Page 443 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
941
857
Wildcat Lake (WCL) Specs
Dies2223
Threads12688
Max Clock5.4 GHz?5 GHz4.8 GHz
L3 Cache12 MB12 MB12 MB
Size96 GB32 GB128 GB
Bandwidth136 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz?2 GHz2.5 GHz
DavidC1
2,164
3,307
I still wonder what is their main target group for these...
The point is battery life superiority in an x86 platform so it has no compatibility issues and GPU that's way better than on Snapdragon.
All having 4+4 means it doesn't matter as much if you get Ultra 5.
Thoughts on this? Seems quite ambitious. GLC IPC based on GB6 is 511
There was another comment saying when he left the Royal Core group the performance on SpecCPU wasn't that impressive compared to the other teams projects at least for the first version.
I would just say it was way too ambitious and probably unrealistic. Computers already advance at a breakneck pace. You can't expect the increase in pace of that to increase, can you?
DavidC1
2,164
3,307
Need both core sizes, clock ceilings, perf/watt and clock comparisons, but as it is based on rough data it would appear you'd need around 1.4-1.5 more Skymont cores than Zen 5 cores (with Zen 5 operating at similar frequencies ) , and around 1.2x Zen 5c (both at max clock speeds) to match throughput
Zen 5c is slower than regular Zen 5 by few %. The latter is 6% faster in Int. Regular Zen 5 is 10% faster than Zen 4 and if Skymont is 2% faster than RPL then the gap is essentially zero.
Since Skymont in Arrowlake clocks higher than Gracemont despite the P core sister losing frequency, I would wager on Skymont having significant clock advantage over 5C, if power is damned. It is possible if the 1.5mm+ size is true then maybe 30% extra core size is taken up to increase clock potential(which I think is stupid).
We have another example of very different approaches reaching a similar end result.
Abwx
12,004
4,968
SKT has 4% better perf/clock than Zen 3 in CB R23 and likely 5% slower in CB R15, for R23 that s almost s 100% confirmed.
jdubs03
1,480
1,054
Got a quick link there? I was searching the comment thread but didn’t spot it.
511
5,424
4,844
cebri1
373
405
I need a new laptop in a bad way. My Surface Laptop 2 has served me well and is still serving me but I'm out of SSD space, trackpad went nuts about a year ago (disabled it), and somehow I cracked the screen. Plus the Skylake quad core is completely overmatched for even light video editing at 4K, Photo/Video AI, and many other apps.
I'm most likely going to buy a LL laptop shortly after launch assuming there are some decent choices. I'll bench the heck out of it and let you all know how it does.
One wonders if a 16 core chadmont would have a market for a “low power” video/photo editing machine.
Nope cause intel 4 meteor lake has IDM Margins as well with lunar lake TSMC there is no margin for manufacturing besides packing
That’s not how it works: gross margin = average price per unit - average cost per unit. It doesn’t matter if the product was built in house or it was outsourced. Intel 4 is quite expensive per Intel’s last earning call, maybe it was cheaper to outsource it to TSMC.
Henry swagger
513
313
Just went through the link. It is quite amazing that a 17w lunar lake part can actually match a 120w 7900X in ST. Lunar lake products are gonna be pretty exciting assuming they’re priced right.
Competition has only a very small market share in laptops. At this level of performance, Lunar Lake might actually wipe it totally out of existence.
Yeah intel will increase market share even more if tsmc can supply 10 or 15 millions chips
511
5,424
4,844
Yeah but they said they ran hot lot for Meteor lake demand outstriping their estimation
mikk
4,333
2,413
The main excitement comes from the much increased efficiency/battery life in many real world usage scenarios like video playback or browsing or any other light workloads which is unheard-of for x86. Sure with 8 threads it won't set new efficiency records under full load but who does this constantly on a (low power) mobile device. If someone needs to do rendering tasks regularly he should better buy something with more cores and threads.
511
5,424
4,844
For the 285K.
Previously It was 10212 pts in CB R23@30W, wich is about the same score at same power than a 18 months old 6C/12T 7540U, so they are quite late to the party, dunno why the excitement.
We for extra 13W 76% more power we got 19% more performance so LNL doesn't scale well at 30W in terms of CPU power 17W is the best point to operate at
511
5,424
4,844
TSMC can supply that considering Intel's Pre Pay and volumes which are larger than AMD and Qualcomm combined don't forget they supply Apple so volume is never a TSMC Problem
Abwx
12,004
4,968
That s 15W CPU + 2W RAM and 28W CPU + 2W RAM, so the CPU power increase by 87% while the CB score increase by 24.5%, this amount to power increasing at a 2.85 exponent rate of frequency, wich is more than previous TSMC s processes, so it s either the process or the design that did cut some corners by increasing density at the expense of perf/watt at the higher range of the TDP, not that it make a huge difference.
cebri1
373
405
The only thing that slightly worries me about these new CPUs with already midrange iGPUs is cooling capabilities of the laptop. I currently have a G14 with Ryzen 9 with a 4060, and the laptop is much better cooled when the dGPU enabled despite drawing more power. I guess the APU gets quite hot when both the 780M and the R9 are enable.
511
5,424
4,844
Score increased by only ~20% also it is package power which can be redistributed where is necessary
Magio
206
243
The excitement comes from a few things. For one, power consumption characteristics which are expected to be almost Apple Silicon-like (tho single core PPW is likely to still be noticeably worse than M3). Then you have *most* benchmark results that have leaked which range from very encouraging to outright great, both in ST and MT considering the chips' TDP. It's also looking quite capable on the GPU side (tho we'll need to wait to see it in real games).
Those CB23 scores Jaykhin is getting are not great. They're in fact quite disappointing. But they're one data point compared to many and while I do think Cinebench is typically a decent benchmark it's also not the be-all and end-all of CPU benches. If LNL does end up being a poor CB platform, then that's one weakness it will have but it won't erase its many (expected) strengths.
Nothingness
3,367
2,459
I see mac devices being used by many SW developers. And we need fast and efficient parallel builds. My 4 yo MBP can last all day running parallel builds and running mostly ST compute heavy tasks. It remains to be seen if Intel will be able to match that.
Is that a niche? Surely 😀
majord
509
711
You're drawing a huge bow here I'm sorry.
2% faster than RPL in MTL to start with, and this is Intel's word. Hence why I said we need to wait for more data.
Zen 5 is more than 10% faster than Zen 4,
Zen 5c is the same architecture as Zen 5. any perceived difference in Strix application is L3 or latency related
you've ignored SMT
I already assumed a max clock difference between 5c and SKT , approx 4Ghz vs approx 4.6ghz
