- Sep 1, 2010
- 4,109
- 923
- 136
Decided that this deserved its own thread; I've mentioned this before somewhere (maybe in Vega builders) but it's still not fixed. So, here we go... sorry in advance for the length.
[system in question is first in my signature below, the Ryzen 1700 computer]
Started a few weeks ago while playing games, first time being Destiny 2 on the first release of Adrenalin drivers. Lost all video initially but then the sound bugged out maybe 10-20 seconds after; all I could do was reboot. Immediately rolled back drivers, making sure to do a clean install, but I think I may have used an older version of DDU. Long story short, the previous drivers (which I had been using just fine prior to updating) also crashed once the card started rendering 3D, or shortly thereafter.
So, naturally I uninstalled all AMD graphics drivers again and used the most recent DDU in safe mode to clean everything up. Didn't help, and the next go around the computer crashed just the same. Okay, so now I'm thinking the card is shot, so I remove it and try it in another machine, Also Win 10 Pro. Worked fine with latest drivers and didn't crash at all under heavy stress testing. A few suggested that it may be power related on the original computer but the PSU is actually 100W more than the minimum required for Vega. (I'm still trying to source another unit just in case this power supply is the culprit, but I don't think so).
Now, looking into other things I discovered my game drive had some unconfirmed sectors so I went and replaced the entire drive. System still crashes, updated some of my proprietary software (AIDA64, Logitech GS, even installed new sound drivers and confirmed DirectX integrity, system still crashes. Ran SFC on C: and confirmed that Windows installation was sound, updated and installed WhoCrashed, which didn't show any record of dumps, despite the Event Viewer showing that the display driver crashed but recovered (LIES!)
I'm pretty stumped at this point but I don't want to RMA yet because of how the card performed when installed in the other Windows 10 computer. This computer has been absolutely fine in the past, with a few little quirks that were easily ironed out. One of the only clues I have is that AMD drivers do NOT uninstall normally (i.e. progress gets to about 20% and just stops dead, never finishes), so that's odd but could be completely unrelated. Another clue is that all WattMan values default upon restarting but it's a hard restart so I suppose that's relatively normal.
I just flashed the BIOS on my board to the latest just for the heck of it and I've abandoned all OC values while trying to diagnose the issue. Nothing seems to have any affect on the problem though; pretty much all 3D apps and even some 2D stuff, such as Flash video and screen saver, crashes the computer. Looking at my keyboard LCD that runs the AIDA64 interface--once the screen goes dead the applet doesn't report stats for utilization or GPU temp, but the GPU dedicated memory still displays.
There aren't any new drivers for my board nor are there any Windows 10 updates available, so I'm not sure where to go at this point. If DDR4 wasn't so sinfully priced I'd try running a different kit but that's not happening. I still think it's a AMD driver bug but so far I've been unable to find the actual cause.
HALP?
HALP?
