AtenRa
- Feb 2, 2009
- 14,003
- 3,361
- 136
I am not sure I agree.
This is priced about the same as buying an existing i3 ($120) + GTX 750 ($100) but only uses about 1/2 the total power.
And significantly slower than the Core i3 + GTX750 in 1080p.
A lot of arguments against the current AMD APU lineup was exactly this. Spend a little more and get comparable (or better GPU performance) with considerable better thermals and consistent CPU performance. Also, Intel has a lot more choices, and often deals, for MBs. This pricing gives another alternative, but this time you also get a true 4C part. It is truly a viable to option to purchase for light gaming, and you don't have regrets with adding a GPU later, as you do with a APU.
First of all, Broadwell is only compatible with expensive H97 and Z97 boards. You cannot install Broadwell to H81/B85 boards.
Secondly, A10-7850K + R7 250 DDR3 in Hybrid CrossFire setup at total of $200 is faster than Broadwell HD6200 at 1080p.
Thirdly, you can use any dGPU with the APUs and you will not miss a lot of performance unless you are aiming for GTX980 and higher.
