Page 201 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
DisEnchantment
1,779
6,798
Some sad news about Intel's 10nm nodes (courtesy of WCCFTech):
Faster than Coffee Lake gen9/10 CPUs will only be released in 2022 which means AMD has all the chances to gain an even greater market share with its Ryzen 4000 CPUs. Looks like the 10nm node is pretty much unsolvable in regard to clocks/power consumption.
Let's just hope they will have a working fast and efficient 7nm node by 2022.
Dang, :(
I have been reading about this on twitter as well as on Tom's
If true, it is devastating.
Two years is a long time in Tech Industry.
I really don't wish for Intel to fall this behind.
In 2022 Intel will have to fight GAA from Samsung/TSMC. Samsung already have GAA test devices with a target of 30%+ performance process over their next gen 5nm process
GAA will bring decent gains similar to the move to FinFET.
I hope all the people they have been assembling lately will help them.
maddie
5,202
5,612
Dang, :(
Yeah, so let's see here.
TSMC advancing faster than Intel. Check
Intel 1-2 generations behind at present. Check
Intel will catch up in 2 years. Dream on
Reactions: lobz
Exist50
2,452
3,106
Just because Intel won't be at process parity doesn't mean we won't see any advancement at all. I don't know how you reached that conclusion.
JasonLD
488
447
Though in 3-4 years, TSMC, Samsung, and Intel's progress will all be dependent on ASML's progress on their EUV equipment. I expect all of them will be on same level in terms of process nodes by then. I expect quality of 3D stacking and packaging will be more important.
Reactions: lightmanek
maddie
5,202
5,612
So you think lithography machines is all, or at least the majority of chipmaking?
JasonLD
488
447
Yes, definitely. 3nm and beyond will need higher NA EUV system which isn't really due until 2023~2024. Going 3nm on current EUV system could be quite a risk, and TSMC is trying to stay with finfet on their 3nm. If they can achieve that, it will be a quite a achievement, but it is still unknown at this point.
DisEnchantment
1,779
6,798
Just stating that obvious but there is so much more to EUV process tech than just EUV machines.
Masks, pellicles, cell structures, patterning, resistance/capacitance management, cell libraries, interconnects and so much more... all of these need to be designed besides having the EUV machines.
Samsung and TSMC had the same ASML machines but the outcome is different.
JasonLD
488
447
Oh, definitely. However, All of the above things you mentioned are done within the specifications of what current EUV machines are capable of, on sub-7nm and any smaller nodes after. At least for the decade, TSMC, Samsung, and Intel will have to follow the ASML’s roadmap basically.
maddie
5,202
5,612
Which was basically true for each earlier state of lithography, and yet we had widely different architectures and performance levels. All engineers, in all fields, work within the limits of the available materials and tools.
Markeyse
112
13
41
I'm with you on this. I think 3D packaging is really the next step. After 7nm, what more is there? It is time to stack them chips!
jpiniero
17,113
7,503
Looks like Dell got some crap tier i5 1035g1 chips. Performance is what you would maybe expect from a 15 W i5 but it is running at 25 W. So performance on the previous XPS models with Whiskey is faster.
mikk
4,327
2,409
This might explain the big socket. I wonder what big little architecture they will use, possibly Gracemont.
jpiniero
17,113
7,503
https://videocardz.com/newz/intel-alder-lake-s-to-feature-16-cores-125-150w-tdp-and-pcie-4-0
Some new information on ADL-S. Looks like Intel is planning a heterogeneous mix of cores for the desktop (8 big + 8 small). Really interested in why they chose this option and not to go with more 'BIG' cores instead.
It's probably two 4+4 chiplets plus an IGP chiplet. The 125 maybe 150 W TDP at base does suggest that they might indeed backport Alder Lake to 14nm. Given when it'd be released (likely two years from now) you would think they would consider 7 nm.
Wouldn't surprise me if the 6+0 was Rocket Lake's CPU chiplet.
OriAr
Alder Lake is 10nm, that much is certain. If they backported Golden Cove to 14nm it'd have gotten another codename.
Regarding what is the exact configuration... At this point I think a big cores die + a small cores die but my guess is as good as anything else.
This is legitimately the biggest change in desktop since the introduction of x86-64, maybe even bigger.
Reactions: vstar and mikk
mikk
4,327
2,409
There is also a 8+8+1 variant with a TDP of only 80W TDP in this picture! I doubt this is doable with 14nm because Golden Cove is probably bigger than Willow Cove.
ondma
3,319
1,708
Seems strange on the desktop though. I would think big/little would be more suited for mobile, where you could operate on the small cores to save power until a heavy load required the big cores. I think the problem is that yields/power consumption on 10 nm is still not what it should be, so they cant make a 12 or 16 core with manageable power consumption or yields.
vstar
46
39
61
Golden cove + Gracemont would make sense.
Do we have any predictions of how Gracemont cores would perform?
OriAr
Gracemont should have IPC between SKL to Sunny Cove.
Not too shabby at all, especially if it's towards the higher end of the scale.
