SpeedTester
because 7970 is terrible for non overclocker users like me ...
What drivers are you on? The newest ones (12.8 iirc) make a massive difference.
SpeedTester
SpeedTester
60 fps average is great then .... if u never got below 50 in bf3 .... well .. that is idealfor me ...
Gordon Freemen
dude .. i got 7970 .... and i will never buy amd again ... my gtx 480 has better framerates in BF3 then 7970 .... don't believe me ? no problem ... but i saw my self and believe my eyes ... will never ever have again deal with AMD...
$550ish I think 1400mhz is with in reach on stock volts..
People have been touching 1500mhz on water. And it has dual Bios.. One guy got 1800mhz out of it with Ln2.
There is one draw back... it has No Dual link Dvi so if u have a 2560x1440 panel you would have to buy a Active display port to DL Dvi adaptor.
Other wise it supports hdmi Normal dvi /vga and display port.
Rvenger
wait you got 30 fps dips with gtx 670 ftw ? ;/ on gulf of omen ?? i know that maps are not optimezed ... but hell 30 fps it's like on my gtx 480![]()
OP said he didn't want to overclock so a cheaper card may suit him better.
SpeedTester
no need to talk me like that .... ;/ other people understand me well .. if you don't .. then it's your problem ....
QUOTE]
Just making my point....You said "Dude I got 7970", which in my eyes means you have a 7970, sorry for the misunderstanding.
SpeedTester
i got 7970 and sold it now i got 480 .... it just sounded a bit rude nothing more .... why you always try to "attack" me i don't understand ....
cmdrdredd
with no doubt msi is one of the best brand for overclock , but im looking for card with high stock clocks ... i mean with the best stock OC performance ....
cause im noob and prefer cards like plug and play ( no sarcasm )![]()
Problem is, the FTW cards will throttle sooner because they run hotter and will be a lot louder. Up to you though. Even though the base clock is higher it doesn't mean the card will boost the same as my card or someone else's card. I have two identical cards and at the same overclock they boost to different levels.
Just FYI: The MSI card comes clocked higher than the FTW card out of the box.
hm what about zotac amp edition ??? cooling is better then ftw has and core and memory clocks are even higher .... yes it costs a bit expensive but ....
msi is not a bad idea ..i had twin frozen cards before .... they really have good cooling system![]()
SpeedTester
Even stock on release drivers the 7970 was ~39% faster than a 480. Something's wrong somewhere. You got a bad card or there's something else wrong with your setup.
Nope I understood him last night just fine and the message was intended for me so ah heck off LOL.If your grammar was better maybe people could understand you. From this paragraph it's sounds like you have a 7970. Just trying to give my opinion, isn't that why you posted in a public forum?
