to 1800€ so more or less aligned with Meteor Lake I'd say. My guess is that this will probably have higher margins (Intel 4 Ireland vs N3B).
Edit: ThinkBook 13x G4 IMH Intel Evo Core Ultra 9 185H/32GB/1TB SSD/13.5"
1799€.
Sometime there s stones that can end being as mellow as butter.
A must read once you have some time left :
It would have been pretty nice if Ultra 7/9 had eight Skymont cores. Now all different SKUs feels rather pointless. I still wonder what is their main target group for these...
Isn't ExpertBook, as Asus' enterprise line, typically more expensive than Zenbooks?
Starting a tad below 1k for initial SKUs is what was expected for LNL and it's mostly fine if it delivers on expectations. There'll be cheaper designs later on as always.
I read through it and I'm not seeing your claim that PL2 was changed with just weeks to go.
So, lets look at the recommended PL2 in your link. Lets start with August 2021. Looks like 253 W.
Ok, now what happened when Raptor Lake launched: Hmm, PL2 is still 253 W.
Ok, well maybe it changed for the 14th generation: also 253 W. Boy Intel really changed it in the last few weeks!
That is definitely not true. The board is very much in control of the PL1/2 and OEMs can set it to their whim.
Of course OEMs can set those values to anything that works for them. The claim that I am debating was that Intel forces changes to PL2 with weeks to go.
Lets say, as Abwx is implying, that Intel will suddenly require PL2 to go up. The OEM designs often won't be able to cope with that. PL2 going down is feasible of course. But Intel suddenly making a major required PL2 change after the chips have been in production and OEMs are making designs? Not happening.
This is the post that I find incorrect:
Guess that currently Intel is devising about the exact power they ll use since at 250W they will have a win only in CB R20/R23 for MT, and a marginal one.
Intel isn't the one devising PL2 at this point in the process. OEMs can, Intel isn't. The Intel recommended PL2 was set a long time ago.
Honestly no clue, i'm not that much into that stuff. I just guessed that Expertbook is more expensive than Vivobook because of being Enterprise. But Zenbook is the premium consumer line and Zenbook S is the Premium ultrathin one within the Zenbook line so i just thought it is eben a bit above Expertbooks. 32GB configuration of Zenbook S16 is 2099€ here.
I know there will be cheaper options, but some keys of the keyboard of my 5 year old Acer Swift 5 partially stopped working so I need something new in the near future. I wanted to wait for LNL reviews because if the battery life is meaningfully better than everything else on x86 it will be my go to.
And since Acer is not an option anymore for obvious reasons, the Zenbook S14 is the only device that got leaked already. Oh, and I want an OLED btw. S14 basically has all what I want, basically only waiting for reviews if there's a massive dealbreaker in terms of fans or something.
For the time the leaks say that ARL has a 177W PL2, we ll see how this will end in two months, the recent CB R23 leak tell me that there s few chances that it will be the final PL2, but who knows.
You originally claimed that Intel is changing PL2 ("Intel is devising about the exact power they ll use") then you claimed PL2 could be 297 W ("They may well set 297W as PL2"). Now you are going with 177 W. I have a hard time following your rapidly altered ideas.
Intel's recommended PL2 is fixed. It isn't currently changing. It may be different than Raptor Lake. I'll accept whatever number you say for discussion purposes, but it isn't currently changing. The 177 W number does match Jaykihn's leak for two of the Arrow Lake-S chips only in baseline mode (the top two 125 W TDP chips). That PL2 number of 177 W has been floating around for nearly a year from DarkmontTech.
The 177W were discussed in this very thread as some people really thought that
such perf/watt improvement at better perfs than the 14900K@253W was possible.
What i m saying is that at least 250W are required for a marginal win in Cinebench R23 and 2024 but hardly in anything else, so how will Intel react, you think that they ll be content with a win only in these CB benches and a tie or so in the non app GB 6.?.
And btw, Jaykihn numbers in GB 5 are about the same as the ones in the recent GB 5 submissions, so the numbers he provided are in line with the final silicon.
Intel is not reacting, not at this point, not with chips in production and OEMs already designing computers around it. Intel's chance to react ended months ago.
Intel has publicly stated that they aren't having performance wins until 18A and not a clear performance win until 14A.
That s perf/watt win in the slide, not perf win.
Precisely the only thing that can be changed that late are the thermals, at this point it is months that they have done tests at all possible powers, so they know what is possible or not, and fixing the final TPDs 2 months before releasing a product is nothing exceptional, all it require is a bios.
Also it could be different for OEMs and retail market because enthousiasts are looking for pure perfs while OEMs have traditionaly a more cautious approach.
What does a slide about their future nodes have to do with whether they might get performance wins on the product side, especially considering ARL is like 95% going to be on N3B?
Can someone who has 13k/14k processors explain,
is it a thing that Intel CPUs run all cores @ 5.7 mhz in geekbench, or if these are results of OC-ed CPUs ?
GB6 : Intel(R) Core(TM) Ultra 9 285K : 3449 Single-Core Score 23024 Multi-Core Score
GB5 : Intel(R) Core(TM) Ultra 9 285K : 2513 Single-Core Score 28214 Multi-Core Score
According to Techpowerup reviews the 13900K will boost up to 5.5GHz all core given adequate cooling and volts. The 14900K will go to 5.7GHz all core. Anything beyond that is technically overclocked I would think.
I need a new laptop in a bad way. My Surface Laptop 2 has served me well and is still serving me but I'm out of SSD space, trackpad went nuts about a year ago (disabled it), and somehow I cracked the screen. Plus the Skylake quad core is completely overmatched for even light video editing at 4K, Photo/Video AI, and many other apps.
I'm most likely going to buy a LL laptop shortly after launch assuming there are some decent choices. I'll bench the heck out of it and let you all know how it does.
1799€.
Nope cause intel 4 meteor lake has IDM Margins as well with lunar lake TSMC there is no margin for manufacturing besides packing
