Im so Happy to have Radeon 7970GHz
Yes TriXX change my V i can see it in HWMonitor ! so where is the problem ?
And its verry good cooling on XFX DD i have MAX on OC 77-79c and when im mining it has 83-84c
Mid 80's is hot. My OC'ed 7950 never gets over the mid 60's, and thats with the fans at 50% speed (Although its a sapphire). The problem though is the vregs do not get much air flow. If they run too hot, they will fail prematurely.
Yeah, the problem is my BigTower and old fans ! ;-) i will change them in the near future here u have screen of my tower and fans 1 Up->down push, 1 side pull , and One back push to Zalman ! http://hwbot.org/submission/2329497_
thats old pictures with my nV 285 but Tower is the same and vents
OK the first fun ( side ) is set to Push and temps are lower 77-79c now is 62-66c 🙂 Hurra and 1200/1640 runing smooth, but still i canot go with higher G-RAM 1640 is most stable for now ! maby Flash Bios? who's on XFX DD GHz done it and live lol?
How hot are your VRMs getting OP?
Since you guys are talking about overclocking 7970s and I'll be buying a new PC with one in it soon,I wanted to ask a question.Which is better for overclocking,the MSI Twin Frozer or the Sapphire Vapor-X OC?Apart from that...Do you guys want me to post my 3DMark scores from my laptop with a Core 2 Duo at 2.4GHz and a mighty ATi Radeon HD4650 with a whooping 1GB VRAM?You could have a laugh and I'm gonna cry in my bed while looking at your scores. 😛
I have new scores :
3D Mark 13 CloudGate = 18579 { 54652, 5613}
3D Mark 13 FireStrike EXTr = 3781 { 4004, 8793 }
3D MarkVantage = 26730 {29832 GPU , 20375 CPU }
I have new scores :
Vantage score is kinda low. What clocks were you at
My 7970 @1230/1700
Durvelle27
uff CPU give a real boost in this Test
You know i think i have problem with my GPU so i will be change it for new one in my shop, cuz when i play Crysis 3 (average 45 fps in FRAPS) later when in net Fire Fox i have artifacts on Top of the screen little green nasty things, then they vanish. I think i will have to change for new cuz i have door->door ! what u think?
Durvelle27
Is it OC'd if so is the power tune at 20%
ok +20% and 1120/1600 and after Heaven bench about 15min stress its generating artifats on FireFox (harware accelerated) dunno why but everything in bench was OK
and when i play Crysis 3 also its ok -> sob is fast i like XFX
what volts are you using also
