Despoiler
- Nov 10, 2007
- 1,968
- 773
- 136
I think I may have figured this one out guys... but I won't know until I have a new power supply and cables.
Upon close inspection it looks like, and I don't know for sure, but the card may have been drawing so much power from a single PCIe power connector on the PSU that it actually fused the end of the cable into the port! I couldn't get the cable out, not even with pliers! The end of the cable actually snapped right off with two teeth still stuck in the power supply board so I think that might be what's up--or that once the card starting to draw heavy power the supply was cutting it off if there was a spike or short or something. Gah, that doesn't seem possible but needless to say I think I'll leave the power limit alone and use two separate cables with the new power supply!![]()
Seasonic X850? Possibly a defect in the cable or in the plug. Max GPU settings should pull around 400w. The physical connectors on the cables and plugs are rated way over the stated PCI-E spec.
