Originally posted by: tkdromeo
P.s again, it seems i resoldered the wires good because i was able to use the multimedia reader for the MS Pro Duo 🙂 I feel very good about that accomplishment btw.
Originally posted by: QuiksilverX1
That PSU is overkill anyway, I'd just go with this.
http://www.bestbuy.com/site/ol...oduct&id=1188560188623
Also buying stuff online yields better prices. :S
Also does HP use proprietary connectors like dell? If so then you would need to find an HP compatible PSU.
nope the PS in that case is generic. he will be ok. but yeah I was thinking that 500 would be enough as well but shit if he want more let there be more. better for future upgrades anyway.
If I were in your position Id get something like this, if I had a PC club close by
http://pcclub.com/product_details.cfm?itemno=A6211121#
see how the cables come pre wrapped? Its great to keep clutter to a min. Its not to expensive. its got all the connections you will need. its powerful enough and has a little extra if you ever want to add another optical drive or HD (hard drive). I have a thermaltake in my case and am happy with it. its a 450Watt. Where ever you go keep an eye out for the wrapped cables.
Originally posted by: themisfit610
Yeah. Your power supply is _not_ enough to run a high end video card.
See, this is why I hate OEM computers. They stuff their tiny plastic coated cases to the gills with barely any breathing room, and give the system JUST enough power for the stock configuration. God help you if you want to upgrade anything.
--------I 100% agree. its BS BUUUT it also makes you give them more $ when you DO want to upgrade!!
You COULD frankenswap in an off the shelf power supply - HP and the other major OEM's stopped using proprietary connections awhile ago - but the major issue is going to be shoehorning the PSU into the case. They are likely using a proprietary form factor for the PSU, so you can likely forget about that as well.
-------------nope. there is no form factor in this case. he should be able to hot swap a PS easy as pie.
Originally posted by: tkdromeo K will do, but what do i get from best buy atm? 🙂
