builder-inator
Alright thanks!! I'm going with the FX-4170/HD7790. Will you also be able to teach me how to build it once I order the parts
He says that I'll really need it so I'm thinking I'll go down one in graphics
Lol now I really don't know what to do, he says that there's no way he'll let me get 4GB then update. Maybe it's because he wants to do video editing, rendering and recording
You're really asking too much of a budget machine. It's hard to make something that can game and encode video competently on a strict budget. You're going to have to make some compromises.
But even with 4GB, can this build not do the video work?
OK know what, I'm somehow going to arrange the extra cash and get the 8GB without changing anything
Lol he recommends many things but doesn't pay for anything. I was snooping around through other forums and asked the same initial question, and this is what they said,
" Besides, that power supply is highly doubtful it will give the power you need. Why? Well that video card alone needs a minimum of a 450 Watt power supply as per manufacture's specs.
Second it is PCI-e 3.0 card and your motherboard is limited to 2.0.
Third, it may have 3 gigs of DDR5 but it only has a 128-bit interface. A 2 gig card with a 256-bit interface 2.0 will be considerably cheaper and not be a waste of money."
Downgrade to 1333mhz or 1600mhz. the 1866 isnt worth the cost.Oh man thanks a load for clearing it up! So my build is OK and will last me at least 3 years?
CPU: AMD FX 4170 Bulldozer Series CPU - 4.2GHz Quad(4) Core, AM3+ Socket,12MB, HyperTran - R1476
Motherboard: MSI AMD 970A-G46 970 Chipset - R1025
Memory: G.Skill F3-14900CL10S-8GBXL RipjawsX 1x8GB DDR3-1866 MHz Desktop Memory - R872
Video Card: PowerColor AX7770 1GBD5-PP2DH Radeon HD7770 - R1379
Power Supply: Corsair Builder Series CX430 V2 430W Power Supply - 80PLUS Certified - R513
I was thinking I downgrade the Ram to 1333 but I can't find anything
I did as you said, I couldn't find a 1333 so I got a 1600.
G.Skill F3-12800CL10S-8GBXL (1x 8GB) DDR3-1600MHz 1.5V CL9 Ripjaws Desktop Memory
I'm still looking for one. But my brother says I should wait for DDR4
