Originally posted by: malak
I'm told d-link is the way to go these days.
Originally posted by: WackyDan
Originally posted by: Googer
Go to your routers configureation setup. Usualy it is done through a web browser after entering the ip address of the default gateway. Find the page that lets you change channels and choose channel 11 since it has the least amount of interferance.
Really depends on his environment.
Wooooahhhhhh😀! I've just completed my wireless network with a D-Link router, PCI card, and camera. Took a bit of tweaking of the config programs and a couple calls to tech support, but I've got it working like a charm😎 D-Link tech support helped a bit and I must say they are good. I've also got all the security measures setup so I'm pretty much set. I wish that the manuals was hard copies instead of on CD, but I guess that's how it's being done nowadays.
Good luck in setting up your wireless network.
Yes, that is why channel 11 is his best choice, since it recieves the least amount of interferance. (channel 5 is usualy default)
are you using a pc or a mac?
Seriosuly make sure you are not using a microwave oven or cordless phone, if you have a cordless phone unplug it for a day or so and see if the problem goes away. With wireless setups there are soo many cause of disruption. This is just the start.
The Laptop is a PC. We just bought a new cordless phone, a GE, but I know its not the problem causer, because the problem was there even when the phone wasnt there.
Originally posted by: Mik3y
i'm on wireless all the time. it may be the location of your system from where the router is. wireless is very picky about hot spots.
My sisters room is not that far from the router. Her room is very close. She has the door closed most of the time, but the internet is still connected. But once it disconnects, it disconnects.
Her connection always says Excellent, even if we cant connect to the internet, so it can be quite confusing. But when she is on the internet, she never experiences problems, until it decides it wants to disconnect.
It never says "Way Cool!" or "Groovy"? Only "Excellent"?
Yeah, there definately is something wrong with your WiFi. You need to enable THC protocol. But be careful of other network "sniffers" in the area. Don't ever enable LSD mode though, because if it ever causes a disconnection, it could be permanent.
