imported_Sincity
I think you have an awesome system here based on your budget. I think it is fine that you went "all out" on the FX60 since that will be the last high-end FX chip for the 939. You can always upgrade your 7800GT by getting a second one or get a new higher performing card later. But I suspect since you have a large LCD monitor, you are gaming at 1600 res or higher. Your video upgrade will probably come sooner than anticipated so start saving your pennies!
I noticed you bought a NV Silencer. The NV Silencer is an awesome cooler. But one problem, unless you have a SLI board that has two open slots between the SLI slots (ASUS and MSI top end Neo Platinum), you will not be able to use 2 NV Silencers. I think you DFI only has 1 slot in between. I could be wrong. I am returning my NV Silencer back to the Egg and awaiting Arctic Cooling's new GPU cooler called the Accelero X1 (out end of Feb). You can fit two Acceleros (according to my correspondance with Arctic Cooling) in a "tight" SLI board.
I only have one critque: ditch the Aspire PSU. I currently run Seasonics and Antecs. My former favorite was Silverstone.
