Originally posted by: nakedfrog
:laugh:
You smarmy bastard. I know what you're doing.
*looks closely at DBZ's avatar*
Originally posted by: ElFenix
http://www.washingtonpost.com/wp-dyn/co...rticle/2006/08/03/AR2006080301403.html
as long as the engine is firing, you're still burning gas
No. My foot isn't on the gas pedal.
Then what's firing the combustion? :roll:
There isn't any. My foot is off the gas and the car is in neutral.
a combustion engine fires constantly if it is on. go back to grade school.
No. I'm saving gas.
Originally posted by: spidey07
Originally posted by: MercenaryForHire
NOT THIS THREAD AGAIN 😕
- M4H
Agreed. OP is trolling hugely.
Originally posted by: Philippine Mango
Also I bet the OP doesn't know but if you use engine braking, the ECU will adjust to using the same amount of fuel as when it's idle. I think the safest route would be to shift into a gear with the lowest resistance for the best mileage assuming of course you want to coast as far as possible since engine braking does just that, BRAKE and therefore slow you down...
Originally posted by: JulesMaximus
Coasting downhill is not going to save you any fuel whatsoever. When coasting in gear you are using zero gas anyway. Coasting in neutral you are actually using fuel to keep the engine at idle.
:laugh:
You just want to be a 'HYPERMILER' like me. 😛
OP IS TROLLING. STOP RESPONDING. 😛
- M4H
- M4H
Fixed 😛
- M4H
- M4H
:roll: another wannabe 'HYPERMILER'.
Originally posted by: MisterServer
i drive an audi with a trip display, when i coast downhill in neutral it says i'm getting 200 mpg.. if i leave it in 5th (last) gear i get the normal ~25 mpg
- M4H
Fixed 😛
- M4H
Yes, this has been done to death.
On another note did you know that a Lotus Elise will get 32mpg on the freeway? 😉
No. If I coast in gear the engine will turn and I will lose fuel. 🙁
Actually, you are wrong.
No. I'm saving gas.
Actually he's trolling, just play along..
