Page 408 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
Wildcat Lake (WCL) Specs
Intel Raptor Lake UIntel Wildcat Lake 15WIntel Lunar LakeIntel Panther Lake 4+0+4
ModelIntel 150UIntel Core 7 360Core Ultra 7 268VCore Ultra 7 365
Dies2223
Threads12688
Max Clock5.4 GHz4.8 GHz5 GHz4.8 GHz
L3 Cache12 MB6 MB12 MB12 MB
TDP15 - 55 W15 - 35 W17 - 37 W25 - 55 W
Memory128-bit LPDDR5-520064-bit LPDDR5x-7467128-bit LPDDR5x-8533128-bit LPDDR5x-7467
Size96 GB48 GB32 GB128 GB
Bandwidth83 GB/s60 GB/s136 GB/s120 GB/s
RTNoNoYESYES
EU / Xe96 EU2 Xe8 Xe4 Xe
Max Clock1.3 GHz2.6 GHz2 GHz2.5 GHz
NPUGNA 3.017 TOPS48 TOPS49 TOPS
I don't know why anyone would expect anything else other than marginal ST uplift. Intel 7 is many things, but it allowed Intel to clock their CPUs incredibly high. Finding a large ST uplift was always going to be an uphill battle.
Raptorlake was not supposed to exist. It was supposed to be Alderlake->Meteorlake. Instead, we got a REFRESH of the supposedly-not-existing part.
So they were able to refine the chip endlessly, same as when original 14nm disappointed due to longer than expected 22nm refinements. Then it happened again with 14nm vs 10nm.
Are you saying there is only one QS sample Intel uses? Can you prove that? Then why he doesn't share the clock speed, what's the problem?
If it can get to 250W then it means that clock speeds are healthy, otherwise it couldnt hit such a TDP.
Beside the GB5 SC score is comparable to LNL when you account for the theorical frequency, in GB5 LNL does about 2000 pts at 4.6-4.7, so 2455 pts at about 5.7 is right on the money.
Hard to say considering his poor track record. He maybe wrong yet again! But considering his claims that it's a QS, the benches are a bit appalling. Not saying it's definitely close to final. But it maybe. And thats the worry.
LNC isn't RPC. It was supposed to bring in more IPC.
Why he isn't using the real name of the sample? if it's a 285K QS why not call it 285K QS? If it has 0000 CPU ID it's certainly not a QS.
But, ARL's LNC was expected to have higher IPC than LNL's LNC. Otherwise, there was no necessity for 2 different LNCs. No reason to work on 2 expensive designs parallel. Something's amiss.
If no decent uplift, the P core team needs to be fired.
I m not familiar with all Intel s iterations but i dont think that they designed two different P cores, there could be very minor differences such as L3 cache size but for the rest this should be the same cores, otherwise that would be a nightmare for validation, better to deal with a single beast given that they have two designs within an hybrid uarch, that s already miraculous that these can be designed and fabbed in a matter of 2 years.
From everything I've seen, that was simply a forum theory based on very shaky, if any, evidence.
They still need to design for LNL and ARL SoCs separately as they are supposed to compete in very different markets. However, that doesn't mean the cores themselves have changed at all, except maybe in higher levels of cache.
The P-core team has definitely been struggling.
It has 0.5M moar L2.
That'll have some, albeit marginal, impact.
Yes, I mentioned this in the next line, but the forum theory was that they were changing key structures of the cores themselves.
They've had way too much time since the last big tock. It was already mentioned clearly that LNC is an umbrella term for multiple core designs that share a common trait (fubs/cells). And ARL's LNC was expected to have more IPC than LNL's LNC not just due to cache/memory, but maybe due to a few other higher power/frequency related optimizations.
Usually around 5% was the expectations. I even expected more. But this changes the game entirely. Either many of us here were wrong, or the there's something off with the results. Need more info.
Again, unless you can show otherwise, this was just pure forum speculation that multiple people were debunking along the way, but I guess hopium kept it alive in the minds of some. Some later server offerings might differ in some respects to the consumer chips, but that wouldn't be anything new as Intel has made architectural tweaks for server SKUs on multiple occasions.
Not so long ago 5% better IPC mandated a uarch serious overhaul despite lower hanging fruits than what is available nowadays.
Even if there s a little IPC difference between ARL and LNL this is partly leveled by the latter s huge 8533Mt/s RAM speed, that s 42% more BW than DDR5 6000, so in practice both chips should have comparable perf/Hz.
Plus it makes sense for Intel to choose a point in the curve that (barely) improves on their previous product while directing all efficiency+IPC improvements towards curtailing their insane power requirements. Otherwise they're never going to climb down from up there.
Ok. Here are my thoughts... @Jaykihn QS results may not reflect final. Either his QS isn't close to final or something else is amiss like bios, power profile, device drivers, memory, etc. He maybe wrong yet again. It just can't be this bad considering the heavy duty uplift provided by 16 skymont cores.
Even with all the additional high uplift provided by 16 skymont cores, if the total MT isn't good enough, then it kinda signifies that the P cores have serious IPC regression which doesn't compute well. Like I said, somethings amiss.
Time for some napkin math.
It's almost as if there's some feature that boosts your nT performance at a very small area cost that Intel dropped this gen.
I told you so...?
The only difference in the two cores are the 0.5MB L3 cache, meaning basically 0% gains.
Is there a middle ground with you? You flip completely from optimism to pessimism.
By the way, firing is what got them into this mess in the first place.
ST doesn't care about bandwidth. Desktops have an advantage of having 60ns memory versus ~110ns for laptops which will actually matter for ST.
If these leaks come out as true, lion cove seems disapointing, arrow lake seems meh even with the chadmont onboard. Tsmc 3nb, no avx512 and bigger core than z5 for overall similar perf and eficiency? Doesnt seems great for me
That was never the consensus viewpoint. There was never any evidence to expect anymore than 1-2% IPC over LNL’s version of Lion Cove.
The info that Intel provided to their partners was 1.05x over RPL. That should have always been the expectation.
Intel is back with their yearly schedule. single digit uplift is embarrassing. What are they even doing over there? 3 generations of Alderlake derivatives for this?
TSMC N3B doesn’t provide any tangible benefit to an x86 core in a desktop CPU. I could even make an argument that N4P is a better node for that use case.
As far as efficiency goes, there’s still no data on this from either Zen 5 or ARL.
CPU fabric doesn't deliver full bandwidth on neither LNL or MTL/ARL CPU side.
That's cope, it's a marginally faster node under all circumstances.
It's just expensive, that's the downside.
Competitive at what cost? New nodes, 2 new cores for that? Pyrrhic victory, and even that is not guaranteed.
That same argument works in reverse too. It's super weird how Company A and Company B can land at the same performance and yet it's a disaster for one and a success for the other.
