Fuuuu...dge
Craig234
38,548
350
I thoiught this would have info on fudge.
But the CA bay area is nice temperatures, more inland gets very hot.
AlienCraft
10,539
It was the run capacitor. Already cooling down in the house.
I am in Northern CA, near Sacramento.
I'm in Sacramento and we are re-installing our package unit on the roof.
Currently 155* up there. We are taking a water break, should have the ducts connected shortly.
BoomerD
66,704
15,104
That's why they have to spend so much time packing it ():)
shortylickens
80,287
17,082
AC went out last night about 9 PM. 103 yesterday. Already 80 in the house now and supposed to be 106 today. We keep it about 72.
Repair people supposed to be here between 1 and 3.
Better go down to the basement where it's cooler.
the only nice thing about a 3 level town house is theres always one place where you're comfortable.
14,076
Ouch that sucks. If I lived in a hot place like that I'd probably have redundant units and a generator that can power at least one of em.
I'm sitting here at work, and it's around 23C or so. I'm also logged into my house, and it's in the low 20's.
Living Room 21.3125°C (=)
Hallway 23.25°C (+)
Server Room 20.3125°C (=)
HVAC Return 19.75°C (=)
HVAC Supply 20.0625°C (=)
Outside 18.625°C (=)
Was freaking hot in my home office though, my new core i7 system is like a space heater. Got a 1 ton AC unit to take care of that though. Going to move that PC to the server room eventually.
BUTCH1
20,433
1,770
Can't fix your own A/C? Fail. :colbert:
I've fixed mine 3 times but some problems cannot be fixed by the homeowner. I've replaced a bad cap, fan motor, bad relay but if your evap coil leaks or compressor fails you will be callin in the pros, plus, like he said it's under warranty and opening anything would probably void it. OP, beware that many warranty's are parts ONLY and you could still get stuck with a bill for the labor to install it..
sad_guy
197
be a man and stop whining .. i lived without AC for 16 years.. just 2 years back i got one.
And btw thats in India not the cool america..
BUTCH1
20,433
1,770
You do realize that there are many different climates and temperatures in North America?, "Death Vally" has the highest recorded temperature, and Alaska is frozen over for 9 months of the year, the "cool america" comment just bumped you up on the dumb-o-meter quite a bit..
Greenman
22,486
6,572
It gets plenty hot everywhere but near the coast. It was a 100 here yesterday and I can see Suisun bay from my front door.
alkemyst
83,769
19
The fact is for the most part the United States has moderate temps most of the time. Sure there are outliers and exceptions...
BUTCH1
20,433
1,770
True, but you live in FL as do I and living without AC is possible but you would be one sweaty, miserable mofo..
alkemyst
83,769
19
I live coastal so most of the time that breeze off the ocean is nice, however; I keep my windows closed because even a block or two from the beach = dust.
postmortemIA
7,721
40
So worst summers are humid, as humans tolerance of heat very much depends of relative humidity and wind. Nothing worse than stale hot and wet air.
AreaCode707
18,447
133
It was 110F yesterday here. We are still lacking amenities like insulation, some of our doors/windows, etc. So it was 110F inside the house as well. :)
I'm glad the temp is back down to about 80 today.
BUTCH1
20,433
1,770
I'm about 1.5 miles from the beach (as the crow flies), one thing I've noticed is how fast stuff rusts the closer to the beach you are, AC condensing units in particular rust out quick as it's fan draws large amounts of salty mist through the coils..
Miramonti
28,653
100
We try and avoid the a/c, which has taken the inside temp to 88 lately. My office gets into the low 90's tho. We're just cheap like that.
Sheep221
1,843
27
That's a pity, I'm lucky that I can tolerate high heat, yes I don't need AC at 106.
Yeah, you just go around here with the threads you are hopeless in your life, but you tell others to be a man...this is uncool dude. Some people feel bad when the temp is high and need AC to feel ok.
olds
50,128
781
I am uncomfortable outside at temps over 90.
When the temps go over about 70-75, the AC comes on. In my car, even if opening the windows would cool the interior enough, I still use the AC. I don't care for the wind or road noise.
