Originally posted by: ribbon13
Even if you make valid points Jedi, you need to learn how to present them in a more readable fashion.And I think most people who have been in the computer business as long as I have would put Seasonic, Zippy/Emacs, and PC Power & Cooling in the same league. Seasonic's primary market is countries with very expensive electricity, which is why they are so good at making efficient (80Plus) PSUs, Zippy is very much a bastion of the world wide server market, and PC Power & Cooling is what the military, mission-critical servers and life-support computers use.
Originally posted by: Googer
NO it is not if you look at the post above this one, PC Power and Cooling Pays for it's self iif you are an Antec user.
Also Ribbon and I discussed this PSU earlier in the Week. The Specifications on that PSU are horible. The Seasonic he always recomends shares both the 5volt and 3.3volt on a common rail. This is something I would expect to see in a cheap $50-60 PSU or one you get in a Cheap $24 Case and PSU combo. For $100 I expect to have separate lines for 5.5 and 3.3Volt, there is no excuse for it. For $99 I would expect to see better. For $89 I could do better.
Since the total draw on 3.3v and 5v rails are so low, does combined rails even matter.
Do Antec power supplies have separate 3.3/5v rails or is it only for cetain models?
Thats fine, but for $99 expect better than that. For the $75 and higher price range I expect separate rails and maybe PFC with 3% or better voltage regulaton. That Seasonic has 5% regulation and shared rails. POS.
SO if you use too much amperes on 5v with a PSU like the seasonic then you leave zero 3.3 volt power for your motherboard. Great IDEA![]()
I commend your aptitude in linguistics. However if your post is formatted terribly no one will read it and therefore no one will benefit from it. Which defeats the purpose, doesn't it?Originally posted by: JEDIYoda
What does making valid points have to do with readability....
First of all I would ask if you own or have owned a PCP&C PSU? If not I would ask if you read that from SPCR?Originally posted by: Mik3y
PSP&P is awesome, but I would never, ever put my money towards it. They're too damn loud! Seasonic for me.![]()
If that's the case, I'd like to bring attention to the fact that SPCR also deemed the Zalman 9500 loud and that's just not the consensus from people who own it! They saying it's quiet!
Also in the last three or four months the good people at SPCR have introduced a superior fan controller! They have addressed that issue very well by the way!!
The bottom line is when I discussed the noise issue with PCP&C technicians they addressed the topic in a worthy manner. They stated all the fans for use in thier PSUs are tested for long-term reliability more than thier noise production. Contrary to popular belief, gamers and average PC users are not their bread and butter, rather the industrial segment of the computer industry is primary marketshare. Factories, hospitals and other industries that require dependability over noise factor! Yet the engineers at PCP&C have taken corrective measures to deal with the noise issue by popular demand!
Also I read the comment "You want to know why I always recommend Seasonic? Simple: I don't like seeing threads about PSU problems." That is the reason I don't use anything other than PCP&C PSUs!
Next we have this comment: "Thats fine, but for $99 expect better than that. For the $75 and higher price range I expect separate rails and maybe PFC with 3% or better voltage regulaton. That Seasonic has 5% regulation and shared rails. POS." Truly seperate rails don't exist unless a seperate AC/DC transformer is used for every voltage.
Dual rails are a myth! Dual rails aren't necessary to run even the most high-end personal computer. It's important to remember that even though there are two "independent" 12V lines, they still draw from the same main source. It's highly unlikely that there are two separate 120VAC:12VDC power conversion devices in a PSU; this would be much too costly and inefficient. There is only one 12VDC source, and the two lines draw from the same transformer. Each line is coming from the same 12VDC source, but through its own "controlled gateway".
Ribbon, when you quoted me you omited some importatnt points. Especially where I said that I misread part of the specifications and did not see the negative symbol. I do not think you understand my point. The Seasonic is a $50 selling for $99. For that kind of money you can do better. I only recomendd the Sparkle/Fortron PSU becasue it reprented the best value for the guy asking about it on the opening thread.
Originally posted by: maluckey
So, when all is said and done, Zippy/Emacs (which makes some of the PC Power and Cooling, FSP (which makes some of the PC Power and Cooling as well), and of course PC Power and Cooling come out on top in the D*ck wagging contest.
It all boils down to this. If you do your own research and don't listen to to "seat of the pants testing" and Fanboys you will do fine in your PSU choice. False and deceptive advertising seem normal in this industry, and the only way to tell is to read between the lies (errrr lines?). A certain PSU manufacturer rates as Peak at 25C PSU temp, and another at sustained output at 40C. Guess which is better and more likely to not fail? Read, learn, buy.
I lost lots of money to a certain company's lies, now it's only server FSP units for me. They are inexpensive, and tough.--thats the real issue ya don`t weant to pay for quality!!
Until recently, ALL PC Power and cooling were manufactured by other companies, mainly FSP. Some of the the Silencer series is still an FSP design. Read, learn, buy.
FSP-300-60GT is resold by PC Power and Cooling as the Turbo Cool 300 and by California PC Products as their 300W power supplly.
PC Power and Cooling brand 400W Rev 2.01 ATX PS2 Power Supply is made by Zippy/Emacs
JEDIYoda
P.S., your ignorance and your A$$ is showing
You are so very very misinformed....
PCP&C manufacturers there own products and always have been!!
I do understand that supposedly the early silencer series were manufactured supposedly by another company...but even that is conjecture...
2.There is absolutely no truth to those unsubstantiated statements!
Only PCP&C makes there own PSU`s!!
3.I do understand that supposedly the early silencer series were manufactured supposedly by another company...but even that is conjecture
There is hardly a company out there that does not use parts that are made or branded by competitors to assemble there product in there warehouse and on there assembly line
PC P&C 510 ASL (nVidia SLI Certified)
Only the ASL model has the 8-pin (+12V) EPS connector REQUIRED for the Expert!
$239: http://www.pcpowercooling.com/produ...&view=techspecs
OCZ PowerStream 600W
http://www.ocztechnology.com/produc...am_power_supply
From $179: http://froogle.google.com/froogle?t...=Search+Froogle
Enermax 600W (New) Noisetaker 600W EG701AX-VE (W) (nVidia SLI Certified)
http://www.enermax.com.tw/english/p...setaker600w.htm
From: $139: http://froogle.google.com/froogle?t...=Search+Froogle
OCZ PowerStream 520W
From $116: http://froogle.google.com/froogle?t...=Search+Froogle
Enermax 535W (New) FMA 535W (nVidia SLI Certified)
Only the current model has the 8-pin (+12V) EPS connector REQUIRED for the Expert!
http://www.enermax.com.tw/english/p...su_fma_535w.htm
$83: http://www.ewiz.com/detail.php?p=PS...6c6f67876470201
Sparkle 550W (EPS) FSP550-60PLG
http://www.sparklepower.com/pdf/FSP550-60PLG.pdf
From $85: http://froogle.google.com/froogle?t...=Search+Froogle
Fortron 550W (EPS) FSP550-60PLN
http://www.home2000.net/client/fspg...?linenumber=126
http://www.fsp-group.com.tw/english...ctorname=EPS12V
From $79: http://froogle.google.com/froogle?t...=Search+Froogle
/Q]
Originally posted by: PC_Freak
I'm looking at the Antec Truepower 2.0 550W power supply, but it may be too much for my needs.
It will be supporting an AMD 3500, 1) 6800GS, 2 dvd-rw's, 3 HD's and 1GB of memory.
I will be adding another 6800GS down the road and 1 more GB of memory also.
What recommendations would you make for a power supply?
Originally posted by: ofiraltarasy
One:
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
Two:
http://www.newegg.com/Product/Product.asp?Item=N82E16817104982
Three:
http://www.newegg.com/Product/Product.asp?Item=N82E16817104973
Take your pick or just look for one with dual 12v rail and good amps like 16 or higher
Dual 12v rails are a myth...there is no such thing as true dual 12v rails!
All a dual rail rig has is a single 12v that is split into 2.....
You would be better off getting a single 12v rail that has at leasts 24amps...
