JulesMaximus
Originally posted by: funboy42
You can save even more if you turn the car off while coasting down the hill 😛
He could save even more gas if he pushes the car off a cliff.
Originally posted by: Philippine Mango
Originally posted by: DivideBYZero
Originally posted by: JulesMaximus
Coasting downhill is not going to save you any fuel whatsoever. When coasting in gear you are using zero gas anyway. Coasting in neutral you are actually using fuel to keep the engine at idle.
No. If I coast in gear the engine will turn and I will lose fuel. 🙁
Here, take an electric motor, hook it up to a battery, what does it do?
Now, take a dewalt or some other power tool, clasp the end to the spinning part on the electric motor, grasp one hand, yell to your mother from your basement to get her ass down there, tell her to get a multimeter and attach the electrodes to the wires coming out of the multimeter.
What happens?
as long as the engine is firing, you're still burning gas
No. My foot isn't on the gas pedal.
Then what's firing the combustion? :roll:
There isn't any. My foot is off the gas and the car is in neutral.
a combustion engine fires constantly if it is on. go back to grade school.
No. I'm saving gas.
If you honestly believe that, your an idiot.
What happens?
His mother's dead, jackhole! :|
I actually considered doing that once, but thankfully I knew that the brakes only work 3 times before the pedal locksup and doesn't function.
Look, when you let off of the accelerator pedal in gear the ECU cuts fuel and the engine is spun by the momentum of the wheels. When you are in neutral the engine is not attached to the wheels so the ECU has to keep a constant flow of fuel to allow the engine to idle.
Incase you didn't get it let me spell it out: WHEN THE ENGINE IS IDLING IT IS USING GASOLINE.
Originally posted by: jlbenedict
Even better:
Cut the floorboard out. It needs to be a big enough hole so you can place your feet on the asphault surface below. Place your transmission in neutral; turn off engine.
Pat your feet and pedal on the ground like Fred Flinstone and take your ass back to the stoneages!
Ok the OP is definitely trolling.
Originally posted by: Chryso
I like to turn off the engine when going downhill to save even more gas.
Originally posted by: Amused
This is illegal for the main reason that if your car stalls (it is more likely to stall at idle) you lose power steering and power brakes.
Some people are even more stupid and suggest shutting the car off when coasting, ensuring that they lose power steering and power breaks.
Both are bad ideas.
My car idles when it is at a stop. It's not moving, so no fuel is used. If I do that while the car body is moving I save money BIG TIME.
What happens?
****** you, like I have to know every ****** detail of every a-hole on this forum you jackass.
Damn, and we were so close to getting rid of you! :|
go let your car idle in your driveway all day and see how much gas you have left.
stupid. plus it's illegal. at least in the US anyway.
