HybridSquirrel
New patch is out on steam. Seems to have significantly improved performance for me.
know if its hosted somewhere?
No idea. It's possible it's not out for non-steam copies, since they seem to require different executables.
Ever since I installed the ATI D3D9.dll the game's been running really well on my 5850. So I'm loathe to install any patches which might mess it up again.
There are no non-steam versions. FNV is a Steamworks game.
Anyway, the patch downloaded for me but now the game refuses to start... I had ZERO problems before the patch (okay, the game crashed once in 50 hours)... I click play on the launcher, the mouse turns into a wheel for a second, the process shows up in task manager and disappears after a second. Tried to disable all my mods... didn't help at all. Tried verifying local files a few times, no dice.
There was absolutely nothing I changed apart from the patch... "great" D:
Use this new version of FOMM:
http://www.newvegasnexus.com/downloads/file.php?id=36901
Make sure to list all ESM's first on the list (with the FONV ESM at the very top.)
Mine wouldn't start either with the new update... But it is always good to keep a vanilla copy of the game, in case you need to start over to figure out which mod is fucking things up.
Cheers.
Fellout is great during the day, but they overdid the darkness of night given how useless the pip-boy light is.
Link to the mod please? Is it for NV or FO3? I'd like it for FO3.That's why I also got a mod to improve Power Armors. Helmets have night vision toggle instead of the pip-boy light. Fits very well into the game imo (Power Armors are very high-tech).
Again, I'm hoping to wait until NV is (relatively) bug-free before buying it. Think the game will be cheaper then?The game was running suspect before patch, but the new patch made everything a lot more stable for me.
I do use mods as well, and have had zero crashes with it. I did the old school method of using a .txt rather than the .bsa so maybe that's why I haven't encountered any issues.
Keep in mind they patched a lot of PERFORMANCE related stuff, but didn't really fix broken things - such as certain quests. Also note Veronica is still jacked up (won't level) so you still have to use a mod to get her proper.
They should put the patch on their website labeled "for non-steam versions", then make a list of the IPs that download it for further investigation.Why would it be? The game requires Steam and it automatically updates on Steam. There's only one reason it would need to be hosted somewhere else. Good job.
Interesting that you guys are having less crashes since last Patch. Now I can't Play for 10 minutes before it Crashes. :$
Ed-E no longer does anything except place itself between an Enemy and me, the BoS Chick shows up once in awhile during a Firefight, then afterwards walks backwards until she runs into some object, although she's still walking backwards.
I regret buying this game so early, should have waited another Month or so.
