Question Geekbench 6 released and calibrated against Core i7-12700
Page 25 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
19,210
thunng8
167
72
101
It has nothing to do with intel cpus and the fans are indeed at 0 rpm.
The m4 was tested under ln2 and still lost. So even though it's unfair that I didn't have Ln2 to use as well, it's fine, don't need it.
So as I imagined an M4 pcore is larger in transistor count vs an intel pcore, isn't it?
The m4 tested with no cooling at all still gets approx 3750 in geekbench 6.3. They were trying to get the highest result possible and one test managed to get just over 4k with ln2 being poured over it. When macs come out, it would be easy to get that score with fans. 12900k in comparison scores approx 2700.
I have no ideas your obsession with transistor counts. It is a non-issue. If a CPU manufacturer can double speed with double transistor count for a core, they would be over the moon. It is just not a realistic scenario. If you really believe this, you have absolutely no clue about CPU design.
FYI - I really think you are trying to compete with Igor in this thread for comedy. Keep it coming.
Bencher
54
10
51
Of course transistor count is what matters when you are trying to compare CPUs with different architectures, instructions and nodes. What can ARM achieve with X amount of transistors vs what an x86 CPU can achieve with X amount of transistors. With the data we currently have a 3 year old x86 beats the latest and great arm by around 40% while having less than half the transistor count. At least in GB6. If you wanna compare something else, sure, just ask and ill have no problem testing it for you.
The m4 max / ultra are going to be what, 100b transistors? Im pretty confident theyd be getting blasted by any epyc / xeon chip with that trans count
thunng8
167
72
101
Show us a screenshot of your diagnostic that the fans were off. In my experience, desktops fans are never turned off unless it is faulty. They might be running at its lowest speced RPM though.
Reactions: Nothingness
Bencher
54
10
51
Seriously, you've never seen a 0rpm fan? Here you go. And check the fan curve im using on the CPU, it's 0% until 80c or roundabout.
thunng8
167
72
101
Ok, sure it has been a while. Interestingly, the system seems to have 4 other fans operating and with a large heat sink. I would hardly call this a passively cooled system.
Bencher
54
10
51
Well - that's the minimum rpm I can run those other fans
poke01
4,817
6,143
Limited to 45w. Still faster than the m4. Usually the chip wasn't even hitting the 45w power limit - it was sitting between 25-30. Only clang maxed it out.
"processor_frequency": {
"frequencies": [
4969,
4975,
4950,
4966,
4965,
4975,
4963,
4959,
4949,
4961,
4968,
4968,
4973,
4970,
4972,
4968,
4974,
4953,
4969,
5042,
5047,
5053,
5053,
5159,
5060,
5156,
5108,
5154,
5142,
5150,
5112,
5091,
5081,
5140,
5110,
5140,
5102,
4923,
4987,
5072,
5150,
5129,
5122,
5113,
4982,
5025,
5026,
5011,
5073,
5010,
5048
Is possible to test at 4.5Ghz? Its no surprise the 8P core 12900K with HT at 4.9GHz is faster than a 4P+6E at 4.5G in multi-core.
Bencher
54
10
51
With 8P+4E at 3.6GHz the M2 Max matches your 12900K.
Not sure it was running at those frequencies since it was limited to 45 watts.
Why do clockspeeds matter though? Performance per transistor count is what matters, clockspeeds and number of cores is kinda irrelevant. If a CPU can be faster while using 10.000 cores, great, got no issue.
EG1. The m2 max is what, 8 times bigger than the 12900k? And that's not disappointing?
thunng8
167
72
101
Most of the m2max is the GPU. It also has so much more than just the CPU cores. NPU, secure enclave, display engines, encode engines. Do you not even know this?
thunng8
167
72
101
It's not LN2 cooled either, still beats the ln2 cooled m4 ;)
I've already said it, when the ipad is not cooled at all, the speed difference is less than 8%. LN2 was only to get the highest possible speed in the ipad.
Here is a result fully passive cooling. Actually less than 5% speed difference.
Bencher
54
10
51
Sure, sure. For context, a 4080 super + a 12900k is still 17b less transistors than the m2 max. Practically it should be faster than a 4080s + 4x12900ks. Is it?
thunng8
167
72
101
Still a lot of thing missing even with adding the 4080 and 12900k. And uses approx 10X more power under load.
But the 4080 GPU demolishes the m2Max GPU though.
Bencher
54
10
51
What workload is the 4080 and 12900k 10x more power? As youve just pointed out yourself at 45w the 900k is matching the m2 max in gb6, no?
Nothingness
3,367
2,459
It's now pretty obvious you are into a crusade to validate your confirmation bias.
M2 floorplan: https://www.semianalysis.com/p/apple-m2-die-shot-and-architecture
12900k floorplan: https://www.techpowerup.com/review/intel-core-i9-12900k-alder-lake-12th-gen/2.html
Adding to the pain you compare GB6 MT scores which we know don't scale linearly. Piling up on invalid premises will only lead to incredibly stupid conclusions.
Bencher
54
10
51
Ah, now I get it. For the last 23 pages that you thought M4 was winning, GB6 was fine. Now that you realize it's actually losing, it's not fine to use GB6. Kay, no worries.
Eg1. It was you specifically arguing the last 10-15 pages about how great GB6 is against everyone else that says otherwise. Oh gosh
poke01
4,817
6,143
GPUs are a different story. Nvidia leads in perf/w and absolute performance. No one one is catching up to Nvidia this year or next year with the RTX 40/50 series.
thunng8
167
72
101
Who said it was losing? M3max demolishes the 12900k while using much less power. The m4 in an iPad pro that in a fanless 5mm thick chassis has much higher per core performance than the 12900k (or any intel processor). You really have a one track mind and absolute no sense of reality.
thunng8
167
72
101
Not sure about performance/watts, but definitely in absolute performance. The m3 gpu made huge advances compared to the m2 especially in compute.
I does look like this time, there will be an m4 Ultra. We will have to see if the performance gap closes.
Bencher
54
10
51
The m2 max (posted by nothingness above) and the m4 loses by a lot to the 12900k. The m3 max barely scratches a win, which is embarrassing considering it is what, ~19 times bigger in transistor count? 19 freaking times. Let that sink in...Of course any modern high end chip from amd or intel walks all over it, but sure, let's compare it to the 12900k, no problem.
