HP 42" 1080P LCD at Best Buy for $749 or less with 12% off coupon YMMV
giltnerj0
Called local BB about it, quoted $1049 price. Went to store and had them check, also $1049 price.
BIGFOOTPI
1,029
if you are going to bother reporting on a failure it might be helpful to post what city/store so people know. Otherwise it just sounds like crass indifference to the probability of this deal.
And the price in the system is the same by phone or instore. And if you are going to break the hot deal cardinal rule of calling you should call a bestbuy at least an hour away from you to check all local stores in your area instead of calling the one you plan to go to.
giltnerj0
My bad, yeah that would be heplfull. Checked the Huntsville AL location, and the Murfreesboro TN location. Huntsville's price was $1049, and Murfreesboro didn't have any in stock.
Dynamyck
122
Went to a Houston Best Buy that online stock indicated they had one. Of course they didn't but a couple of other stores had it and the list price was either $1499, $1049 or $890. A BB 80 miles from here had a couple in stock for $749. May drive out there and grab one if I don't see that feedthepig.org commerical again where the guy about to buy the big flat screen HDTV says, "you're right, I don't need it".
OcFerris
497
Are there any current 10-12% coupons out there? I did a quick search but didn't find any. :(
Zap
22,377
7
Haha, good idea. That's what a friend did. He called several, but only one of them offered to look up other stores for him and located one.
Yes, but they won't accept coupon on clearance items. A friend of mine tried (same one as above).
GCS
4,898
Agreed.
Also if a location NEAR you has one but at a higher price buy it anyway. Go to another store or to a store that has it for LESS and return and rebuy. MANY MANY people have had success with this (myself included). I got lucky on this deal and didn't have a problem since my store had it and it was only $749. They also took my coupon w/o question.
I should mention on the coupon front that it worked just by scanning it. Meaning the system accepted it and there was no override needed. So get them to try it and wouldn't be surprised if it worked.
2 new coupons btw
FREE GIFT CARD WITH PURCHASE
10% Off Movers Guide coupon
Good Luck
Greg
Ferzerp
6,438
107
This deal moved me to HD. Now i've spent more on other things like a ps3, etc just to have stuff to use the tv for.
stay away from component and lower input on this if you can
GCS
4,898
Well I finally set mine up last night. I think it looks great. Does it look like $1500-$2000 Samsung, Sharp, Pioneer --- NO --- but I paid $660 for it.
I should mention that I am using it for GAMING ONLY. I set up a dedicated XBOX 360 system with a driving wheel, chair, 5.1 surround and this LCD and it fits the bill just fine. We will also use it for GHII & GHIII.
Greg
mrrame
7
anybody using this as a computer monitor? How dow 1920 x1080 look like. Can you post some pictures.
Thanks
Throckmorton
16,829
Thanks
Assuming it doesn't do 1:1 pixel mapping, it will suck for a PC
skywhr
3,866
Checked stock in my local BB, said they had them I went up was told they only had a different model.
The girl smiled really big dont know if shes hearing that question alot or.....
Chesapeake VA no go
John
Moderator Emeritus<br>Elite Member
The 2nd one is expired. However this one works like a champ.
I just returned from my local BB, and the friendly female CSR didn't even blink at the above coupon, or make an issue that the HP TV discussed in this thread was on clearance. Since I purchased it last Sat. she felt generous and rang it up as a price match which made the TV $674.99, plus I received 10% of the difference ($7.50) making the total credit back to my CC $82.50 + tax. Obviously it pays to make a couple of attempts to find a coupon friendly CSR. :D
BIGFOOTPI
1,029
TV is crap- returned 2 to Fayetteville GA store on Friday night.
Can't Display 1280x720 or 1920x1080 from VGA or DVI-HDMI. got either "NO SIGNAL" or was way screwed overscanned and distorted.
Optimal widescreen res that DOES work is 1360x768 = not HOT.
Cable tuner quality horrible on SD AND digital.
Seems these are only good for MAYBE OTA TV, DVD players and game consoles.
AliasX
508
The Best Buy near me had it listed at $1299. Talked the guy down to $900 out the door. I might have a chance at price matching with a store selling it for $750.
Anyway, do you guys think it is worth it for $900? or was it only close to worth it at $750? Should I return or keep at $900?
isekii
28,578
You could probably get a Sharp Aquos or a Samsung LCD TV for 900ish on sale + coupon at circuit city.
I'd just wait it out.
sapiens74
2,162
showed 1349 here in Hawaii, they only had one in stock, I had to pass on this one, though i wanted to replace my olevia
AliasX
508
Did you have to pay a restocking fee? If not, did you avoid it by claiming the TV was faulty?
BIGFOOTPI
1,029
actually- the tv I "opened" turned out to be USED or DISPLAY model- some dust, what looked like small splats of a sneeze on the screen, no power cable, batteries all ready in the remote= nice try Best Buy. So they got an earful on that one too. I didn't open the second one that still had factory straps around it.
So yes- I got a full refund.
BIGFOOTPI
1,029
Originally posted by: skywhr
cheap lcd is cheap
what did you expect
There is a difference between a "cheap LCD" and a LCD on clearance.
If you go to the HP website and other places the tv is as high as $1499
I EXPECT ANY lcd to do 1280x720 from a PC, and definitely expect it to at least have fair to good looking digital TV picture.
Your derogatory commentary is not appreciated nor needed. Bitter much?
Seems like informing the forum viewers of issues with a product should not result in commentary such as yours.
