Page 387 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
920
835
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
Henry swagger
513
313
It is a alright benchmark that at least scales compared to GB6. CPU-Z is a good indicator if compared against other Intel CPUs.
Chips and Cheese analyzed the bench and came to the conclusion that the instruction mix does not accurately resemble consumer workloads.
I call half BS on that, which bench really resembles consumer workloads SPEC - FP or INT, Cinebench, all the other crazy SIMD benches ?
I think the bench got overcriticized because AMD is slow in it, showing that the Zen4 core is less wide AND SLOWER, which it is.
I cannot make this sh... up, wait for GB6 benches and don't trust CPU-Z.....
The leaks seem possible, E-Cores are buffed beyond 50% and the P core are min +15% faster with additional news of the new layout.
Current System (13700K@1,34V 2P@5,8 6P@5,7 8P@5,5 8E@4,4 = CPU-Z : ST=938, MT= 13100), so quite realistic.
Cpu z line up perfectly with cinebench r23..
Reactions: AcrosTinus
ondma
3,316
1,708
Nobody is making a 50% IPC gain in a single generation, that's simply not possible.
It also doesn't make sense they'd use TSMC N2 when 18A is supposed to be ready before it (if not 14A!) and they keep claiming they are going to achieve process leadership. That article reads like someone's wet dream about what they want to happen, much like how people here were building up all this hype for Zen 5 to gain 40% or more IPC.
I wouldn't call it "not possible". Zen did it over Bulldozer, and Skymont is in the ballpark of 50% increase. Granted, both are coming vs a much weaker baseline than intel's big cores. And as other posters said, it was probably based on a 2 or 3 generation leap. I am not saying it will happen, admittedly, it is very unlikely.
coercitiv
7,447
17,752
So in a desktop motherboard, there is the "Processor" and the "Chipset", as shown in the above diagram.
Is this true for laptop motherboards too? My understanding is that in laptops, the Chipset and Processor are integrated into one SoC. Is that so?
Most laptop designs that aim to have decent battery life will have the chipset on package or on-die, because it affects idle power consumption. Speaking specifically about Intel, historically they preferred to have the chipset on package for low power SKUs and kept it separate for 45W+ products. Here's a screenshot with Skylake packages for different form factors:
Obviously as we move towards the modern implementations like MTL and LNL, integration became tighter. The "discrete" chipset is probably on it's way out even for higher performance products from Intel.
ondma
3,316
1,708
Until CPU-z corrects the design of its benchmark to respect the CPPC scheduling of Ryzen, the results will be a wildcard because it always forces to core 0, which could be any random quality core boosting to any unknown frequency below or up to max singlethread boost.
Comparing any two samples of Ryzen will give you unpredictable results due to this.
Comparing Ryzen ST results to intel is also disingenuous because it will schedule properly on Intel to the fastest core.
Not saying CPU-Z is a valid benchmark or not, but to be fair, Acros did state that it was useful for Intel vs Intel.
TwistedAndy
159
150
It's pretty weird to see 20-30% IPC claims. Intel has given us some first-party numbers:
It makes sense to expect similar numbers for P-cores in Arrow Lake vs. Raptor Lake.
Also, if we take a closer look at Lion Cove's performance/power curve, we will see that it's steeper at the beginning and "saturates" faster. There are fewer reasons to push the power limits higher. Probably, the PL2 for Arrow Lake will be decreased to a more reasonable 180-200W. PL1 is expected to be 125W for ARL-S.
Tup3x
1,287
1,418
Well, some test can very well show 20-30% improvement as Intel showed but average is not going to be like that.
DAPUNISHER
32,270
33,031
Holy cow. This thread turned into a mess really fast and devolved into the usual conspiracy drivel.
The performance of ARL-S is more or less known. There are Intel NDA overclocking guides that have already been given to partners and tons of ES samples in the wild. There’s no data to suggest a +20% 1T performance increase. Hype it at your own peril.
I agree. I don't know why some think this is a versus thread. Or are disregarding the CPU forum rule about vendor threads being safe spaces but the next post throwing shade at Intel or pimping AMD is getting double ban bingo spaces filled.
If you (collective you) don't like what is posted in this thread, don't read it. You can't come in here and start accosting the Intel users about any claims made. And keep AMD out of it, they have their own threads. As I have posted before and The Offspring rocked - You gotta keep 'em separated.
Mod DAPUNISHER
KompuKare
1,234
1,605
And that's the best thing IMO.
What I would call a return to sanity after all these pushed to the limit (or beyond) parts Intel released the last few years.
IPC 15% ± 5% or whatever we end up at the end is great but what had made Intel an automatic no for me the last few years was the power usage.
TwistedAndy
159
150
Intel Lion Cove has 33% more peak throughput than Raptor Cove (8-wide vs. 6-wide), but in the real apps, the IPC increase will be closer to the values presented by Intel (10-20%).
Obviously, some apps will be able to utilize all the throughput and show ~30% increase in performance (as we see on the Intel's chart), but it will be rather an exception than a rule.
Yes, leaks were suggesting that Arrow Lake desktop CPUs will have 125W PL1 and 177W PL2. It looks pretty reasonable.
As for the mobile ones, ARL-HX will have the same 55W PL1 and 115W PL2.
Reactions: Hulk
DavidC1
2,021
3,157
The big picture reason for Intel taking forever to integrate the PCH is because they used it to fill their older fabs. It is the same reason why they took forever to integrate the memory controller too. They had the CPU, MCH and the IOH, and competitive pressure made them integrate most of the MCH into CPU and rest into PCH.
Now with Foveros and Tiles they have zero reason not to do so. Of course the cost isn't free, but it's much better in terms of communication speeds and power. For high performance such as CPUs and GPUs it might be difficult to do it fully and always a compromise but PCH should be easier and have integration benefits.
KompuKare
1,234
1,605
I always suspected that filling the old fabs was the reason that Atom was neglected for so long.
Well until years later they panicked and threw dollar bills at anyone willing to make tablets with Intel Atom. Think most of those £50 tablets have ended up in landfill by now.
Reactions: coercitiv
dullard
26,185
4,842
Take a look at the graph on the left. It shows an average (maybe median) of +14% IPC. But, that includes two benchmark results with negative IPC changes and two benchmark results with about double the average IPC change (roughly 25% to 30%). So, I don't think it is weird at all to see 20% to 30% IPC claims as long as people clearly state that that is just one benchmark--and it is on the rest of us to acknowledge that one benchmark is not representative of a processor as a whole. No conclusion should ever be made from just one benchmark unless that one benchmark is all you plan on using with that processor.
Wolverine2349
525
179
86
26.71% single thread improvement over 13900K per CPU-Z i above source.
Though 22% regression in multi threaded performance.
Either HT makes that big a difference, the SKymont cores do not have near the IPC gain as thought over Skymont, they are using the 6+8 or all of the above. Even if 6+8 if Skymont had the IPC increase to put it at Raptor Cove, I would think that should more than make up for lakc of HT and onky 8 E cores if it indeed has 2% better IPC than Gracemont??
But Lion Cove oh my so good and the real real and IPC increase maybe 25% afterall if true and the latency can be good as well. Please Intel 12 P core Arrow Lake CPU.
Hitman928
6,748
12,474
Tell me you didn’t read the last couple pages of the thread without telling me you didn’t read the last couple of pages. . . ;)
eek2121
3,458
5,105
ICYMI: The CPU-Z benchmark is fake.
Is the 15W 8840U score with a 15W PL1/2, or just a 15W PL1? Because the guy who gave the 17W LNL score confirmed it's 17W PL1/PL2.
AMD chips use a singular power limit (PPT), not PL1/PL2.
You are misrepresenting what Intel stated. They stated pretty clearly that the core in other products will differ from the one in Lunar Lake. Arrow Lake desktop, for example, will have faster cache, and more of it. It is debatable how much additional IPC uplift the cache changes will provide, but it will be > 0%. That excludes any other changes that Intel may include.
Absolute performance will be even greater, and I have seen NO indications there will be a clock regression vs the 13900k. 1T clocks should most certainly either be unchanged or possibly higher. Base clocks also appear to be up.
Hitman928
6,748
12,474
Are we memory holing the 14th gen then?
Reactions: Tlh97 and Elfear
Wolverine2349
525
179
86
Oh yeah thats right. People saying CPU-Z is flawed benchmark. Well for AMD CPUs it seems to be but it seems more accurate for Intel CPUs? Though did not fully read them just scanned briefly so may have missed?
So am I not right or is that source not right?
Hitman928
6,748
12,474
Outside of the CPUz being worthless discussion, the original source was a post in the Baidu forum, but another user there apparently called it out as being an outright fake.
Kepler_L2
1,044
4,476
CPU-Z just benchmarks how good your CPU is at branchless SSE code, which is not a real workload.
whoshere
45
99
itvision.altervista.org
Thats sad. But I'm still hoping that it's somehow true! :)
I tried to analyze the image trying to find any ps edits, but the result was inconclusive. The (false) color bleed looks more like jpg compression artifact rather than alteration. Either the image is real or they've done an amazing pixel perfect job (which isn't difficult actually) or they might have faked it some other way. Hard to say.
But what if it isn't fake? 😶
I can forge any CPU-Z score you need with a 100% accuracy, meaning you'll never be able to tell it's fake.
There's no need to forensically examine this screenshot, as it's completely useless.
