GTX670 Upgrade and Overclocking Review (vs. 5850 crossfire)
Termie
7,949
48
www.techbuyersguru.com
Do me a favor when you retest. Just play Caspian multi on a 64 player map, test for 300 seconds and just play normal. I want to compare against my 1300 core 7850
Testing for just 60 seconds just doesn't give an accurate picture of gameplay.
Here ya go:
What do ya got for me? ;)
By the way, this is not my preferred way to benchmark - dropping into the spawn screen messes things up and gives me very low minimums.
Ieat
260
Was that the max stable overclock you could get? 1058+125= 1183? Seems a bit low.
BallaTheFeared
8,115
Don't really surprise me, though it does surprise me a bit that OC vs OC 5850s are that far behind 470 SLI.
BD231
10,568
138
I get over 70 FPS average in that same BF3 run with an oc'd gtx 480 at 1080p and my 3D mark score is only 6700 ... what gives?
Jaydip
3,691
21
OP from all the benchmarks that i have seen on the web it seems that Kepler is greatly affected my memory overclocking.Increasing the clocks seems to have less of a impact on Kepler.
Termie
7,949
48
Couldn't really tell you, other than that there must be a difference in the way we're running the map. Also, you're at slightly lower resolution - but 70fps on all ultra honestly sounds pretty unlikely on a GTX480. Did you FRAPS it?
What did you OC the memory to?
I think you guys are on to something. I only clocked up the memory to 6400 from 6000. My core clock isn't giving me much in the way of scaling. I have to work on that memory overclock, but it's tricky, because you need to watch for memory correction kicking in and lowering the performance.
Alas, the only game I really care about is BF3, and I'm going to turn on nVidia's Adaptive vsync to lock in smooth gameplay around 60fps. Now if only I could figure out the driver glitches in that game...
BD231
10,568
138
HBAO was off my bad, I'm at 59 average with in on.
Borealis7
2,901
205
Tremie, your upgrade has actually given me some good info ;)
now i know a GTX670 will roughly be twice as fast as my current single 5850! thanks!
Termie
7,949
48
That's exactly right - the 670 is just about twice as fast as the 5850, and at least in the benchmarking apps, is able to beat 5850 crossfire, which has imperfect scaling.
BD231
10,568
138
Still too high for a 480 Oced. 480 Oced can't compete with 670 Oced or even 5850 cf Oced.
You'll get 50 to 60 fps average on ultra with an oc'd 480, ran it three times and hit 59/58/59. Turn off HBAO and you're into the 70's :/. I expected more from the 670.
Ieat
260
Your Heaven benchmark seems low. I get about 18% more frames at 1293mhz and 6600 mem. 18% more frames from a 9% higher overclock doesn't seem right. Maybe a cpu bottleneck?
f1sherman
2,243
how about subjective feeling of gameplay 670 vs 5850 CF, i.e. smoothness, responsiveness?
T_Yamamoto
15,007
795
Yeah. I sense a bottleneck
Feb 19, 2009
10,457
10
Metro is not an AMD favored game btw, it's a TWIMTBP title.
Surprisingly good results for the old boys.. 5850s, one of the best gpu ever. You should however notice better gameplay/smoothness with the 670 in starcraft 2 ultra and shogun 2, i noticed a big difference when i ditched the cf setup for this single card in those games.
Termie
7,949
48
Wrong guys. It's the resolution. 1080p is exactly 11% lower total pixels than 1200p. ;)
Your extra boost makes up the rest. Heaven is completely unaffected by CPU - it is the ultimate GPU benchmark. I've tested it many times and found it to be perfectly comparable across CPUs.
blackened23
8,548
Yeah, I did a double take when I saw that. It was considered nvidia favored for a long time because the cayman series had pretty poor tessellation performance, but the tahitis are really strong in metro (and have dramatically increased tessellation performance in general)
