How does the inside of your PC look like?
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
Originally posted by: scrawnypaleguy
Originally posted by: mooncancook
What passive cooling kit and how well does it work for your X800XL?? it'll nice for the P180 since I have the VGA duct setup.
Why do you want cold cathode in your case since your case doesn't have a window?
The video card cooler came stock with my card, it's a gigabyte. And CM makes a window for this case, you just have to buy it separately, which I will do if I can convince myself to go through the whole lighting mod I have in mind.
What are your plans for lighting, if you don't mind me asking? I'm going to be rigging up some lighting, and I'm always looking for new ideas! :)
Tas.
scrawnypaleguy
1,036
Tas.
Oh man I've been waiting for someone to ask that!
1) I'm going to replace the two 5mm blue leds behind the front "slab" on the case that act as power on lights with some white ones. (By the way, putting new ones on only includes attaching the power lines to the two ends on the leds and shrinkwrapping them separately right? If it's more complicated than that, someone please let me know!)
2) Replace the 5mm blue led hdd activity indicator with a white one as well (frozencpu.com sells pre-wired leds for just such projects; I'll pick up one of them)
3) Get CM's side window (clear, not blue).
4) Get CM's dual white ccfl kit and, if they fit, put one on the bottom along the edge and one on the left on the support beam, so you don't see the source of the light; just the glow lighting up my case's innards. I'm only using CM's because they have a pci thingy that allows me to shut them off for when I want to go to bed
5) get some random cable extenders to help hide wiring (specifically that psu fan rpm wire)
But before I do any of that, I'm going to take your advice and get the Zalman hard drive silencer and see if my case is quiet enough to allow the removal of the aluminum side panel, which probably dampens sound better than acrylic.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
Okay, first, with LEDs--you have to have a resistor in series with the LEDs, or you will burn them up. Send me the specs (voltage, max amps, etc) of your LEDs, and I'll let you know what resistor to pick up at Radio Shack (unfortunately the best place to go actually). And for the cable extenders, if you get some heat shrink tubing, you can hide the fact that there are extenders, and it can be used in leiu of cable sleeving and all that, and it will still look damn sexy if you have to show the wires...
Tas.
scrawnypaleguy
1,036
Crap. I knew it couldn't be that easy. I have absolutely no idea what the specs are for the leds, but it's ok, I'll just go to plan B: get a Lazer LED bank of 3 white leds, tape it to the hard drive cage right behind the intake grill, and remove the old leds. the light might not be as good, but it's better than nothin. And thanks for the idea of the heatshrink, I'll keep that in mind.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
It's not hard, I promise. What LEDs are you getting? (Find them online at Radio Crap, and send me the link). And if you know how to solder, and have sleeving capabilities / materials, you just solder in the resistor, shrink tube it, and then carry on... I've already created a web site showing someone how to put in a switch for a LED. hehehehe. This would be easy too. :) Just let me know. Remember, mod what you want. Don't settle for "I can do this instead".
Tas.
Remedy
3,981
Outside
Inside
I'm rather proud of the wiring. Do you guys think that if I moved the case speaker I could fit a cold cathode at the bottom and then another on the left side vertically?
Is it me or is that just an 80mm fan working as an exhaust system?:confused:
CraigRT
31,440
Outside
Inside
Yep...
I have the same case, works great...
scrawnypaleguy
1,036
You don't need much when you've already got an XP-90 on top of a venice core. Besides, I always count the PSU as an exhaust as well.
scrawnypaleguy
1,036
Tas.
5mm white led
Damn, I need a soldering iron too? I know how to solder (hooray for tech ed seven years ago) but I don't have one handy. They're not very expensive right? By the way, thanks a lot for the help.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
You can get a soldering iron for $7 at Radio Crap... But you will also need flux and solder... Tell you what. The resistors are only like $1. How were you planning on connecting this to the LED? I can build you the stuff for it. I'm at a pause on my modding anyway until I get the materials for the window....
Oh, and are you putting this on the 5v or 12v line on your molex?
Tas.
scrawnypaleguy
1,036
Tas.
What's flux? Now I'm really confused :( . I thought there were just wires that you had to attach (wrap, solder, whatever) to the ends of the led, but I had no idea there was this much to it. I think the leds are on the 5v line, they each have their own molex connector, here's a pic so you can see for yourself here
they're the two molexes on the left of the drive cage with the blue and white wires. Since they're not the standard color, I'm not sure if they're 5v or 7v, but they're definitely not 12v.
BillyBobJoel71
2,610
Originally posted by: RKS
Originally posted by: SuperTyphoon
SilverStone Temjin TJ06 with 2 extra fans added:
http://pics.bbzzdd.com/users/SuperTyphoon/DSCN1215.JPG
SuperTyphoon:
what kinda idle/load temps are you getting?
I am about to pull the trigger on a Lian Li v2100 but am concerned about high-temps or I can go with a Antec P180 which may have better cooling but a bit louder.
In between those choices the SS TJ06 looks like a great compromise but the layout/compartments don't seem as 'nice' as the first 2 options.
well, my cpu temp's idle are 34-36, with the cooler on highest rpm. my video card idles 54-56, same as the old case i used, and my cpu loads at about 45-48, while the video card loads at 68. since i added 2 extra fans (one above the soudn card, the other blowing air up to the top of the case) it is a bit louder but wow, everything is drowned out by the stock cooler on the video card. i love the case, it looks really nice.
it is a bit heavy, and the upside down thing was annoying, but i dfind that it is good for your cpu sicne it has the 2 120 mm fans blowing across it at the coolest part of the case. other than that, i think it is a great case. its your choice.
Safeway
12,075
11
You don't need flux. Just get rosin core solder. It has the flux in it.
scrawnypalguy, flux is an acid that cleans the metal contacts for a better connection. Rosin core is made for electronics and has this in the core of the solder.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
Yes, but as a complete matter of opinion, it doesn't work near as well. Liquid flux is the way to go. Liquid flux, and silver solder. You can't beat it. This coming from much experience soldering while sitting on top of a Isotta Franchini V8 which is Generator #1A, while the damn thing is running. Soldering goes so much quicker if you have the right stuff....
Tas.
scrawnypaleguy
1,036
Hmmm... do you think I could just bring in the leds that I have currently and have someone at radio shack show me how to replace the blue leds with the white ones?
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
*eg*. Sorry. Um, it's possible, but I've usually just gone in there for the blank stares. But you could always try it too... I could show you how, but you would still need the materials...
Tas.
Bulldog101598
Banned
Aug 2, 2005
32
Tas.
Bingo. Rosin core solder is junk.
imported_t0ast
24
Antec CS600B
I think it's a pretty decent job for my first build, though it doesn't quite stand up to some of the stuff i've seen here. That little purple bar tucked towards the back in the bottom right corner of the pic is a godsend for cable management. Though it's not a high priority (having a "sleeper" case w/o window) I'm still wanting to put that sleeving that came with the DFI mobo to use and clean it up some more.
Only parts that bug me are the bottom backside fan and the HD. That fan's cable is just long enough to reach the mobo plug, but not long enough to tuck anywhere. And though you can't see it, there's an 80mm fan mounted in the bottom 3.5" bay that cools it well, but makes the back end of the HD hang out and mess with the cable layout.
And yes, I know my PDA's digital camera sucks.
BillyBobJoel71
2,610
the only problem with mine is the orientation. because the mobo is upside down, there is a limit on how neat the cables can look in mine.
