Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 196 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
820
785
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
TESKATLIPOKA
2,696
3,260
Still trying to measure power efficiency with only the P core?
Still trying to measure power efficiency with only the LP E-cores? ;)
On the contrary, majority of the so called "power efficiency" test results that we've come across so far has squarely focused on stressing the CPU tile alone while COMPLETELY ignoring the LPE cores, which I believe it completely wrong as it doesn't align with MTL's use cases.
MTL is a general purpose CPU, so you can use It for many things, It's not limited to only light workload.
BTW, I didn't see any confirmation that those LP e-cores are not working during full load.
Just give MTL a chance to prove itself in lighter load tests with newer pcode. Thats all I'm sayin.
And you expect what? Or rather what would It really change?
It will either win or lose against PHX in idle, video, web, but is that really that important?
Does It really matter that Intel will maybe consume 1-2watts less than AMD in those cases?
The only thing It will do is extend your battery life, but how many really need more than 8 hours of battery life, or rather how many wouldn't have electrical outlet to charge their laptop?
If It was about electricity bill, then consuming under load should be more important I think.
Tigerick
820
785
ZenBook 14 RetailMechRevo 14 Pro 2024 RetailLenovo Legion Pro 16 RetailRedmiBook 16 RetailMechRevo 14+ RetailLenovo Air 14 Retail
ICU-7 155HICU-5 125HICU-5 125Hi5-13500HR7 7840HSR7 7840U
6P + 8E4P + 8E4P + 8E4P + 8E8P8P
24 MB18 MB18 MB18 MB16 MB16 MB
32G 746732G 560032G 746716G 640016G 640016G 6400
128EU112 EU112EU80EU768SP768SP
1 Fan2 Fans2 Fans2 Fans2 Fans2 Fans
75 WHr60 WHr84 WHr72 WHr60 WHr65 WHr
AC Adaptor65 W100 W100 W100 W100 W65 W
BIOS Tested203T140MTLTFV1615
Date: 12/23/2023
MECN42WW03032.17M4CN31WW
TDP28 W28 W28 W45 W35 W28 W
PL1 (Long)64 W60 W85 W70 W54 W30 W
PL2 (Short)64 W75 W115 W115 WNANA
Base1.6/1.4 GHz1.4/1.2 GHz1.4/1.2 GHz1.9 GHz3.8 GHz3.3 GHz
Turbo4.8 GHz4.5 GHz4.5 GHz4.7 GHz5.1 GHz5.1 GHz
CPU Burn-In
Clock Speed1.9 / 2.3 / 1.3 GHz2.8 / 4.0 / 2.2 GHz2.8 / 4.3 / 2.5 GHz3.5 / 2.8 GHz4.325 GHz3.525 GHz
CPU Power28 W59.89 W68.75 W46 W53.55 W36 W
CineBench R23
10 mins113061374514567120441605814825
Single T172916361641173917881689
AIDA Memory Latency143.9 ns145.2 ns133.7 ns89.7 ns105.0 ns126.7 ns
3DMark TimeSpy344232613564154529282901
Assassin's Creed FHD LQ454346NA5850
Tomb Raider FHD LQ595663336659
Video Editing CPU Only164 sec143 sec132 sec159 sec123 sec135 sec
Video Editing CPU + GPU48 sec35 sec34 secNANANA
I have compiled numbers from Chinese Youtuber 中正评测. He bought the retail version of ZenBook 14 and Lenovo's Legion 16 Pro; both videos are available at Youtube. For comparison, I have listed AMD 7840HS's numbers as well...
From the numbers we can conclude Meteor Lake is not as power efficient as Intel want you to believe. You need 115W PL2 to really hit the performance level approaching AMD's 780M. So much for Centrino and Intel 4 process node, if anyone still believe in IFS's skill, wait until you see CPU from Intel 20A/18A...
That's explain why Intel delays the launching of Ultra 9 cause Ultra 9 comes with 45W TDP and 2.5/2.3GHz base clock....
Khato
1,275
351
I have compiled numbers from UltraBook Review and Chinese Youtuber 中正评测. He bought the retail version of both ZenBook 14 and Lenovo 16 Pro; both videos are available at Youtube. For comparison, I have listed AMD 7840HS's numbers as well...
From the numbers we can conclude Meteor Lake is not as power efficient as Intel want you to believe. You needs 115W PL2 to really hit the performance level approaching AMD's 780M. So much for Centrino and Intel 4 process node, if anyone still believe in IFS's skill, wait until you see CPU from Intel 20A/18A...
And if you watch the full video you'll find that actual power numbers using AIDA64 system stability test on the stress FPU setting are provided. Which show that the ZenBook 14 is actually running 28W while the Legion Pro 16 is around 68W. Meanwhile the referenced MechRevo 14+ shows 54W. Once it goes down to the 35W level the CB23 score apparently drops to 12810 according to the video.
In case others are interested in looking through the source videos which are being referred to I've included below. Note that despite being in Chinese without subtitles there's enough English and numbers in the screenshots to get some information at least.
Zenbook 14:
Legion Pro 16:
MechRevo 14+: https://www.youtube.com/watch?v=y7afgiUYKFI
H433x0n
1,224
1,606
Thats while running under full load. Remember, CB benchmarking is a stress test. MTL isn't designed for that and will surely not fare well in it.
The power efficiency improvement under daily usage scenario should be a lot higher with the new pcode. Lets see real world power usage test results with the new pcode.
It will do fine under load with the updated microcode. If GoldenPig’s numbers are to be believed, the efficiency curve is fine. You don’t need to make caveats for it.
Abwx
11,868
4,846
So, with Win12 are we getting the "rear-view mirror"?
Only rear-view man know the answer, he ll tell you that hardware is no more relevant, only the software is, albeit he could change his mind...
Actually efficency may well have decreased..
If you set the CPU at say 28W and then increase the time it s turboing at say 50W you ll measure a higher score at the "28W" point, same at the 35W point FI, that s the "efficency improvement" they got, actually increasing the boost time and doing like if the CPU was at 28W and other tested point, just a big farce.
Philste
297
474
A Zenbook 14 as one of the lightest and smallest Ultrabooks definitely can't keep a 64W PL1 cooled, I bet the real power draw is much lower.
SiliconFly
1,924
1,284
I don't think we should overestimate RWC. It's just tiled version of RPC (or GLC+). So, when it comes to power efficiency gains, we can't expect much from it except for the node gains from Intel 7 to Intel 4 which is 20% best case (and nothing else significant I guess).
MTL real efficiency comes from it's whole architecture rather than RWC I think.
mikk
4,293
2,382
They have a pre installed Windows 10 in China or why don't he use Windows 11?
H433x0n
1,224
1,606
I tend to believe GoldenPig & UltraBookReview know how to review products and take accurate measurements. However, it’s possible they both screwed up. I don’t think it’s the most likely scenario but who knows.
We’ll see when more people get their hands on production laptops with the updated Bios.
Reactions: cebri1
controlflow
195
339
ZenBook 14 SampleZenBook 14 SampleZenBook 14 RetailLenovo Legion Pro 16 RetailMechRevo 14+ Retail
Tested ByUBRUBR中正评测中正评测中正评测
ICU-7 155HICU-5 125HR7 7840HS
6P + 8E4P + 8E8P
24 MB18 MB16 MB
32G 746732G 746716G 6400
128EU112EU768SP
1 Fan2 Fans2 Fans
75 WHr84 WHr60 WHr
BIOS Tested201203203MECN42WW2.17
TDP28 W28 W35 W
PL1 (Long)64 W85 W54 W
PL2 (Short)64 W115 WNA
Base1.6/1.4 GHz1.4/1.2 GHz3.8 GHz
Turbo4.8 GHz4.5 GHz5.1 GHz
CineBench R231204813873
10 mins1112612132113061456716058
Single T17511761172916411788
AIDA Memory Latency143.9 ns133.7 ns105.0 ns
Battery Life (Standard, Video Playback)5:15 Hours5:05 HoursNA
Assassin's Creed FHD LQ454658
Tomb Raider FHD LQ596366
Video Editing CPU Only164 sec132 sec123 sec
Video Editing CPU + GPU48 sec34 secNA
I have compiled numbers from UltraBook Review and Chinese Youtuber 中正评测. He bought the retail version of both ZenBook 14 and Lenovo's Legion 16 Pro; both videos are available at Youtube. For comparison, I have listed AMD 7840HS's numbers as well...
The 115W number is completely irrelevant and not happening in a Zenbook 14. That is a single fan 2.8 lb laptop with a tiny heatsink that can barely sustain 64W for more than a few seconds, forget even hitting 115W.
DaaQ
1,951
1,408
Wow the adroc of intel is here, I wouldn't have known without reading last 3 pages.
cebri1
373
405
They are using PL1 and PL2 numbers straight out from the specs sheet. No indication in any of those test it hit those power levels.
It's like posting 13900K gaming numbers and saying it needed 250W to achieve those results. Complete baloney.
Thunder 57
3,994
6,687
The real question is since when is 115W acceptable for a laptop? For awhile we seemed to settle on 35W and that seemed a bit much. Soon enough we were in the 15W range.
FlameTail
4,384
2,761
Perhaps take a look at Macbooks and what they do - arguably the best laptops in the industry.
mikk
4,293
2,382
Core Ultra 5 125H DTT On vs DTT Off
In 3 games DTT off runs faster, 1 game DTT on faster, 1 game equal. GPU clock speeds reporting is wrong or not? Seems low, not sure. CPU clock is wrong for sure.
On MTL devices with LP 7500 the memory can be downclocked to 5600 by the looks of it. SAGV seems to be off by default which is faster but also not as efficient. If it's off in battery mode this might be not so great.
CouncilorIrissa
686
2,615
On the contrary, majority of the so called "power efficiency" test results that we've come across so far has squarely focused on stressing the CPU tile alone while COMPLETELY ignoring the LPE cores, which I believe it completely wrong as it doesn't align with MTL's use cases. Just give MTL a chance to prove itself in lighter load tests with newer pcode. Thats all I'm sayin.
But if all you care is light and idle-level loads, then you'd be better off buying an M1-based Macbook Air, a three year old chip that is still unmatched by every non-Apple manufactured chip.
You also get to access the OS that does not BSOD on you (and spies just as well).
SiliconFly
1,924
1,284
M1 is a lot slower.
Also, Windows 11 is more stable than Macs and doesn't have the Spinning Wheel of Death like macOS.
CouncilorIrissa
686
2,615
M1 is a lot slower.
But you yourself suggested measuring MTL in an idle, non-performance sensitive scenario. Why is performance important in scenarios when you're barely touching a keyboard (the only ones that LP-E cores are actually doing anything)?
And regarding Windows' 11 stability: I guess my ROG Ally didn't get the memo about its stability when it crashed into BSOD while playing Genshin Impact, failing to boot afterwards and forcing me to do cloud recovery that resulted in the Windows 11 being reinstalled without a freaking Microsoft Store.
