HardOCP editors declare "shimmer" issue meaningless
Apr 17, 2003
37,622
Originally posted by: 5150Joker
I'm going to upload 2 videos right now to show the drastic quality difference between HQ mode and Q mode in the scene depicted in those SS's. They're ~120 MB each uncompressed so it will take a little bit to upload them. I'm guessing that if you have a lower quality monitor or a small one (e.g. 17" CRT) then shimmering doesn't stick out as much. When you move up in resolution on a higher quality monitor, it is much more prevalent.
yes! do it!
5150Joker
5,549
www.techinferno.com
yes! do it!
Uploading right now :) My upload rate is only 50 KB/s so it's going to take almost 2 hrs to upload them.
5150Joker
5,549
www.techinferno.com
Finally the vids are done uploading. Both were taken using the 81.85 drivers with the 7800 GTX:
Quality Mode: 181 MB
Uncompressed FRAPS - Quality Mode
HQ Mode: 109 MB
Uncompressed FRAPS - HQ Mode
Anyone that isn't blind or glaringly biased will see that the shimmering problem is very much real with the 7800 cards, especially in Quality mode.
Edit:
From the FRAPs FAQ:
Where can I find the custom Fraps FPS1 codec?
The Fraps codec (FPS1) is put on the system when you install Fraps. If you've reinstalled Windows you will also need to reinstall Fraps in order to play back your movies.
Please keep in mind that if you want to give your raw footage to another person they will also need to have Fraps installed.
Go here: http://www.fraps.com and d/l and install fraps to view these videos.
lavaheadache
6,893
14
HQ Mode: 109 MB
Either that or they have too much pride to admit fault with their beloved 7800's
RussianSensation
19,458
765
So is this problem hardware specific? If so, wouldn't it affect 6xxx series cards too? If it's not hardware specific, shouldn't future drivers correct the problem? If they would, this isn't such a big deal.
5150Joker
5,549
www.techinferno.com
It was in the 6x series too but was reduced quite a bit via drivers + clamp. In the 7x series it's been around since release, reduced somewhat in HQ mode via 78.03+ drivers but still very much prevalent in quality mode. Nothing has been done since then to address this nor are there any indications that nVidia is working to do away with this problem anymore.
5150Joker
5,549
www.techinferno.com
damm i cant get the videos to play...
From the FRAPs FAQ: Where can I find the custom Fraps FPS1 codec?
nRollo
Banned
Jan 11, 2002
10,460
Originally posted by: Lonyo
Just because you and 2 website editors say it's a non-issue for the majority doesn't mean it's a non-issue.
I am not saying it's not an issue to anyone, on any game.
I am saying that for many of us, it's not even noticeable in the games we play.
I posted the thread because the quoted website editors agree with my position, and every story has two sides.
As you seem to be one of the people who notice it and don't like it in the games you play, I can appreciate your position and desire for resolution.
As a person who never notices it in the games I play, and one of many who doesn't, I hope you will afford me the same courtesy.
nRollo
Banned
Jan 11, 2002
10,460
Originally posted by: Madellga
Oh yes, because those 2 guys and Rollo said that, I won'tt see any shimmering anymore :roll:
For me, this means a lot: 2 respectable web editors who are not able to see shimmering should not be reviewing graphic cards - they don't have what it takes.
They should find another job. Beside that, HardOCP is a racist website and I normally don't like visiting them.
They can stick the "Canucks" where they find more convenient.....
LOL, yeah they're racists for calling Canadians .....Canadians!
BTW- as "Canuck" has no racial implications, you would be more accurate to describe H as "nationalists".
Megatomic
20,127
I've got both pics open and for the life of me I can't see what you all are talking about. I see moire in the quality pic but I don't see what is being called shimmering. :( Help me out?
Megatomic
20,127
I'll be able to look at the vids when I get home tomorrow morning. I am not supposed to install software on the PCs here at work (must set a good example...) so I can't see them tonight. Will they make the shimmering easier for me to see?
5150Joker
5,549
www.techinferno.com
Yes you should see them very clearly. The moire contributes to the shimmering and it almost goes away when you switch to HQ mode.
Apr 17, 2003
37,622
done and done, thanx a ton
M0RPH
3,302
Thanks for the videos, Joker. Can you tell me which HL2 level that is? I'd like to make a video on my X800 for comparison.
