Kaido
Originally posted by: Zaap
VoodooPower is something that's added separately, not with anything in your kits? I would hate to find out anyone I've set up a system for recently is experiencing Kernel Panics- though I haven't heard anything.
It's in some of my more modern ZIP sets. Basically you need a kext to handle Shutdown/Restart on a Hackintosh. It used to be OpenHaltRestart by Pystar, then SuperHai released VoodooPower, but then I started getting KP's on my rigs about 1-2 times a week (ALL of them), so I removed it a few days ago and haven't crashed since. Also, I have a new OpenHaltRestart that has all the Psystar "advertising" removed, so you don't see it when you boot up 🙂
If you setup a system for someone using a kit update that has VoodooPower in it, it's really simple to find out and fix. Just snag Mkext Tool here:
http://pcwizcomputer.com/index...=view&id=151&Itemid=48
Use the "View Contents" tab to see what's inside your Extensions.mkext file in the Extras folder on the root of the boot drive. If VoodooPower is in there, you can make just make a new Mkext using this tool with OpenHaltRestart instead. Or simply replace the Mkext with my next package update...as soon as 10.5.7 is out and I test it, I'm putting up a new thread with the kit using OpenHaltRestart. I can post the kext directly tomorrow if you need it sooner (not on my workstation atm).
