cmdrdredd
Did you get one from the defective batch?
Yes I did and as noted before I will have my FTW card tomorrow.
Thanks for the tip. Sounds like you are very familiar with the issue then. Next build I'll go for a more modern case - layouts have really changed since the Antec 900 came out. I got mine in Nov. 2007, so it's been through a few builds....
Would you please post unigine heaven with 4xAA for me to compare it to my 7950?
I am rocking with the Temjin TJ-08e. Micro-atx motherboards only. I had the Silverstone FT-03B for awhile, and that was probably the easiest, user friendly, advanced case I have ever (and will ever) own, but man it was just too big for me. So I sold down to get the Temjin. It's a fairly small case (noticeably smaller than the Antec 900) but still has pretty good cooling. I personally like the smaller footprint it leaves and doesn't have any of the annoying LED lights I thought were cool 10 years ago.
Thanks, here is mine:Please list all heaven parameters and I'll do that for you.
Actually it was 1200/5600. I just lowered it a little to accommodate the hot weather here.Here you have it, at +135 offset, 6600 memory. What type of overclock do you have on that 7950? 1150/5600? Amazing that it can beat the 670. Then again that's a 44% overclock, so it looks like it's paid off.
I am not saying it's the user error on your part,
but you must be the single person in the world that gets stuttering when turning Adaptive ON.
Nvidia has acknowledged issue with Kepler driver polling that can be seen on some systems with VSYNC ON. They have announced fix in next driver, but in the meantime Adaptive fixes this for most ppl.
Of course stuttering will never be fixed 100% because
(allow me the quote)
PC really is a minefield for these, worst issue is even developers close to the root of the various issues, eg. nic developers make a poor or non effort at all figuring these out.
Same with engine developers,... look at epic's Unreal Engine, up till today there are games out there with suboptimal ini/cfg settings, it would be easy for Epic to recommend or update certain defaults but apparently they don't care to explain, even less fixing things,...
eg. bInitializeShadersOnDemand is still set to "true", once became default because apparently certain Nvidia cards/ drivers could crash, hasn't been an issue for a while but the workaround stayed, even tho if you set it to "false" it often helped with some lag/ stutter one could encouter,... even worse recent unreal engine games revert manual changes if you don't write protect the files (which can cause other issues).
sound cards in "exclusive mode", can cause audio stutter which also can lead to visual stutter, best is to disable any "exlusive mode" settings.
network cards with flow control and interrupt-moderation enabled, many nic's default this to enabled (their devs even recommend it), often causes frequent lags and stutter of streaming or simply any kind of I/O activity if int sharing (which on a lot of hardware is the typical scenario)
Harddisks/IDE/SATA/PATA/AHCI controllers can easily affect lag/ stutter, what a difference a SSD makes is unbelievable (of course that's only another workaround and doesn't solve the problem) especially in Unreal Engine games where apperently the streaming/ caching/ loading of textures/ all kinds of data is not yet anywhere near perfect and often I think it's similar to the lazy implementation of available tools/ tech,- like with ur FXAA, some ppl (cough* Bethesda) didn't bother to tweak the settings they shipped with, it works but might not be working very well.
Recently played Batman Arkham City, great game but if you can't run this on a top notch system you're likely going to be dissappointed and annoyed by it's performance,... seriously it lags all over the place, even in it's benchmark run it has areas where texture streaming/ lod pop ins are terribly bad, makes you wonder if these things only get tested on ultra fast systems where ur not likely to encouter these,...
Instead of optimizing what they have they introduce "one thread frame lag", "frame smoothing" or keep old workarounds like "UseMinimalNVIDIADriverShaderOptimization" around,... together with driver profiles or drivers assuming certain things on top of all these workarounds who knows what's happening there,... it really seems to be a bloody mess, and as much as Nvidia and ATI usually get blamed for stutter I'm afraid it's not even their fault most of the time.
Well I figured I'd try it with my 670 which oc's a little better than Termie's. I can run these settings 24/7 w temps that top out mid 60's. Windforce 670 btw. 1270 core and 6840 memory
Very nice bench. Exactly in line with the ~7% overclock advantage you have. Again, Heaven is pretty consistent across platforms.
By the way, what's your offset to get to 1270? I've found that my max offset is +151, which gets me to 1215, so you have a good 5% on me due to the windforce cooler and larger PCB. If I were to do it all over again, I'd certainly consider the Gigabyte. In my Antec 900, though, it would force me to move an internal 120mm fan and would likely lead to higher case temps...
Don't forget to update your sig!
I have a +94 offset to get to 1270. Mine comes oc out of the box. I had to get the memory to 6800 for it to catch up to the 1270 core. After 6800 the memory wasn't getting me any more gains.
It really seems as if I finally got one of the better overclockering cards on the forum. 🙂
Nvidia Geforce driver v302.59 is available http://forums.guru3d.com/showthread.php?t=363158
Supports 6800-GTX690. Can use 2nd card for Physx now with GTX600 series.
Just got done installing and testing my new GTX 670 FTW card. Here's some comparison shots as well as a screenshot of what clocks I have it up to currently. I'm not trying to max this out. I did try going over +100 on the core but that took me above 1200Mhz Boost Clock and crashed Crysis 2. +75 keeps it around ~1160. The card with the white stripe on it is the GTX 670 SC version. You can see the FTW card has a full size PCB and the cooler off the GTX 680.
Termie, which drivers are you using?
