Discussion Geekbench 6 released and calibrated against Core i7-12700
Page 37 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Not really surprised. I9 class product with 8 big cores, slightly higher boost clock, more L3 and AVX-512 support vs. the lowest end Arrow Lake i3 class processor... Yeah, it SHOULD be better in MT at this point.
In MT, 10 core comet lake was better in MT than the lowest I3 class Alder/Rocket lake parts. The 9900KS demolishes dual core Rocket Lake and Tiger Lake parts in MT.
Supporting SME in WoA will push up the scores. By how much, we shall know.
Meanwhile, PTL by 18A might not even support AVX512, hmm. See how bad the process will push Intel down to the bottom of performance crown...
To no one's surprise, more use of SME.
I'd expect that the tasks that were optimised (manually even?) for SME should show quite a speedup from 512bit AVX-512 units too, if the benchmark was equally optimised for x86...
(edit: sorry for the tyops)
AVX-512 doesn't boost the score by 7% like SME Does more reason to not use GB6
MT sucks ass now ST will entirely be ISA Play.
You mean like when Zen4 got 242.1% higher uplift in Object Detection over Zen3 via AVX upgrade?
That's higher than the 227.9% that M4 Max got over M3 Max.
I didn't see you complain then.
Zen3 vs Zen4: https://browser.geekbench.com/v6/cpu/compare/13703871?baseline=13703302
M3 Max vs M4 Max: https://browser.geekbench.com/v6/cpu/compare/13690938?baseline=13701855
Geekbench IS optimised for x86. as @mikegg pointed out. AVX-VINNI and its 512-bit version do speed up Object detection.
There was no discussion around AI/ML extensions when Zen4 came out. Its only brought up when Apple introduced SME2 last year and the drama that followed.
Thats a massive difference, should we exclude that test because its an "outlier".
There is a difference between SME/AVX-512 SME is not part of an individual core it is shared by the entire CPU while AVX-512/VNNI is per core and when comparing single core performance how can you use a shared processing unit. It's like one core is using the ALU of another core
That has nothing to do with SME vs AVX-VNNI and everything to do with how Apple implemented SME. Nothing says that ARM/QC/whoever else will do what Apple did.
Also this continues to be a funny deflection from the fact that GB added support for VNNI and SVE before SME. And no one had a problem with that.
I was looking at those comparisons and just to get off the boring object detection dispute, what's going on with structure from motion? Zen4 gained only 4.7% in that benchmark despite higher clock rate, larger L2, and upgrade to DDR5 versus gaining 26% in Clang (something neither AVX512 nor SME2 will help)
Meanwhile M4 gained 17.7% in structure from motion versus 14.5% in Clang. Since the Mac comparison was GB6.5 vs GB6.5 it doesn't seem like this could have had anything to do with new instructions M4 added - according to the Geekbench PDF structure from motion uses AVX2 and NEON, so neither AVX512 nor SME2 will help.
So why such a minuscule gain in structure from motion on Zen4 despite all the advantages, and clearly being a rather big upgrade based on Clang, when M4 saw a gain in structure from motion very similar to the gain from Clang (and its overall gain, if you excluded SME2) What is happening with that benchmark that seems to have confounded Zen4? Looking at Zen5 numbers which were over 30% higher for it, whatever that was AMD fixed it.
