If you look this is a roadmap from April.
Another thought... You know, Intel did say they were cutting back on PC R&D. Would it really shock you if Cannonlake Xeon D was the first product out on 10 nm?
AMD and VIA won some time to perfect their next gen cores.
Would be fun if the first 10nm product was Gemini Lake, but most people I talked to seem think it's still 14nm.
In trying to find more information out about Coffee Lake, I stumbled across the following on Intel's website:
Cannon Lake H (Coffee Lake)
Cannon Lake S (Coffee Lake)
Cannon Lake U/Y
If it comes from an Intel website, then it pretty much confirms that Coffe Lake is Cannonlake in 14nm. This is a good news. With this in mind it makes perfect sense that after Coffe Lake Intel goes to Icelake for desktop.
yeah, I was worried that Intel would stick with the same SKL architecture for three generations -- that would have been sheer laziness. CNL probably won't bring any big bangs, but perf/clock should go up, core count goes up, and things generally get a lot better.
Backporting Cannon Lake to 14nm+ would be pretty expensive though, wouldn't you think?
TBH if this true I think this means that there aren't much in the way of changes between CNL/CFL and KBL. So I wouldn't expect any IPC increase at all, and AVX-512 is likely to be emulation only.
I had always pegged Canon Lake as to when Intel was going to release a "Core Phone" processor. Even though that's dead, power consumption above everything else was still likely their #1 priority in development.
http://www.fool.com/investing/2016/09/14/exclusive-the-secret-of-intel-corporations-coffee.aspx
Coffee Lake is Cannon Lake but on Intel 14nm process?
People are very pessimistic about 10nm.
I'm quite excited for it. From now on we will see a process change every year, how cool is that? Maybe 10nm w/ FinFET with Cannonlake, but then with 10nm+ they might add III-V and Ge, then with 10nm++ add quantum well FETs.
Okay, that prolly won't happen, but it's good to see them being more agile and still have a solid pipeline of 1 product per year. You can't really ask for all the much more. Of course we want big IPC bumps and IGP increases, but we don't have any infos about that.
TDP for CNL-Y is 5.2W, so expect perf to go up within a similar power envelope to KBL.
They can get away with a 14nm Coffee Lake because the segments it will sell into are not really battery/power sensitive (not at all for desktops, minimally for big bulky laptops that people usually keep plugged in anyway).
Do keep in mind that the rules have changed by being on a node for 3 years. The yield of 14nm hasn't even been *healthy* for all that long, but they will already transition to the immature 10nm next year. Releasing products on 14nm isn't as drmatic since they will still have a few years (1 more year) to transition to 10nm. Sad but true.For good reason. Coffee Lake tells you that 10nm yields are still in the crapper and are going to be until pretty much the end of 2018. They can get away with a 14nm Coffee Lake because the segments it will sell into are not really battery/power sensitive (not at all for desktops, minimally for big bulky laptops that people usually keep plugged in anyway).
I guess he meant mapping AVX-512 onto (enhanced) AVX2 units. Or at least that's how I understood it 🙂What performance do you think emulation would be. Ye, that's right. Its not going to happen.
Correct 🙂
