lehtv
In my experience OEM psu's are very good quality. I bought many Dells in my past.
Experience isn't a measure of quality
If it has a 6 pin connector, yes.
Give me a link to your HP computer, I'll will check psu to be sure.
Or the model number.
edit: you cpu pulls 73 watts, gtx960 120watts, hard drive and motherboard 20 watts on the +12v rail. Thats ~ 215 watts, but your entire system never runs 100% so you should be fine.
If you don't have a 6 pin connector on your psu, just use a 4pin to 6 pin connector for 4$.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200106
while gaming the gtx960 uses an average of 104 watts, his psu if I google the right one has 2 rails at 12 amps and 16 amps, that is plenty for a gtx960.
If his psu cant handle 104 watts then it wont handle a gtx750ti (70watts ) either. but it will.
"Average: Metro: Last Light at 1920x1080 because it is representative of a typical gaming power draw"
http://www.techpowerup.com/reviews/Gigabyte/GTX_950_Xtreme_Gaming/28.html
@frozentundra123456
Okay. But for past 2 yrs im using 7770 sapphire is it equal to gtx 750ti?
Huh? Is there some limiting reason why you're stuck to such a small psu?@Russian Sensation
So in other words, you're saying i shud get a good quality psu 400w and a gtx 950 or 960. Last 1 and 2 yrs, get a better rig.
@iiiankiii
Can the cpu of hp p6680d is swapable? To i7 920? If change to i7 920 and get new psu. What gpu can i7 920 handle?
By the way Mantle is terrible and not many games support it.
@iiiankiii
A psu of 300w and i5 650 able to support: (1) r7 250x (Y/N) (2)gtx 750ti (Y/N) (3) r7 360 (y/n) (4) r7 260x (Y/N)?
Will it bottleneck the games or lagging. Will be running on med/high no aa. Achievable to 60fps or lesser than that?
Games are: mgsvpp,bf3,4,hardline. Mw3,aw,ghost and bo2. Crysis3 and ac unity.
Can a gtx 750ti play bf3,bf4, bf hardline, crysis3, metro last light, codaw and ghost, and tomb raider. For a smooth meduim settings gameplay 60fps? Or get a gtx 960?
Current specs: i5 650 3.2ghz, hd 5540 (soon to replace gpu),8gb ram, 300w(hp prebuild) or 300+w.
@Russian Sensation
