Originally posted by: spaceman
not how many own a manual, but what % of licensed drivers know how to operate one?
Where i'm from you will need to learn to drive a manual before you get your licence, so yeah, even a 12 gear with a reversed shift, took quite a while to get used to shift backwards for 5 gears forward + overdrive 5 gears forward and 1 gear backwards +1 gear overdrive backwards.
When you are above 30MPH with such a monster and steer, shift, gas and break almost at the same time then you will know what it meas to concentrate on your driving.
OTOH, if you drove right into the sea, you could just turn on the pumps and go full gas in highest gear (10) and that pice of pansar would tug its way to shore on the other side.
For anyone who wants to try this, remember to check the drain plugs first, a friend of mine didn't do that and it doesn't float all that well when water is just drowning it, doesn't really matter that you have pumps at that stage either.
