Page 269 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
adroc_thurston
7,887
10,604
This can't be real right?
Lmao.
If the focus is on efficiency it could be
Intrinsically every core focuses on efficiency.
seeing how bad the inefficiency Raptor Lake is at the moment
It's ok unless you consider KS parts real.
Raptor-HX is genuinely alright.
Could be better in MT than Zen 5 but worse in ST and edges out in efficiency kind of deal
It doesn't.
Skymont is pretty good but it's no Zen5.
S'renne
151
109
86
Lmao.
It doesn't.
Just saying the "efficiency emphasis" idea out loud only because of the rumour of LNL having 1.5x MT GB(? Forgot which software) score than MTL or something like that
Ghostsonplanets
774
1,228
It's interesting that while there a lot of rumors about ARC not being a good jump over GLC, the rumors around Skymont are pretty positive. It's almost as if the Atom team has been able to deliver a consistent cadence of performance improvements while the Core team takes their sweet time.
Tremont to Gracemont was a substantial jump, Crestmont was a nice update over Gracemont and Skymont is rumored to be around GLC performance, which is really good for what are meant to be area focused cores. One might wonder if the Atom team won't surpass the Core team someday if they keep the impressive cadence.
Reactions: Tlh97 and Geddagod
dullard
26,185
4,841
They do bf/fp8|16 math just fine.
Most support FP16/BF16 just fine.
They can support different data types. But, they often do not. This link below is an Intel graphic, so it is obvious that it is geared to put Intel in the best light, but you can see that not all NPUs ran FP16 at the time of the image creation. If anyone can find AMD's list of supported NPU data types, then I'll link that as well (my Google skills are failing me, the latest information I found is that the list of supported data types has not yet been released).
naukkis
1,030
854
Speculation was about replacing FPU with NPU. FPU doesn't usually even support FP16 math, it's single precision is 32 bit and double precision 64 bit(or more). OK, FPU SIMD today do support also FP16 but that's just outlier for something like AI where NPU is aimed at. So no, you can't replace FPU with NPU as they are designed to totally different kind of precision.
Markfw
May 16, 2002
27,360
16,193
forbidden on that link
dullard
26,185
4,841
The ability to use different data types is theoretically possible with NPUs. But, the main issue is memory, bandwidth, and power used. If you only need 4 bits (which AI often only needs 4 bits or 8 bits), then using something set up for 512 bits is quite a waste. Using 512 bits when your application needs 4 bits will require 128x more memory, will have to move 128x more data around, and will have to process 128x more of that data, using much more power. All while only being able to use much smaller AI models due to those limits. So, it isn't really efficient to use something set up for 512 bits with 4 bits
The reverse is true too. If you have an NPU optimized and designed for say, 4-bit math, and need 16-bit data, then you need to transfer that data around in 4 chunks which takes more time. Then you have memory to store only 1/4th the data. It can work, but just won't be as performant as you want.
dullard
26,185
4,841
adroc_thurston
7,887
10,604
That's compared to (non-existent) MTL-U which is one of the worst parts Intel has ever made.
Not a real achievement per se.
Again, if someone has a list of AMD supported NPU data types, I'll include the official list since I prefer my posts to be neutral in sources.
this really says nothing about the hardware, just DirectML support.
AIE-ML in PHX supports FP16/BF16 just fine.
see the docs.
Reactions: lightmanek
adroc_thurston
7,887
10,604
AIE2 in PHX supports FP16/BF16 just fine.
see the docs.
