Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 108 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
789
757
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
TESKATLIPOKA
2,696
3,260
14900KF is 15% faster than 7950X is ST & 20% faster in MT.
And there's no competition in sight for 6 month at least!
As for MTL, just 1 more day to go... 🤞
What?
Are you seriously expecting +15% ST and +20% MT performance from Raptor refresh using the same process?
edit:
@ondma compared to 7950X. I didn't say It was against Raptor.
FangBLade
203
399
What?
edit:
Raw power means nothing, Zen 4-3d outperforms Intel in games while consuming significantly less energy. That's a real victory. However, claiming victory with just a 5-10% lead while consuming over 100 watts more isn't a victory at all. On top of that, you get an inferior platform with no upgrade options. You'll pay a hefty price for the 14900 version, and if you want to upgrade, you have to buy everything anew. That's not a victory; the performance-to-power consumption ratio determines the winner.
RTX2080
334
533
I won't argue about the % of RPL-R lead. But, considering RPL-R is next month......4-5 months maybe.
TESKATLIPOKA
2,696
3,260
Shouldn't you have replied to @SiliconFly instead?
SiliconFly
1,924
1,284
Raptor refresh is not interesting at all. MTL is what I am interested in.
Me too. I'm more interested in MTL. A monolithic RPL-R (on an outdated node) shouldn't even exist in this day & age.
But RPL-R taking the performance crown and beating the competition by a significant margin is worth a mention.
(Source: here. Related articles: here & here).
Reactions: Darkmont
TESKATLIPOKA
2,696
3,260
Yeah, yeah. I will wait for official tests to see reality, I am really not interested in Geekbench.
BTW, why you posted 3 different links mentioning the same ST and MT score is something I really can't understand.
Ok, at least wccftech also mentioned Geekbench 5 not just 6, but then It was enough to just post that link.
H433x0n
1,224
1,606
14900K is just a rebranded 13900KS, it won't change anything in the performance stack.
It's a rebranded 13900K with process node tweaks to allow +200mhz clocks at iso power. It's a refresh so I don't think people are expecting much.
It will change the performance stack, just not for that long. Across the board 14600K, 14700K and 14900K will get a ~5% ST performance bump. This puts the 14900K ST performance ~15% higher than 7950X. That's not a negligible difference.
gdansk
4,362
7,328
If the buyers needs 10% faster opening of bloated Electron applications (which would be nice) and also doesn't mind 200W+ power draw when they do happen to run the wrong games or application they could have already bought a 13900K.
On the high end it's simply a 200MHz boost for people who somehow didn't think the 13900K was good enough at any point in the past year.
ondma
3,297
1,684
Well, if one is building a new platform with Intel, they might as well get RPL-R, for a bit more performance at the same power. I dont think anyone is claiming it is a worthwhile upgrade from RPL.
TESKATLIPOKA
2,696
3,260
In CB R23 ST, It really could be 20% faster.
Not bad, but I am really not that keen on such high power draw, that's why I am more interested in MTL.
If someone is building a new platform, then this refresh is not a very good choice in my opinion.
1.) It doesn't look like It's upgradable to next gen.
2.) Very high power consumption
3.) Zen5 looks not to be too far away, I would at least wait to see how good It is.
gdansk
4,362
7,328
My line of thought is simply that if the 13900K wasn't good enough for you then the 14900K isn't cause to run to Microcenter.
For people building in the next few months it depends on what price cuts retailers manage for 13th gen because 200MHz isn't worth much.
There may be more interesting changes lower down in the stack.
SiliconFly
1,924
1,284
If AMD won by 20% in CB ST you would be the first to shout out how great AMD is.
Thats so true. :)
AMD has a nice following. Intel not so much.
Intel being in gutter for so long has tarnished its own image. Maybe MTL can change that perspective a bit.
H433x0n
1,224
1,606
It’s not just the 14900K. It’s the entire lineup getting that 200mhz boost.
So you’ve got to factor in:
14600K vs 7600X/7700X
14700K vs 7900X
14900K vs 7950X
It’s a none negligible performance difference in all cases. The i9 will have +15% ST lead and a MT advantage.
Zen 4 efficiency advantage gets reduced since all of these gain +200mhz base clocks at 125W.
SiliconFly
1,924
1,284
MTL will show us some improvements, not sure how big.
Maybe the biggest problem I have with Intel CPUs is not the power consumption but big-little approach.
AMD's approach is much more palatable to me.
I'm sure the big.little is just a stop gap measure until their new core architecture is up and running properly.
But then again, if they make huge advancements in the future with the little cores, then it's a different story altogether. Who knows!
TESKATLIPOKA
2,696
3,260
It’s a none negligible performance difference in all cases. The i9 will have +15% ST advantage and a MT advantage.
That will be true in some cases, but there won't be +15% ST and MT advantage on average.
That +200mhz at ISO power is not much and won't change anything.
Even in CB R23 MT, which is one of the best cases AMD would win and by a significant margin.
Ok, In the case of 7700X vs 14600K the difference wouldn't be big, but 7700X is not particularly efficient thanks to high clocks and only 8 cores.
13400K is also pretty efficient but at the cost of performance.
If you want it for games, then Raptor is also not doing good. The models with 3D cache are crushing everything.
Reactions: Tlh97 and Kryohi
Abwx
11,855
4,832
Good exemple of bad faith, i said in other words that for CB only the MT score matters, but if you want to forge some falsehood about me that render you happy why not, when arguments are worthless only thing left is bs like your post....
