Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 195 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
820
785
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
mikk
4,293
2,382
It's nothing new and btw there is a newer bios available with a bump from 2x to 3x. Good Bios support from Asus, the others are slower. For the Acer there is zero bios update on the support page.
BIOS Update for Windows
Version 301
2023/12/22
IMPORTANCE: CRITICAL
Important Information: Optimize system performance
Reactions: TESKATLIPOKA
TESKATLIPOKA
2,696
3,260
Version 301
2023/12/22
At least we know which brand we should prefer.:) Lenovo:p
eek2121
3,406
5,043
I think the future of laptop RAM is this:
(1) On-package LPDDR
or
OEMs would flee if they couldn’t charge a premium for memory and AMD/Intel made the money instead. Dell practically invented a standard to avoid this.
So, just for the record, your though Intel was going to dominate mobile with lipstick on a power hog?
Every test I have seen shows MTL-P to be competitive with the 7840. Doesn’t seem like a power hog to me? Can Intel do better? probably. Is the chip better than previous Intel designs in terms of efficiency? Absolutely. Is it competitive with AMD? 100%. Will it outsell Zen 4 mobile? Without a doubt. Do I need a haircut? Yes.
SiliconFly
1,924
1,284
Nothing new there, It was already mentioned here.
And you even call It as a huge efficiency uplift. :D
It's not that big, only 7% higher sustained score in CB R23. And you call It as huge.o_O
Thats while running under full load. Remember, CB benchmarking is a stress test. MTL isn't designed for that and will surely not fare well in it.
The power efficiency improvement under daily usage scenario should be a lot higher with the new pcode. Lets see real world power usage test results with the new pcode.
TESKATLIPOKA
2,696
3,260
Then what is It designed for? Doing nothing or very light work?
For that you need 16 cores? Why do you even need so much cores, If you won't use them?
You really should think It trough before you write something, because what you wrote is BS.
Reactions: Mopetar and MangoX
SiliconFly
1,924
1,284
For that I need 16 cores? You really should think It trough before you wrote such a colossal BS.
Not really. Running CB to gauge power efficiency is BS as no real users in the world will do such nonsense.
Put it thru real world usage scenarios. Test it yourself if you have to. Only then you'll realize the difference.
TESKATLIPOKA
2,696
3,260
Checking out efficiency during full load is certainly not a BS like you claim. How you can write such a BS like this is beyond me. Not everyone is doing nothing on their laptops.
If you call watching videos or doing very light work on your laptop as real world usage scenarios, then you clearly don't need 16core MTL for that. You would be better off buying a Mackbook with better efficiency.
BTW, before you tell others to test something out, you should first do It yourself.
Reactions: MangoX
Abwx
11,868
4,846
You forgot that in single thread usage it use 20-25W, depending of the setting, so if even a fully loaded single thread is too much one has to wonder what is daily usage...
coercitiv
7,330
17,334
Follow the entire discussion pls, I'm not the one claiming the P core is a power hog. My question was merely a recall of multiple claims made by the other poster. You know, the kind of quick recap you get at the beginning of a new episode from your favorite show, which is great if you missed the last one while getting a haircut! :)
SiliconFly
1,924
1,284
Checking out efficiency during full load is certainly not a BS like you claim. How you even can write such a BS like this is beyond me. Not everyone is doing nothing on their laptops.
CB represents clearly less than 1% of the real world power usage scenarios. If you want to know MTL's real efficiency, we need to run tests that reflect its design purpose.
Before calling others BS, you should first think thru.
SiliconFly
1,924
1,284
It's really hilarious when people assume that MTL's LPE cores are not performant and completely useless!!!
They're pretty powerful in their own right. Their performance is pretty close to that of regular E cores. They are pretty much capable of doing lots of daily workload stuff without ever firing up the CPU tile. Thats MTL's design philosophy.
And testing power efficiency with ALL the P cores up and running simultaneously and continuously with CB is completely useless as the LPE cores never gets their due diligence.
TESKATLIPOKA
2,696
3,260
CB represents clearly less than 1% of the real world power usage scenarios. If you want to know MTL's real efficiency, run tests that reflect its design purpose.
Why don't you say It clearly, MTL is not as good as PHX during load so that's why you want to ignore It and only look where It wins.
Did you try out a MTL laptop? No
Yet you tell me to check It out.:rolleyes: Does that make sense?
If you want to show how great MTL is, then give us charts.
Abwx
11,868
4,846
Yes, but with Integer code power would be the same, this is documented, contrary to Zen 4 cores RPL and MTL cores use as much power in Integer than in FP.
That being said if you re talking of efficency when doing nothing that s another matter...
SiliconFly
1,924
1,284
...you want to ignore It and only look where It wins...
On the contrary, majority of the so called "power efficiency" test results that we've come across so far has squarely focused on stressing the CPU tile alone while COMPLETELY ignoring the LPE cores, which I believe it completely wrong as it doesn't align with MTL's use cases. Just give MTL a chance to prove itself in lighter load tests with newer pcode. Thats all I'm sayin.
18,856
Can't you guys wait for WIN12 before discussing MTL's efficiency? That's what the CPU is built for. Let's go silent at least until Zen 5 laptop chips are launched. Why go around and around in circles, especially with SiliconFly who can't stop thinking how sexy the LP cores are.
SiliconFly
1,924
1,284
So, with Win12 are we getting the "rear-view mirror"?
