slag
- Dec 14, 2000
- 10,473
- 81
- 101
Nope. Not unless you install Allo.Any change to google assistant?
My only complaint with my S7 Edge is the battery life has been getting worse over time and it's now pretty shitty after being incredible for quite a while after I got it last summer some time.
I do have a Gear VR and updates to that fuckin software in the past have screwed with the battery life (and once caused phone heat issues). A couple days ago I followed the Samsung Gear VR uninstall instructions and uninstalled the one stupid app you can actually uninstall but that hasn't helped at all. I like the Gear VR but just don't use it much so I'm actually considering wiping the phone and starting over. I do seem to notice, though, that the battery can also be worse after doing a bunch of app updates through the Google Play Store. I actually hardly update my apps now because of that.
Maybe it's all in my head but I honestly don't think so. Any of you guys with the S7 notice a degrading battery? I got my S7 Edge new from Verizon in June of 2016. By the way the only thing I have running besides an occasional quick location/GPS enable is Wi-Fi (or a quick mobile data when Wi-Fi isn't available), though I've actually been keeping Wi-Fi off most of the time now due to the battery draining.
Hmmm, might be worth a try, thanks!This happened to me as well, all was fine for the first little while then i started to notice a drop in battery life, i started watching what programs were eating battery and noticed it was the android system itself that was eating battery.
This turned out to be a faulty SD card, as it had some corrupted files on it and the android system was scanning the SD card constantly to build a list of media files, it got to the corrupted files and just kept scanning in a loop killing battery life.
Took out sd card cleaned contacts and reformatted it and all was well again.
I also have degraded battery performance, but I can definitely tell that it is something keeping the phone from going into sleep or doze mode. I used to see the phone barely use any battery overnight, but now it chews through a lot of battery life, and never sleeps. I am not rooted, so apps like GSam can't tell me a whole lot other than the Android System/Android OS are using the most battery. So something is keeping the phone from going into a lower power mode (wakelock I guess is the term).
Rifter, how did you discover that the SD card was the issue specifically? Any way to tell that the system is scanning the SD card?
I really don't want to get into the Apple ecosystem, but crap like this, and hunting it down really makes me frustrated with Android. I barely have any apps installed. I don't use facebook or snapchat or anything. I hate having to spend time farting around with this crap to get my phone to work.
Every problem I've had with Sync was the fault of Sync.Anyone have issues with BT?
Mine connects to Sync, but the use as phone button goes to disabled as soon as I move it to enable. Media playback stays enabled. Going by previous occurrences, if I unpair and reestablish it will work normally for awhile and then same problem begins at some point.
Are you part of a team capable of churning out code in a couple months for something so massive as a full-blown mobile operating system? Do you have any idea how difficult it is to write and debug that much code?I find it funny that nougat dev preview was back in march 2016... almost a year ago, why does it take samsung that long to make an update?
Lg did it in december so yes its possible, with all the cash that samsung swims in it can hire a more capable team.Are you part of a team capable of churning out code in a couple months for something so massive as a full-blown mobile operating system? Do you have any idea how difficult it is to write and debug that much code?
