ShintaiDK
- Apr 22, 2012
- 20,378
- 145
- 106
What does AVX512 and IGP have to do with one another?You know what I mean. The full hardware needed to do AVX-512 properly would be a waste on the mainstream CPU given the IGP.
It sure looks like the biggest release we've seen from Intel in years. From a pure flops pov it should yield at least a 50% jump in perf. Good times. (and about time.)Nice find there! So Coffee Lake is way more than Skylake/Kaby Lake on steroids. We're getting the complete package (CPU + iGPU architecture uodate) on top of 'more cores' (6C/12T).
Once you get that wide, you may as well use GPU compute instead. I'd much rather them add faster caches, more pipelines, SMT-4,etc...What does AVX512 and IGP have to do with one another?
I guess it would depend on the TDP... If they put the Coffee Lake-S on the HEDT socket (ie: 110W) that would be doable.Hopefully it also hits around 4Ghz. 3.8Ghz perhaps as base. That's always the problem when moving up in core count. And we know ST performance matters.
Or Intel could just make dual, quad, and hex core chips...One problem I see is that CFL 4+3e is probably about the same size as 6+2. I can't imagine that either would fly with Intel for their i3 and lower desktop, even cut. One possibility I guess would be some mixture of the Cannon Lake 2+2 die and a 4+2 die, either Coffee or Kaby rebrand.
This site sounds unreliable for me......http://www.fool.com/investing/2016/09/14/exclusive-the-secret-of-intel-corporations-coffee.aspx
Coffee Lake is Cannon Lake but on Intel 14nm process?
Yeah, a screenshot straight from Intel's website is so "unreliable"This site sounds unreliable for me......
LOLYeah, a screenshot straight from Intel's website is so "unreliable"![]()
Intel does not normally release two generations per year. Their PAO scheme means process, next year, architecture, next year optimization, next year back to process. So bringing uit two distinct 10nm products so close together does not make sense.Is there a proof (leaked Intel slide) that Coffee Lake really is 14nm and not 10nm ?
Coffee Lake could be just the code name for the bigger/high performance "Cannon Lake" SOC.
I think you can, thanks to the earlier leaks. It does make sense, Intel probably wants to burn more wafers at 14 nm+, and I guess it was cheaper to do this than to build more 10 nm capacity to support the entire lineup.Is there a proof (leaked Intel slide) that Coffee Lake really is 14nm and not 10nm ?
They didn't release a whole new lineup on 22 nm after releasing Broadwell though. The time gap is also much larger, you probably won't see Ice Lake on the desktop for at least a year after when Coffee launches.If you think desktop, they did the exact same when 14nm begun. Broadwell for mobile only and Xeon-D more or less.
They released Haswell Refresh, call it what you want.They didn't release a whole new lineup on 22 nm after releasing Broadwell though. The time gap is also much larger, you probably won't see Ice Lake on the desktop for at least a year after when Coffee launches.
True, but this is because Intel thought that "Haswell Refresh" would be enough. It wasn't and after the resulting fallout from this, they decided that they would in fact do significant new desktop chips every year.They didn't release a whole new lineup on 22 nm after releasing Broadwell though
Probably not, but Intel has shortened product cycles before (see Skylake-U launch in Q3 2015 after Broadwell-U launchedin Q1 2015).The time gap is also much larger, you probably won't see Ice Lake on the desktop for at least a year after when Coffee launches.
www.digitimes.com/news/a20161110PD210.htmlDigiTimes said:Intel reportedly is planning to add USB 3.1 and Wi-Fi functions into its motherboard chipsets and the new design may be implemented in its upcoming 300-series scheduled to be released at the end of 2017, according to sources from motherboard makers. Intel declined to comment on market speculation.
I think it'll be a new socket, incompatible with previous.May be the desktop version comes earlier than the notebook version. I believe we see the same pattern for Kabylake, apparently Quadcore KBL for notebooks comes later. I wonder if CFL will be compatible with 200-series or even 100-series.
It's a two year thing and not related to tick-tock. Besides, the FIVR is probably coming back and that would make things hard to keep compatible.Because? Assuming that CFL is CNL in 14nm, I doubt it. Intel traditionally don't release a new socket for a tick generation because it's from the same (Skylake) µarch family with minor changes. I expect a new socket with Icelake.
At this point the FIVR coming back with Coffee Lake is just a prediction, but since the TDP of Cannonlake-Y was increased to 5.2 it seems pretty likely that has FIVR.I
There is no indication that FIVR comes back for Cannonlake/Coffe Lake, what is your source? In fact there are reports that it comes back with Icelake generation. It is doubtful that Intel is changing this with CNL/CFL.
